6 types of safety protections (short circuit protection, output load test, over charge protection, over discharge protection, over current protection, no-load protection)
I haven’t seen such data. Still it’s pretty save to assume there must be some step up converter because nominal voltage for single cell is around 0.5V and there are 8 cells in BW-L3 so at most ~4V if connected in series. Cells do not seem to be broken into smaller separate parts so higher voltage is rather not likely.
3 NEWCOLORS and 4 LED options = 12 new combinations
The purple one looks especially suited to host UV pill - direct swap from Convoy S2+ Nichia 365nm UV LED
I don’t think BangGood has the S2+ w/ Biscotti. They only offer the old, and annoying, 3/5 mode group for the S2+ for some reason, even on the newer Desert Tan, Cyan, Purple, and Orange models. But the C8+ listed on BangGood does come with Biscotti (you can see it says “12 mode”).
Convoy’s AliExpress store has the new S2+ purple w/ Biscotti here:
It seems like only Convoy’s AliExpress store has the new colors w/ XP-L Hi w/ Biscotti.
The new colors wth XM-L2 still use the old 5/3-mode groups firmware.
For that matter, I have yet to see a Convoy S2+ or C8 with XM-L2 LED that uses Biscotti… (probably need to customize ourselves to get that configuration)
I was reading in another thread that gearbest and banggood are very resistant to selling the Convoy products with the new Biscotti UI. They all seem to prefer the older, basic UI for some reason.
