I’m interested in a maglite D kit with the adapter for a 17mm driver, shipped to the US. Is this still available and if so what would the total cost be, thanks.
All parts listed in the first post are available.
$13 kit
$4 17mm adapter (extra $3 if you want thin custom retaining ring instead of regular convoy one)
$8 shipping cost
This is a little job I've done with a genuine UltraFire SK98 flashlight's pill.
Inner cylinder is ∅11.1mm approximately, made of two 1mm thick copper discs. Under it is soldered to a ∅18mm 1mm thick disc, and thermal glued to the pill's balcony.
This model would thank a nice and beefy copper pill, it is very easy to mount an H1-A driver in, fits snugly.
Originally posted on Sun, 07/29/2018 - 19:38. Added comments. Further edit to remove wrong white balance pics.
mtnelectronics is supposed to have something in the works, available at the beginning of August! I suspect a copper pill will be quite necessary when running an XHP in an S2+
