Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
So does this mean that we can put in an order for any of the above parts? If so, I would like to get 2 x p60 singe led pills.
Yes you can put an order and it will be made if MOQ is reached.
Great, I’d like to put in an order for 2 x p60 single led pills.
kiriba-ru how much do the B158 pills cost and how much do they weigh?
$10
Last time I had them was more than a year ago. Dont remember weight. Defenetly under 50gr.
The P60 single led is it with a retaining ring or do you solder the driver ?
No retaining ring, solder or press fit.
Thank you for the fast reply :slight_smile:
kiriba-ru
I’m interested in a maglite D kit with the adapter for a 17mm driver, shipped to the US. Is this still available and if so what would the total cost be, thanks.
All parts listed in the first post are available.
$13 kit
$4 17mm adapter (extra $3 if you want thin custom retaining ring instead of regular convoy one)
$8 shipping cost
i will be using a QLITE driver so which adapter would you recommend ? Thank you for the quick reply.
I recommend custom rings if you will use driver with components on both sides.
just so i’m clear, for $3.00 i get a retaining ring that will hold the 17mm driver in the adapter, is that correct ?
Yes. Custom ring is not cheap.
$3.00 for a custom machined brass ring sounds reasonable to me, certainly better than soldering one in
C8 copper pill with threads measure like fasttech brass pill are available?
Not available and never will be.
You can use this one: http://kaidomain.com/DIY-26mm-D-x-13_5mm-H-Copper-Driver-Pillar-Set-for-C8-LED-Flashlights?search=c8
thanks,This one doesn’t copper as declared but brass
right?
brass looks different: https://www.fasttech.com/p/1208600
I think someone wrote that he has bought it an it was realy copper.
