Hum, do you know if there has been any change to the UI since a thread was created and suggestions were given to change it? Thanks in advance!
I guess not, went to see other thing on the bargainers site and the UI is the shame…oops, same
Hello my dear friends!
i got a small discount on the
use my code IT$LEDFZ to lower the price
Main Features:
●Lightweight Mini Design:
With its mini size, it is portable for you to bring it outside. The body is made of premium aluminum alloy with strong and sturdy design.
●672 Lumens Brightness:
The max brightness is 672 lumens, meeting your needs of night camping, running, observation or exploration perfectly.
●2600mAh Large Capacity Battery:
Comes with a 2600mAh large capacity battery, bringing you a brightness endurance for 2375mins.
●USB Charging Port:
With the USB Type-C charging port, providing great convenience for you.
●Unique SOS Mode:
It is unique with the SOS mode. Press the function button to send a distress signal.
also:
and do you like the flashdeals as much as i do?
Convoy S2+ Black XM-L2 7135x8 3/5mode EDC LED Flashlight 18650
Astrolux S42 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
BLF A6 XPL 1600LM 7/4modes EDC LED Flashlight + INR18650-30Q Battery
Martin, does “request a code” still work? I sent you a request some time ago, but I still have not received an answer.
I deactivated that because it grew too big
better ask via Mail as that is much easier to follow and answer if a code is available. if I need to request my sources I post it here and on my other pages so the whole community can use it
Okay, I will do as suggested as I also asked some days ago.
Message sent. I’m counting on an interesting discount
I checked the mail today and found my SC26 waiting for me!
Now all I have to do is wait for nightfall…
Thanks for the coupon code!
Amutorch AL1, ordered 1 NW 18650 thru your link, thanks.
thank you guys!
100 RESTOCKED
Features:
1.Utilizes a XP-L LED
2.High efficiency constant current circuit enables maximum output up to 600 lumens
3.Driven by 1 x 14500/AA battery for maximum runtime up to 240 hours
4.Intelligent memory functions
5.Toughened ultra-clear mineral glass with anti-reflective coating
6.Constructed from aerospace grade aluminum alloy
7.HAIII military grade hard-anodized
8.Waterproof in accordance with IPX-8 (2 meters submersible)
9.Very compact and lightweight flashlight for indoor outdoor everyday carry.
10.Can simple clip it onto your pocket, bags, notebook or anywhere you want.
11.Reverse polarity protection
12.Tail stand capability
13.With tail magnet, it is convenient to fixed operation and work
Package included:
1 x BlitzWolf® BW-ET1 XP-L V6 600LM Stepless Dimming LED Flashlight
2 x O-rings
1 x Lanyard
1 x White Diffuser
1 x Manual
1 x Body Tube
aand some more deals are added to
Thanks again Martin for your hard work on the codes, you saved me a bunch on my new Reylight AAA Copper pineapple!
today i added a deal for the
available in SAND color and BLACK
brand | model =my link to use | code | price |
Convoy | C8 sand | MSAD8 | 19.99 |
Convoy | C8+ black | MYN8C | 19.66 |
Brand: | Convoy |
Model: | C8+ |
Emitter Type: | XPL HI |
Light Tint & Light temperature: |
V2-1A 6500-7000K
U6-3A 5000-5200K
U6-4C 4200-4500K
U4-7A 3000-3300k |
Peak Beam Power: | 11 Watts |
Max Output: | 1100 Lumens |
Range: | 150 Meters |
Mode: | Details and operation please see the 1st picture below |
Battery Configurations: | 1x 18650 Li-ion battery (Both protected or unprotected) (Not included) |
Working Voltage: | 4.2V |
Switch Type: | Clicky |
Switch Location: | Tail of the Flashlight |
Material: | Aircraft-grade aluminum alloy |
Impact Resistant: | 1 Meter |
Waterproof: | IPX8 waterproof |
Reflector: |
Specially high reflectivity smoothreflector
Carrying Strap: | Lanyard |
Color: | Sand color |
Weight: | 145g (Excluding battery) |
Size: | 142mmx 44.5mmx 25.2mm (Lengthx Head diamemterx Body diameter) |
Specification:
1. LED : XPL HI with 1100 lumens high performance
2. C8+ runs on 1pcs 18650 lithium battery (protected or unprotected) ,easily buy and recharge
3. Specially made high reflectivity smoothreflector
4. Waterproof : IPX-8 waterproof
5. Expert level design with 12 goups & 55 modes dimming for your daily use and research needs
6. Big diamaond knurling
7. U shape tail with self-protection defense tactical tail
what about this…can we get a code?thanks a lot
on it!
hkequipment does a clearance of all SPARK flashlights –
use the code MDSPARK to get 45% OFF
and maybe it slipped your attention, but members get UP TO 20% OFF on Manker flashlights as well ;)
and banggood gave me codes for:
Thanks for the Spark info. I used your link and code to order two SP2 lights. Much appreciated! :+1:
If you guys have not seen it… check this out. . Fireflies ROT66
Martin & Neal come through again…. :+1:
hi martin. what wrongs about gearbest on your list
its disappear.
https://m4dm4x.com/m4d-m4x-deals/
where is gone?
