The color temperature is approximately 5500 K 6000 - 6500K and the flashlight has mode memory. Turbo mode steps down to High after 3 minutes. In Turbo mode, mine gets warm but never too hot to touch. The only real complaint I have about my VG15s is that there is an approximately 1/2 second delay between FireFly mode and Low mode, and approximately a 1/4 second delay between Low and Medium. That is to say, you 1/2 press the button and there is a conspicuous delay between mode changes.
I cannot help but compare this flashlight to my BLF A6 siince the A6, for me, is the gold standard in 18650 tube flashlights. The A6 has a nicer finish (IMHO), better performance, more color temperature options, and more mode options than the VG15S. BangGood now regularly offers A6s from both their Chinese and US stores for under $20. Recently, Bilakos10 provided a BangGood coupon code that brought A6 price down to $17.50 at the Chinese store. (That code is no longer valid.) My point is, the VG15S is a decent flashlight, but there are probably better values available.
Update2: With the coupon, the Lightening Deal price on the VG15S is $13.12. You have to checkout before you see the coupon savings.This deal will be available until 8:15 pm EDT, or until they run out of flashlights.
Update3: My questions to ThorfireDirect about the VG15S:
Is the VG15S crenelated bezel aluminum, stainless steel, or some other metal?
How many amps does the LED draw during Turbo Mode?
What is the LED's color temperature?
Thanks!
Their reply:
The bezel of VG15S is make of stainless steel.
3 A on Turbo Mode.
The color temperature of the VG15S light is 6000-6500K.
Wow … snagged one. $13.12 delivered. Many Thanks for the heads up.
Order Summary
Item(s) Subtotal: $21.50
Shipping & Handling: $0.00
Your Coupon Savings: -$3.00
Lightning Deal: -$5.38
Total before tax: $13.12
Estimated tax to be collected: $0.00
Grand Total: $13.12
Interesting. It seems like it can run on a variety of batteries, provided you can make them fit. It looks like it can boost 1D cell, buck 4s AA. Tempting as an emergency light.
Found another deal, currently at $3.34 add on item. http://a.co/4CZPssb
Aimkon iTP N1 CREE XP-G2 165lm Keychain Flashlight
This is a very nice keychain light that uses 1/3N primary lithium batteries. It is smaller than 10180 lights. Peak output is insane for this size at 165 advertised lumens. My eyeball test says its about 140 real lumens. Unfortunately, 1/3N batteries are expensive and I haven’t been able to find a rechargeable cell to fit. I got one when it was $3.75, and the price fluctuates between that and $20.
The Lumintop Tool AA is in an Amazon (US) Lightening Deal until about 10:55 EDT, Jul 20 for $14.80. I believe the UltraTac A1 may be giving the Tool AA some competition in the future because of the similar form factor and modes However, the A1 has a better mode spread using NiMH, Alkaline, and primary lithium batteries: Low (1 Lumen) -> Med (30 Lumens)-> High (220 Lumens). Both the A1 and Tool AA start out in Low, have no mode memory. The A1 also has a more pleasant color tempertature IMHO at around 5500K verus 6500K for the Tool AA.
Thorfire VG10s is currently 40% off with N5LH2OQT coupon code, which brings it to $14.70 before tax.
Update: It looks like Thorfire is doing a lot of promotions on Amazon right now. A lot of the lights have coupons.
Many of the ones that don’t have coupons have substantial discounts on purchases of one or more if you scroll and look at the special offers. For example, the BLF Q8 is currently 30% off ($50.40) using the promotion code listed in special offers.
Finally, various products have discounts if you buy with other ThorFire products.
I took a chance on two of these headlamps from US Amazon. Two buttons provide separate control of the white and red LEDs. They are $4.04 each with coupon code HEADCO05.
Tested the coupon code again and it didn't work for me. Maybe it is one-time use only. Bon Chance!
No sir, I haven't received them and really know nothing about them other that what's in the description. But I doubt that you can bypass the strobe. They will probably be gifted. Bon Chance if you buy one!
Thanks! At $4, it’s worth a shot. I might give it to my kid to run around with.
EDIT: I noticed there is another listing for this product from a different seller - Amazon.com - this one has free 2-day prime shipping. Not sure if the coupon code would work on this listing as well. The coupon is one time use.
This head lamp has no mode memory per a response to my question on the site. The white LED always comes up in High, and the red LED always comes up steady. This means you will never see the strobe if you turn it off in High or Low - which works for me.
I am not concerned about the 3 - 4 week delivery time because I already have headlamps. This purchase is a whim, and my wife is going to gag when it arrive.
If I have to look at strobe to turn it off, then that would VERY disappointing. I probably would probably keep it in my car and give it away to a stranger.
I'm hoping its a knockoff of the Vitchello V800 headlamp which has similar appearance, separate buttons for white and red, like modes, no mode memory, and shut off when you hold the button down. I really do like the V800 headlamp which one reason I bought this one that seems similar.
One for you zoomie fans. The Wowtac A3 seems to have a price drop right now. It’s the 600 lumen model. I had a few of them at one time and they are a mighty fine zoomie. Comes with a micro usb equipped 18650. They were usually $19.99, now they have the price down to $15.95. The upgraded 1000 lumen A3S is still at $29.99.
