One thing to note here is that the way of measuring the die size is not perfectly accurate. It is usually done by carefully taking a picture and then counting pixels.
I noticed it a few months ago, but didn’t see any big benefits. The rectangular shape of the die is definitely a downside.
They do state the luminance!
Die size: 0.93mm^2
Real thermal resistance: typ 4.1cd/mm^2
Luminance at 700mA: avg 110cd/mm^2
Edit:
The Black Flat is 20% larger, but only does 66cd/mm^2 at 700mA. So the Nichia might actually be really good if one can live with the die shape! Thanks Schoki!
Edit2:
The weird thing is that it’s a 6V LED! This makes it easier to drive the LED to its max in single cell lights, there are good boost drivers available.
I wonder how far apart the two dies are. This could ruin the beam with smo reflectors.
OK, so let’s consider the dies separately, so we can compare with Blackie a bit better.
Half-Nichia:
.465 mm² die. 110 cd / mm² at 1.5 A/mm² and 5 W/mm².
Blackie:
1.122 mm² die. 110 cd / mm² at 1.25 A/mm² and 3.85 W/mm².
Nichia has a bit better thermal resistance, but it doesn’t seem to be enough.
Also, its LES is significantly higher than die size in case of Nichia.
So probably not too good….
Luminance is candela per square millimeter of die area. This means it’s independent of the angle from which you are looking at the LED. The luminance determines the throw when the LED is combined with a given reflector or optic. The area of the lit up reflector as seen from the position of the hotspot in some distance mutiplied by the luminance determines the Candela (which leads to throw). This means that two LEDs with two reflectors will double the Candela (which leads to throw). A larger LED with the same luminance as a smaller one will not increase throw with a reflector, only the hotspot gets larger.
That means no matter how large the emitting area is, the LED (with a given luminance and reflector) will throw the same distance. Then the only thing that changes is the hotspot size?
But increasing the reflector/lens area “seen when looking into it” gives better candela —> more throw.
Right?
And pushing more power through the LED increases the luminance?
Here is the formula:
Luminus_intensity [cd] = luminance [cd/mm^2] * area_of_reflector_or_optic [mm^2] * losses [%]
Losses being the reflectivity of the reflector (or the transmission rate of the optic) and the transmission rate of the lens.
Generelly small LEDs which tolerate very high power densities reach the absolute highest luminance values. The Luminus CFT-90 is an outlier.
wait, so luminus intensity doesn’t depend on reflector shape?, so what if i have a very deep reflector( like 2cm diameter OTF) and 20cm OTF but narrow, both have same area, they will throw the same, right ?
No, it doesn’t. That’s a very common misconception.
If you have two reflectors with the same outer diameter but one is deeper, the deeper one will have a slightly smaller led opening. This increases the total reflective area slightly. The larger the reflector, the less important this becomes.
At constant diameter? Deeper reflector = larger hotspot……
Same intensity * more lm collected by the reflector = larger spot
Saying same thing in other terms…
All parabolas are the same except for the scale. All parabolic reflectors are (geometrically) the same except for the scale and 2 cut points.
Scale is usually expressed in terms of focal length (FL).
For a given emitter beam angle depends on FL and on nothing else. Larger FL = narrower beam.
For constant diameter, larger FL = smaller depth. So less deep = smaller spot.
You need to differentiate between hotspot and corona (“coma”). Deep reflectors (at the same outside diameter and same size LED) make the actual hotspot with maximum intensity smaller and the corona surrounding it bigger. The corona also has a high intensity, much higher than the spill, but noticeably lower than the hotspot itself. This fills in the dark gap between the hotspot and the spill when shining the light into the distance. This can create a more practical beam.
Armytek uses very deep reflectors. You can compare beamshots of them with those of lights from other manufacturers.
