Amutorch AL1 XPL HD 1100LM glare Stepless Dimming L-shape Corner LED Flashlight Aluminum +Titanium +Resin 18650/ 16340 /18350
Here’s the exact tutorial:
Switch and mode:
Regular Mode: Onefold click to turn on . Onefold click to dimming:Low 0.1A-Med 0.7A-High1.5A,Turbo3A(quick double-click),Strobe(quick triple-click).
Stepless Dimming:it can customize the brightness, long click to turn on the light, then long click to increase the stepless brightness, release to lock and remembered the mode. then long click to decrease the stepless brightness. Minimum luminance mode is 20mA.
Long press for 1 second to turn it off at any luminance level.
The turbo mode can be activated by quick double click at any luminance level. quick triple-click to strobe.Fourfold click to lock or unlock.
Flashlight protection function explanation:
(1)Mode memory function: if the flashlight is turned on more than 3seconds ,current mode can be memoried.Turn it off and then turn it on ,still the original mode.
if less than 3seconds ,Turn it off and then turn it on ,it goes into the next mode.
(2)Battery reverse protection:if your battery is reversed,dont worry ,no any problem will happen.
Grabbed another Wuben A21, CW this time from banggood with your coupon. I just had to have two of these they’re so nice. Thanks again for the original group buy and the banggood coupon! :+1:
Probably going to get the new Lumintop ODF30C as well. I already have the original. Love that light too. Should have had USB charging on the original, but at least they have added it now.
Main Features:
●Lightweight Mini Design:
With its mini size, it is portable for you to bring it outside. The body is made of premium aluminum alloy with strong and sturdy design.
●672 Lumens Brightness:
The max brightness is 672 lumens, meeting your needs of night camping, running, observation or exploration perfectly.
●2600mAh Large Capacity Battery:
Comes with a 2600mAh large capacity battery, bringing you a brightness endurance for 2375mins.
●USB Charging Port:
With the USB Type-C charging port, providing great convenience for you.
●Unique SOS Mode:
It is unique with the SOS mode. Press the function button to send a distress signal.
better ask via Mail as that is much easier to follow and answer if a code is available. if I need to request my sources I post it here and on my other pages so the whole community can use it
