I can get some readings but I swapped the LED in mine to a NW LED so it would not necessarily match what would be seen in the production version since the Vf varies among the LED’s.
If people really want to see I can check though.
I did test the lumen output before I swapped the LED and with the new TA sphere it read a bit over 1200 lumens.
His prototype had the thermal regulation set to off by default. It could of been changed in the menu as well but re-flashing ensured it was like the production lights will be.
Steel shows a Uni-T clamp meter on it, out of light, making only 3A on a GA and less than 3.5A on a VTC6, pretty lousy. Should be doing closer to 6A on that C6 and around 1500 lumens or more.
If that’s all that driver can do I’ll have to wipe it and build an FET+1 with the more standard components. Should be able to see over 1700 lumens in the assembled bypassed light.
That’s if, of course, I stay with the XP-L emitter…
The wires are about 50x too long in those pictures as well and causing massive voltage drop.
In the light the readings will be much higher. I can take some on my light if people want but it is using a NW LED I swapped in instead of the stock LED.
The driver is the same as any other FET driver, the only real change you could make outside of spring bypasses to get more power would be swapping the FET for a lower resistance model. Although the one they are using is not bad.
