Got some more Nichia Optisolis, this time the whole shebang: 2700-3000-3500-4000-5000-6500 K.
All the measurements can be found here:
Nichia Optisolis 2700-3000-3500-4000-5000-6500K - Album on Imgur
The tint and CRI on these is amazing. The 5000 K is truly a daylight simulator with practically perfect color rendering. You can also see that the peak on the 5000 K and 6500 K emitters is significantly lower at the purple wavelength. The dip above it is also much shallower than the typical cyan dip in a LED spectrum.
Just look at the spectrum!
Here’s a 4000 K with the low peak at a typical higher wavelength and a clear dip above it which reduces the color rendering indices just a bit. But in turn their Rg value is above 100 which means they oversaturate some color a bit, which might be preferable to some.
I also tested the output on the 3000 K and 5000 K variants up to 400 mA. Somewhat surprisingly the 3000 K is more efficient on lower currents but as the current is increased the 5000 K flies past. Forward voltage is higher on the 5000 K one as expected. I found it also amusing that I happened to get a perfect average 3000 K emitter, since its output was bang on 24.1 lumens at 65 mA just like Nichia specifies.
The tint was only tested with bare emitters. There’s barely any tint shift as can be seen from the OP, but Clemence tells me that these don’t work very well in clear optics as a quad at least but a frosted one is fine. It’s could also be quite difficult to find a suitable reflector. My go to Pineapple OP one did exhibit clear shifts in the hotspot. However, a beaded TIR optic looked excellent.
