wow still, i think they try to improve the battery or performance of the light then now that the x9r is out then relate to the runtimes on that and that their light will do almost 15000 more lumens so they better do a good runtime because who wants a light for that price if its not even 1 hourmax?
My EC50 Gen II is one of my favorite lights. Been using it often over the last year. UI is great, build quality very good. Considerably better than the average chinese flashlight. Also have the EC35 which is very good too.
While comparing a friends older X65 to ours (from the latest run), we noticed some differences. This sparked an interest to see what other changes
were made that weren’t easily visible. This list was complied from a series of emails over a period of 2-3 weeks with both Acebeam and my dealer.
- Battery indicator light was moved from the switch to a stand alone indicator light forward of the switch.
- Improved switch. Earlier switches were soft with little feedback. The latest switches are firm and positive.
- Updated reflector design for improved beam quality and less artifacts.
- Updated battery pack. The newest battery packs have been improved for better performance.
- The screws inside the head used to be Phillips. They are now Tamper-pruf screws.
- Improved UI. The double click timing to access Turbo and Turbo Max has been updated.
- Improved tailcap to ensure the lanyard ring rotates freely after a drop or impact.
- Improved centering ring to ensure the LED’s are perfectly centered at the factory.
And how can we know if a X65 is one of the new or from older deliveries? Can we ask for the Serial number?But which is the first S/N of the new deliveries?
I think its more struggling how get decent battery life from 8 x 18650 batteries thats gonna power 40k lumens and 3 fans also… thats the problem i think. Not the fans alone why would those be a problem ?
The fans need to be water proof, rust proof, dust proof, etc… for 5 years (that’s Acebeam’s usual warranty period). Maybe in their testing the fans can’t last more than a couple years.
We saw where Olight designed the X9 fan to be in a removable cartridge for easy cleaning and replacement.
Maybe Acebeam is having issues with that? Who knows.
Fujitsu is at least several thousand times the size of Acebeam and Olight. They have a huge amount of resources and thousands of engineers to perform research and development for products that sell in the millions. In comparison, Acebeam probably has a handful of engineers that develop products that sell in the hundreds or maybe thousands. For a company the size of Fujitsu to develop this capability is an achievement worth noting but for a company like Acebeam to successfully develop this feature is remarkably impressive.
I just hope Acebeam don’t end up failing like Olight. Would be funny if a bargain brand like Astrolux end up as the only one that can make an actively cooled flashlight.
I think most of the problem Acebeam is encountering have to do with making the fan water resistant, but they don’t have to if they used a separated motor and propeller assembly with a waterproof bearing in the shaft. Motor remains isolated and dry in the driver bay.
They’re probably limiting themselves by using regular computer fans where the motor and controller is inside the propeller, this makes the whole assembly exposed the elements.
