+1
At least, with BLF projects we get to discuss led tints, driver specs, ano quality, springs stiffness, square threads roundness and many other very interesting aspects of the project. That helps wait for the next prototype or beamshot…
The worst part of it is that i didn’t buy an other MF-0X light other then the 01 because i’m expecting this particular MF-03… because of this thread. :person_facepalming:
This one does look interesting. I decided not to get a DX80 at this time, I’ll wait to see how this one turns out. JasonWWW mentioned the MF04s and MF02s. Does anybody know where some decent videos are for these? I’ve been looking and I find a few still shots but no videos. I’ve purchased the MF04 (gave to my brother-in-law) and also the MF02 for me. I’d like to see a decent video where the MF04 is compared to the MF04s and the MF02 is compared to the MF02s. If you have any links please let me know. I’ll watch those while waiting for more info on the MF03.
For a good buck driver, Lexel was recommending 10 x 18650 to get 21 volts. It’s about the same diameter as the other options.
4 x 18650 can fit in a 44mm circle.
5 x 18650 needs a 49mm circle.
4 x 20700 needs a 49mm circle.
4 x 21700 needs a 51mm circle.
I think the one bonus feature of the MF03 that made it stand out was the added throw from the single xhp35-HI in the middle.
For the MF03 to compete, they may need to enlarge the head diameter to fit more 70.2 (from 7 to maybe 9 or 10) then maybe a bigger reflector for the xhp35-HI.
There are also TIR lenses that fit 70.2. I wonder if they would boost throw by narrowing the spill and improving efficiency. It could set this light more apart from others.
The 44mm is ideal case. Many 4x18650 flashlight has about 50mm battery tube, BLF GT is largest at 55mm.
Ya, that is the nice feature of MF03 with middle XHP35 HI. Someone has to talk to Imalent to put a XHP35 HI or XPL HI for the center LED of MS12, it may hit 250kcd but slightly lower max lumens. Or just factory dedome the center XHP 70 led, it should help. I was thinking can they dedome all the LED.
