Interesting point. I already have two of those, but I want two more.
A single unit can produce a very nice amount of light, however it becomes so bright that itâs unpleasant to look at it directly. By having multiple units, you can have a more balanced illumination, while keeping the output per unit low enough so it doesnât bother anymore looking directly at it.
Having multiple units also enhances the coziness as well; itâs just like with candles, having several of them instead of one enhances ambiance.
It doesnât feel cheap at all, it makes quite a worthy, well build impression, the materials used feel solid and the light color (WW) and light distribution are fantastic.
Iâm glad tho that it has a USD charging port because the only downside I could find is that itâs quite hard to screw on the âtailcapâ to the
battery compartment. If youâre not careful you run the risk at âscrewing upâ (no pun intended) the threads.
