I got no idea what could cause this, I had never voltage readout making problems, sometimes the diode bridge was closed by solder paste and I got 4.4V readout
Thanks. I’ll have to refer to the schematics to better understand the extra caps.
I wonder if I bypassed the diode by mistake somehow. I cant remember how low I took the actual cell voltage. I know I haven’t tested it with low SoC cell, but I thought I’d check with a cell @ ~3.7.
I got atm not enough time to get ahead with the Boost, I made some progress just to run into a problem again
I ordered version 3 of prototyp boards 10 days ago, with enhanced thermal path to cool the MPS chip as I ran likely on 50W output into thermal problems I hope the new board will fix it
So I think final version of programming port found
rearranged pins to fit MCU pins arrangement better than original v1.0 had
improvement machanically
2 traces on the pogo pin board to self align it by the solder
increased pad size on drivers to 0.8mm, to compensate wrong pogo pins
length of the solder traces on board reduced as some flux went in the pogo top, can be solved with alcohol but more distance is better
Added a key head for easier handling
added 2 holes to use a wire strap to secure the programming wire
Picture of v1.1 on V1.0 board, pin alignment does not work on the small 0.6mm pad on first reflow
over time new ones, but I have here hundreds of old boards stocked up, likely 600-800
so if I take a new board over an old I would charge something, as I am usually try to use older designs if the performance is the same
If a board got new MOSFET like on the Buck I am sitting on dead boards and parts if noone want a XHP35 Buck driver, where old parts have no disadvantage
I even cancelled the current enhancement fee for high power parts, but those 6-8A all get all new parts
