Ohhh, I like the recent developments! Put me down for a 5600K (I wish there was something in the middle, like a 4500K, but hey… I’ll take what I can get!)
I would like this light to have maximum runtime. So I vote 20 mA if 30 mA will reduce the runtime dramatically. These type of lights are not meant to be bright anyway.
I’m afraid I will need to do a current/output test this evening, and a 24hrs runtime test at 60mA to see how they last. That will generate some data on what current is best.
I suggested it to Barry, but had to explain what it is, I’m not sure if that is picked up very well so I may have to emphasize it once more.
Being of a skeptical nature, in the meantime I did some searching for the need of potting drivers and what came up is that it is about heavy components that come loose on impact, such as thoroids with ferrite rings. This light will have a tiny boost driver that needs to produce very little current so it has a very small (lightweight) coil, that needs much larger impact to come loose than a big thoroid. So I’m in doubt if the potted driver of the E01 is overkill or not.
So before I bug Barry about this: is there any experience at all among BLFers of small lights failing from broken-off components upon impact?
Only issue I (and another member) had so far was with Sofirn SP10! Somehow the impact (1m above the ground) damage a component or link between components and the light stopped working (even with magnifying lens I was never able to figure what it was).
But the SP10B has a different architecture regarding the driver. So, concerning these even smaller lights, I never had any issue. Don’t know if this helps, but that’s my only experience :zipper_mouth_face:
Thanks to all involved, this seems much more likely to happen now :+1:
I was on the list for two of the mooted Fenix version, but with Sofirn aiming for $6, I can put the same money in for twice as many lights!
I strongly recommend that the LEDs only be driven at 20mA.
We’re trying to build a bulletproof light here, and that’s the recommended spec from Yuji. One of the best ways to make electronics ultra-reliable is to run the parts well below their maximum rating.
If I had this project on my lab bench, I’d even be experimenting with 15mA, on the off-chance that the light output might still be acceptable.
Regarding the three colour choices, I’d suggest: hard-anodised black; hard-anodised grey; and red.
Black because many prefer an unobtrusive option; grey as an option that’s easier to find in the dark, but can still be hard-anodised; and red where high visibility is the priority, despite the slightly less robust anodising.
Yes it does matter. Impacts cause extremely high G loads. Solder is not a particularly strong material at 1000 G. The robustness of the E01 is legendary and there have been many tests of it against other unpotted 1xAAA lights. It always comes out on top.
It’s very important for impact resistance, and it can also help with water resistance in the event that an o-ring fails.
I’d also like to see a spring on the driver board to cushion impacts bouncing the cell around, even at the price of an extra couple of millimetres in overall light length.
As I said, I’m skeptical and like testing. There clearly is a correlation, the E01 is robust and the E01 has a potted driver, but that does not neccessarily have to be a causality. Solder is not strong but perhaps way strong enough for this, 1000G sounds an impressive number but a soldered tiny coil may survive 10,000G, who knows without testing.
So the “yes it does matter” still needs backup for me to accept it, either by experiences from small flashlight users, or actual impact tests of electronics showing mechanically failing components.
