XHP35 HD NW. I measured 1850 lumen with the texas ace tube using 26650 shockli unprotected.
XHP35 HI NW… 1720 lumen. 26650 shockli unprotected.
Haikielite official Lumen are very consistent, just like you would expect from acebeam or thrunite…
Leds are well centered… i didnt encounter any artifiacts on the white wall…
Dome on have a bigger hotspot. Dome on version will be perfect for close ranges. Xhp hi have a tight hot spot, and i dont find any dark spot in the middle…
Both neutral white tints look great… i would guess 5600k…
Interesting mode…
While you are in turbo mode, then turn off the light… next time when you turn on the light, its always gonna be turbo mode… its kind of light an instant turbo mode until you hold the button…
Newlumen, have you measured the difference in output between a 26650 and a 26350 battery in each? Curious to know how bright the shorty version will measure up to the full length tube. :+1:
[/quote]
