GearVita Daily Deal: Xiaomi Xiaobai Smart 1080P IP Camera - Panoramic HD, AI Humanoid Detection, Remote Alarm
The Fenix BC30R Bike Light won the ISPO (Asia) Award Gold Winner in 2015 so bike enthusiasts recognize the beauty of this new biking torch. As recognized by ISPO: "BC30R is the first Fenix light employing OLED display screen, which can display the rest runtime of the current output level and the battery percentage clearly, as the riders not only need comfortable lighting effect but also need to get to know the remaining runtime whether it is mountain biking or urban utility.”
The Fenix BC30R is for rugged conditions and features the industry's first digital display screen for confidence in your runtime readings. This micro USB charging bike light has a maximum of 20 hours of runtime. If you are a cyclist, there is no better bike light for you.
$10 discount and free shipping coupon code of GearVita: FNBC30RBL
Coupon price: $116.99
Coupon time: July 19 - July 31
Product link: https://gearvita.com/fenix-bc30r-led-bike-light-1800lm.html
Product Features:
● OLED digital display panel for remaining runtime at the current output and battery percentage.
● Remote pressure switch activates momentary on 1800 lumens.
● Dual Distance Beam System.
● Features low power warning and intelligent output downshift function.
● Quick-release handlebar mount for easy and secure adjustment of lights direction.
● Digitally regulated output maintains constant brightness.
● All-metal housing for better heat dissipation.
● IP66 rated protection:
- Dustproof - Totally protected against dust and foreign objects.
- Waterproof - Can withstand heavy rain and splashing.
Flexible Power Application with Carry-on Convenience! The Fenix BC21R Bike Light is an integrated yet versatile bike light which delivers a maximum 880-lumen neutral white light. The BC21R features four output modes plus flash to enhance your cycling activities. The built-in side red light assists in riding safety. The quick-release bike mount makes it easier to mount or dismount the light. Because the Fenix BC21R is powered by one standard 18650 rechargeable battery or two non-rechargeable CR123 battery, you can easily dismount the light, change the batteries, then continue on those long rights. This well-designed bike light goes anywhere for any activity. Perfect for road racing, bicycle riding, and urban commuting.
Free shipping coupon code of GearVita: FNBC21RBL
Coupon price: $71.99
Coupon time: July 20 - July 31
Product link: https://gearvita.com/fenix-bc21r-led-bike-light-880lm.html
Product Features:
● Uses one Cree XM-L2 T6 neutral white LED with better color rendition.
● Powered by one 18650 rechargeable Li-ion battery or two CR123A Lithium batteries.
● Optimized Dual Distance Beam System.
● Micro USB direct charging.
● Built-in over-charge, over-discharge protection.
● Battery Level Indication.
● Low power warning reminds when battery replacement needed.
● Over-heat protection to avoid high temperature of the surface.
● New-type quick-release bike mount for easy and secure adjustment of the lighting direction.
● Four brightness levels and one flashing mode.
● Made of aluminum alloy with excellent heat dissipation design.
● Waterproof to IPX-6 standard.
The Fenix BC30 Bike Light includes a maximum of 1800 lumens and a maximum runtime of 20 hours. The Cree XM-L2 neutral white LED's on the Fenix BC30 produce a maximum beam distance of 557 feet when on the 1800 lumen burst mode. The remote pressure switch included will quickly and easily access the burst mode. The Fenix BC30 runs off either two 18650 batteries or another option would be four CR123A batteries.
$10 discount and free shipping coupon code of GearVita: FNBC30BL
Coupon price: $85.99
Product link: https://gearvita.com/fenix-bc30-led-bike-light-1800lm.html
Product Features:
● Utilizes two Cree XM-L2 T6 neutral white LEDs, max 1800-lumen output.
● Instant burst activation with the remote pressure switch.
● dual distance beam system.
● 4 brightness levels plus warning mode.
● Digitally regulated output – maintains constant brightness.
● Quick attach and detach handlebar mount sized for.
● 22mm-35mm handlebars.
● Easy, secure adjustment of the lighting direction.
● Made of aluminum alloy and quality plastic.
Related products:
The Olight M2T Warrior flashlight, based off the groundbreaking M2R model is a dual switch LED tactical flashlight equipped with an XHP35 HD CW LED powered by a single 18650 or two CR123A delivering an output range of 1 to 1,200 lumens. This light features a silent and compact tail switch for easy operation. Users can have momentary ON, ON/OFF switching, and momentary strobe all through pressing the tail switch using different pressure. The side switch features a similar operation as the extremely popular OLIGHT S series flashlights for standard carry. With a lanyard hole, dual direction pocket clip, and holster, the M2T Warrior is the perfect light for anyone looking for an easy to operate and high quality tactical flashlight.
$8 discount coupon code of GearVita: OLTM2TW
Coupon price: $59.88
Coupon time: July 23 - July 31
Product link: https://gearvita.com/olight-m2t-warrior-tactical-led-flashlight-1200lumen.html
Product Features:
● Hard anodized aluminum body is impact and water resistant.
● Ergonomic knurling provides secure grip even while wearing gloves.
● Orange peel textured reflector ensures even beam spread.
● Crenulated bezel can be used to break glass or for self defense.
● Dual switch interface for multiple operation methods.
- Tailcap Switch - Used to turn light ON/OFF. Allows for momentary on and momentary strobe.
- Side Switch - Used to switch between all 6 outputs. Doubles as a low power indicator.
● Beam dims after 3 minutes in Turbo Mode to prevent overheating.
● Rapid strobe frequency flashes 13 times per second (normal strobe only does 10).
● Lock out function helps prevent accidental activation.
● CE and RoHS Certified.
Related products:
https://gearvita.com/nitecore-srt9-smartring-tactical-led-flashlight-xhp50-2150lm.html
https://gearvita.com/yage-battery-lead-linternas-torches-tactical-cree-flashlight.html
The Olight I3T EOS flashlight is a slim tail switch flashlight powered by a single AAA battery with a max output of 180 lumens. It is equipped with an excellent LED paired with a TIR optic lens producing a soft and balanced beam. It is also equipped with a dual direction pocket clip for multiple carrying options such as a pocket or backpack strap. It is really an incredibly convenient illumination experience to take with you everywhere.
Product Features:
● Powered by a convenient and widely available single AAA battery producing an output of 180 lumens
● The I3T is equipped with a TIR optic lens producing a soft and balanced beam for comfortable use.
● Highly integrated tail switch: The user can operate momentary on and quick mode shifting (5/180 lumens) all through a convenient tail switch.
● Super easy carry: Barely know it is there with its lightweight and slender form factor. The dual direction pocket clip makes the I3T even more convenient for carrying in a pocket or attaching to a hat or strap.
● Double helix body knurling for unique style and solid grip.
Buy it on GearVita now: https://gearvita.com/olight-i3t-eos-180-lumens-flashlight.html
The Olight M1T Raider flashlight has unique body knurling. Dense double helix knurling pattern combines functionality and style. Premium beam quality. TIR optic produces a soft and balanced beam which is great for reading on low mode or any close-range illumination at night. Comfortable tail switch. Features an auxiliary spring hidden under the switch making operations smooth and crisp. Control the mode changing (5/500 lumens), momentary-on and constant ON/OFF all through single clicking this tail switch. Super convenient carrying. With a length no longer than the width of an adult palm, the concealed profile is perfect for backup duty. It comes with a dual direction pocket clip and lanyard for multiple carrying options, i.e. attach to pocket, backpack or belt.
Product Features:
● Compact Body for EDC
Did someone say everyday carry? The Olight M1T Raider is an EDC flashlight dream come true with its compact, 3.58" long body and ultra lightweight (1.76 oz without battery!) body. A cool white, Luminus SST40 LED enables a 500 lumen max output for searching, inspecting and illuminating tasks. Featuring dense double helix knurling along the body, the palm-sized flashlight is easy to hold and operate with or without gloves on.
● Tactical Style Tail Cap Controls
A single control button located on the tail cap of the M1T provides access to everything you need: ON/OFF, momentary output and mode switching. The M1T offers two modes for task-specific lighting. Choose Mode 1 for a 500 lumen beam when you need a lot of light or switch to Mode 2 for a 5 lumen beam ideal for up close tasks and night reading.
● Includes Everything You Need
To power the M1T, you'll need 1x CR123A battery (included) or 1x RCR123A battery for a rechargeable option. A full charge gives you up to 125 minutes of runtime on Mode 1 and up to 100 hours on Mode 2! The M1T also comes with everything you need to securely carry the flashlight including a lanyard and dual-direction pocket clip.
Check it on GearVita: https://gearvita.com/olight-m1t-raider-compact-edc-flashlight-500-lumen.html
Related product:
The Olight I1R EOS flashlight is a tiny rechargeable LED keychain flashlight with dual output settings ranging from 5 to 130 lumens. It weighs only 12g and has an extraordinarily compact size. The I1R is built from strong aluminum alloy and features a built-in rechargeable Li-ion battery that charges through a Micro-USB port when the light head is unscrewed and removed. It features a high-performance Philips LUXEON TX LED paired with a TIR optic lens producing a soft and balanced beam. Changing outputs (5/130 lumens) is simple just by twisting the light head. The I1R EOS is the perfect daily carry keychain flashlight with high output, convenient charging, and easy mode changing.
Product Features:
● Lightweight and Tiny. The entire light is slimmer than a pinky finger with the length shorter than a AAA battery and weight at only 0.42 oz/12g.
● Features a high-performance Philips LUXEON TX LED paired with a TIR optic lens producing a soft and balanced beam.
● Rechargeable through a built-in Micro-USB charging port. Fully charged within 1 hour and 15 minutes.
● ON/OFF and output changes are controlled through twisting the flashlight head. Twist it slightly to turn it on at 5 lumens and a bit further for 130 lumens.
The Olight I1R EOS is probably the smallest flashlight that Olight has ever produced for the I Series (keychain). It is really tiny and portable, it can just hang on your keychain or pocket without taking up any space when you don't use it. Its ease of operation is also a advantage, all twisty activation of the light can be easily done with one hand. This keychain flashlight can bring you a lot of convenience when you walk alone in the night, buy this cheap flashlight on GearVita to illuminate your night road: https://gearvita.com/olight-i1r-eos-led-keychain-flashlight-130-lumens-rechargeable.html
Related products:
https://gearvita.com/nitecore-tip-ss-stainless-steel-metallic-keychain-flashlight-360lm.html
https://gearvita.com/nitecore-tini-rechargeable-led-keychain-flashlight-380-lumen.html
A fistful of light - the all-new Acebeam K30 flashlight delivers an unprecedented blast of light from a package smaller than a regular energy drink! The latest CREE XHP70.2 LED pumps out a broad 5,200 lumen beam, ideally suited to security, adventure and emergency use. The proven single-button interface provides intuitive one-handed operation with instant access to all the major functions - even from the "off" position! Powered by three 18650 lithium-ion rechargeable batteries sealed into a waterproof and impact resistant body, the K30 means you'll always have daylight in your grasp.
$5 discount and free shipping coupon code of GearVita: ABK30F
Coupon price: $106.78
Coupon time: July 27 - Aug 6
Product link: https://gearvita.com/acebeam-k30-led-flashlight-5200lumens.html
Product Features:
● A CREE XHP 70.2 LED, maximum output of 5200lumens.
● Single-button side switch cycles through all the major functions even from the "off" position.
● Lock-out function to prevent accidental activation.
● Powered by three high capacity 18650 rechargeable lithium batteries with protection board.
● Sealed into a waterproof and impact resistant body.
● Stainless steel bezel provides protection from drops.
● Aircraft-grade aluminum body with anti-scratch type III hard anodizing.
● The K30 is the most durable flashlight yet produced by Acebeam, capable of surviving accidental immersion to extreme depths of up to 10metres! However it is not a diving light, and should not be turned on or off underwater.
● Strobe mode is for tactical and emergency use.
● Highly focused beam for maximum distance.
● Streamlined body design.
● Intelligent highly efficient circuit board design for max performance and long runtime.
● Ultra-clear tempered glass lens with anti-reflective coating,which achieves a 98.3% light transmittance.
Related products:
https://gearvita.com/acebeam-ec65-4000lm-rechargeable-flashlight.html
https://gearvita.com/acebeam-x80-gt-rechargeable-flashlight-32500-lumens.html
Acebeam UC15 flashlight is Acebeam's new keychain light, look cute and come in a range of colours, it is a serious tool from the makers of some of the brightest and best-made flashlights in the world. On the "high" setting the UC15 delivers a healthy 250 lumens using two AAA batteries, or an awe-inspiring 1000 lumens from two rechargeable 10440 lithium ion cells. Coupled with an 107-metre throw from the latest Cree XP-L or Nichia LEDs this is more than enough to read a street sign or light up a front yard. Better yet, the UC15 provides a "mid" setting of 82 lumens (200 lumens with lithium ion cells) and a "low" of 10 lumens, which is enough to read a map or find your way to the bathroom, and it can maintain this output throughout the longest night! Simple and intuitive operation, a low-battery-warning indicator, IP54 sealing and rubber switch and keyring connectors combine to make this the gift that keeps giving - for yourself or anyone else!
Product Features:
● With 10440 Li-ion batteries: 10/200/1000 lumens
● With AAA alkaline batteries: 10/82/250 lumens
● Runtime: 47 minutes - 19 hours (10440), 1.1 - 14 hours (AAA)
● Cree XP-L2 high-density white LED
● Cree XPE-R2 630nm red LED
● Nichia 276A 365nm UV LED
● Anti-reflective coated glass
● Battery level indicator
● Aluminum housing with Type III hard anodized finish
● IP54-rated, dust and spray resistant
● Clip for pocket or cap brim
● Stainless-steel key ring loop
Pick one up in your choice of 4 colors with the price of $47.88 on GearVita link below:
https://gearvita.com/acebeam-uc15-keychain-light-1000-lumen.html
Related products:
https://gearvita.com/nitecore-tube-usb-rechargeable-led-keychain-flashlight-45lm.html
The Wuben TO40R flashlight is a USB rechargeable outdoor series flashlight used best in camping, outdoor activities, and security. It projects a bright focused spot beam, it's lightweight and compact with a max output of 1 200 lumen and a maximum beam distance of 220 meters.
● Easy to Carry Outdoor Flashlight
The WUBEN TO40R Flashlight is a portable LED outdoor flashlight equipped with an CREE XPL2 LED powered by 1*18650 rechargeable Li-ion battery delivering an output range of 1 to 1,200 lumens.
● Quick Access to Turbo and Strobe, 5 Brightness Mode
When flashlight on, long press W switch one second flashlight will be in Strobe. Long press 3 seconds for SOS, single click to return to last used normal mode. The brightness mode from Moon-Low-Med-High-Turbo. It has memory function.
● Robust Body Construction
High-strength aerospace aluminum body; Aluminum alloy vacuum plating smooth reflective cup; Mil-Spec hard-anodized for extreme durability.
● Advanced Temperature Regulation
(ATR) technology; Thermoelectric separation copper substrate for better heat dissipation, with the digitally regulated output, the brightness stays constant.
● Enhanced Comfortable User Experience
Screwing the tail cap on or off is even easier due to increased friction of the tail cap knurling. Slim head design, detachable pocket clip for both carry directions, and lanyard hole for an enhanced and comfortable user experience.
● Easy Operate and High Quality
The TO40R is the perfect light for anyone looking for an easy to operate and high quality flashlight. Fit in any outdoor and indoor activity.
Brightness Mode:
● Turbo: 1200Lumens - 1.7h
● High: 600 Lumens - 3.5h
● Med: 200 Lumens - 7h
● Low: 40 Lumens - 56h
● Moon : 8 Lumens - 125h
Product Features:
● Utilizes CREE XPL2 LED with 100,000 hours lifespan,
● Powered by 1*18650 rechargeable Li-ion battery
● Max output up to 1200 Lumens
● Max beam distance up to 220 meters
● Max runtime up to 125 hours
● Micro-USB charging
● Dual Side e-switch lockout function, more convenient for using
● One press to Turbo and Strobe
● Remaining battery power display
● Aluminum alloy vacuum plating smooth reflective cup
● Thermoelectric separation copper substrate for better heat dissipation
● Advanced temperature regulation (ATR) technology
● Reverse polarity protection to protect from improper battery insertion
● High-strength aerospace aluminum body
● Mil-Spec hard-anodized for extreme durability
● Impact resistance 1.5 meters
● Waterproof level IPX8
Wuben TO40R is a portable flashlight special for outdoor activity, bring it, you no longer have to worry about your night travel. Check the details on GearVita:
https://gearvita.com/wuben-to40r-led-flashlight-1200-lumens.html
Related products:
https://gearvita.com/convoy-s3-xm-l2-led-flashlight.html
Wuben TO46R flashlight is a multi-function flashlight for outdoor shooting and outdoor sports. Equipped with 3* CREE XPG-S3 LED, high CRI, realistic restore color. Max output up to 1300 Lumens and a max beam distance of 135 metres. Press the switch on both sides, easy to achieve a very bright and a key burst flash. Power supply part of a 18650 battery with built-in charging design, the use of more convenient.
$5 discount and free shipping coupon code of GearVita: WBTO46R
Coupon price: $44.99
Coupon time: Aug 1 - Aug 9
Product link: https://gearvita.com/wuben-to46r-led-flashlight-1300-lumens.html
Product Features:
● Wuben Advantage
Wuben focuses on R & D of tactical flashlight for 36 years, serving global users 100million +, under the ANSI World standard, recognized by the military industry with excellent feedback!
● High Light
Uses 3 * CREE XP-G3 High 90CRI LED. Powered by 1 * 18650 rechargeable Li-ion battery, Micro-USB charging. LED XP-G3 High color, Color fidelity reduction. As used for the night light of night photography
● 5 Light Modes
Wuben T046R Tactical Lamp with 5 modes-Bright (1300 lumen) -High brightness (604LM) -Means (200LM) -Bas (38LM) -Lune (7LM). Maximum power up to 1300 Lumens, maximum beam distance up to 135 meters, maximum life up to 125 hours
● Balanced Heat Dissipation
Lateral Double Latch Lock Function, Turbo and Strobe Pressure, Remaining Battery Power Display, Ultra-Clear Carclo Optics Creates a Smooth and Optimized Bundle, a Separate Thermoelectric Copper Substrate for better heat dissipation.
● Lamp IPX8 Waterproof
Waterproof torch light with IPX8 can be used in rain and up to 2 meters underwater. Shock resistance 1.5 meters Level. Perfect for your outdoor outings such as fishing, camping, exploring, hiking, and also ideal for home use.
Related products:
https://gearvita.com/wuben-a21-portable-led-flashlight-4200lumens.html
The Nitecore EC23 Flashlight is a high performance compact flashlight utilizing a CREE XHP35 HD E2 LED to emit a scorching 1800 lumen output. One of the brightest flashlights of its size, the lightweight and compact EC23 can be easily stored in pockets, packs or bags for quick access to light anywhere you go. Powered by a single IMR 18650 battery, the EC23 has a max runtime of 330 hours and a max beam intensity of 16,200 making it perfect for outdoor use and everyday carry.
An innovative all-in-one control switch located on the side of the flashlight allows easy one-handed operation of five brightness levels and three special modes. The addition of a tailstand provides the ability to light up an area and frees up hands for working or maneuvering. A combination of features such as Advanced Temperature Regulation which regulates output and adapts to the ambient environment and an IPX8 rating ensure the EC23 is a premium EDC flashlight for all-weather applications.
$5 discount and free shipping coupon code of GearVita: NTEC23F
Coupon price: $47.99
Coupon time: Aug 2 - Aug 20
Product link: https://gearvita.com/nitecore-ec23-high-performance-led-flashlight-1800lumens.html
Product Features:
● Utilizes a CREE XHP35 HD E2 LED.
● Maximum output of up to 1800 lumens.
● Integrated "Precision Digital Optics Technology" provides extreme reflector performance.
● Boasts a peak beam intensity of 16200cd and a throw distance of up to 255 meters.
● Innovative single button offers access to 5 brightness level and 3 modes.
● High efficiency constant current circuit board provides max running time of 330h.
● Integrated power indicator light displays remaining battery power and voltage.
● Reverse polarity protection prevents damage from incorrectly inserted batteries.
● Optics lens with anti-reflective coating.
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish.
● Waterproof in accordance to IPX-8 ( two meters submersible ) and impact resistant to 1.5 meters.
● Tail stand capability.
Related products:
https://gearvita.com/fenix-uc35-v2-0-usb-rechargeable-flashlight-1000-lumens.html
https://gearvita.com/nitecore-mh23-1800lm-rechargeable-flashlight.html
The Klarus XT1A flashlight is back and is better than ever! This handheld lighting tool was originally available as a 1xAA light with a maximum output of 180 lumens. The new-and-improved Klarus XT1A has been rejuvenated and redesigned to deliver an even brighter output of 1000 lumens. This compact EDC flashlight is now compatible with the more powerful Li-ion 14500 battery and also includes the latest in develop of High Definition Cree LEDs with the XP-L lamp. Put these two features together to create a 1000-lumen flashlight that is small enough to carry with you everywhere, yet powerful enough to illuminate your campsite with ease.
$3 discount and free shipping coupon code of GearVita: KRXT1AF
Coupon price: $43.88
Coupon time: Aug 6 - Aug 16
Product link: https://gearvita.com/klarus-xt1a-tactical-led-flashlight-1000-lumens.html
Product Features:
● Tactical EDC flashlight, compact and lightweight.
● CREE XP-L HD V6 LED, with optimized design high efficiency drive circuit. Max output up to 1000 lumens, exceeding the current industry standard.
● Easy interface: One Touch Strobe, One Touch Turbo, One Touch Low, SOS.
● Includes Intelligent Battery Capacity Indicator, Thermal Protection System, and Quick Settings Switch.
● Patented Tactical Tail-cap Dual-Switch Control; non-visual tactile one-handed operation with intuitive control for low-light operation.
● 14500 Li-ion battery with Micro-USB port included, easy and fast charging. XT1A is compatible with all AA batteries.
● Two interfaces: Tactical Setting; Outdoor Setting.
Related products:
Klarus XT12GT flashlight, one of the the Klarus's XT series flashlights, has been developed with tactical use and self-defense in mind, is a precision-engineered illumination tool. Featuring 1600Lm impressive output and 603m exceptionally long-range throw, it is one of the most powerful tactical lights on the market today! Additionally, the XT12GT employs an innovative magnetic charging connector, which doubles as charging connector and keychain light. The patented dual tail switch design gives you full control over the light, allowing fast mode change - instant access to Turbo, Low, Strobe or SOS from any mode. This makes it an incredibly effective tactical torch for daily and emergency use.
$10 discount and free shipping coupon code of GearVita: KRXT12GT
Coupon price: $79.99
Coupon time: Aug 7 - Aug 16
Product link: https://gearvita.com/klarus-xt12gt-rechargeable-tactical-led-flashlight-1600-lumens.html
Product Features:
● Body crafted from aircraft-grade aluminium alloy with hard-anodised finish.
● Toughened ultra-clear mineral glass lens with anti-corrosion coating.
● Stainless steel strike bezel used to break glass, as a self defense tool.
● Dual tactical switch interface can be operated using just one hand.
▹ Primary switch: used to turn the light ON/OFF. While light is OFF, can be lightly pressed to temporarily access Turbo mode.
▹ Mode switch: While light is ON, used to cycle through outputs. While light is OFF, used to temporarily access either Low mode or Strobe mode.
● Features a pair of programmable settings for multi-purpose use.
▹ Tactical setting - access to Turbo, High, and Low modes, temporary access to Strobe mode.
▹ Outdoor setting - access to Turbo, High, Medium, Low, and S.O.S. modes, temporary access to Low mode.
● Can be recharged internally using the one-of-a-kind magnetic charging connector.
▹ Plug micro-USB cord into connector and attach connector to light's magnetic. charging surface to charge the light (only when equipped with a 18650 battery).
▹ Connector also functions as a 10 Lumen keylight.
● LED power indicator ring around charging surface displays battery's remaining charge.
● ITS temperature control and heat-dissipating fins help prevent overheating.
● Springs at bezel and tail help prevent damage from impacts, drops.
Related products:
Feast your eyes on the Klarus XT11X flashlight, the world's brightest single 18650 light on the market today! This monster torch measures just 6 inches long and weighs less than half a pound, making it an easy carry for law enforcement, search and rescue, or even everyday users. Despite its incredibly average size, the flashlight's power is anything but average, able to output a ridiculous 3200 Lumens of brightness that can throw further than 300 yards! Such power is typically unheard of in such a compact light, but thanks to its powerful IMR 18650 power source (included) and it's efficient circuitry, thew XT11X is able to outshine all its competitors!
The XT11X does only wield immense power, it also sports one of the most innovative and user-friendly interfaces of any tactical torch. The flashlight is designed with two different methods of operation; a simple side switch better suited for normal everyday applications and a dual tailcap switch tailored for more tactical operations. Both methods of operations grant access to all of the flashlight's output modes, including its blinding strobe function and its efficient S.O.S. mode for emergency situations. The XT11X is able to grant instant access to both Strobe Mode and Low Mode and even allows for momentary activation for brief bursts of light.
The intelligent interface isn't the only feature that makes the XT11X user-friendly. The practical light is designed with a handy micro-USB charging port that can be used to recharge the included IMR 18650 internally, so there is no need for a separate designated charger! Charging progress can be easily monitored thanks to the multi-color LED indicator built right into the torch's side switch, glowing red while charging and green once charging is complete. The LED indicator can even be used to check up on the XT11X's remaining charge while in use so you're never blindsided by a dead battery!
$10 discount and free shipping coupon code of GearVita: KRXT11X
Coupon price: $78.68
Coupon time: Aug 8 - Aug 17
Product link: https://gearvita.com/klarus-xt11x-rechargeable-led-flashlight-3200-lumens.html
Main Parameters:
LED: CREE XHP70.2 P2 LED, lifetime up to 50,000 hours
Compatible Batteries: 1 x 18650 or 2 x CR123A or 2 x Klarus 16340.
Reflector: Orange Peel
Lens: Hardened mineral glass, AR coated, scratch resistant
Switch: Tactical tailcap dual-switch + side switch
Dimensions:
Head - 41.0mm (1.61”) diameter
Body - 25.4mm (1.00”) diameter
Length - 150.8mm (5.94”)
Brightness Outputs (using included IMR 18650*):
Turbo - 3200 lumens / 45 minutes
High - 400 lumens / 4 hours
Medium - 100 lumens / 16 hours
Low - 15 lumens / 82 hours
Strobe - 3200 lumens / 1 hour 30 min
S.O.S. - 100 lumens / 48 hours
Product Features:
● CREE XHP70.2 P2 LED with max output up to 3200 lumens (with included 18650 battery), far exceeds the competition.
● Easy Interface: one touch Strobe, one touch Turbo, one touch Low, mode memory function, SOS, switch lock-out function, quick settings switch.
● Multiple Safety Systems: Intelligent Thermal Protection System (ITS), Intelligent Battery Identification System (IBIS), Intelligent Charging System (ICS).
● Patented tail cap dual-switch and side switch design, adaptable for different scenarios, easy to use.
● Patented tactical tailcap dual-switch control; non-visual tactile one-handed operation in the dark with intuitive control.
● Two Interfaces: tactical setting and outdoor setting.
▹ Tactical Setting: specially designed for self-defense and tactical use. Classic KLARUS XT series control interface, one touch Strobe, one touch Turbo, perfect candidate for any mission.
▹ Outdoor Setting: designed with the wilderness in mind. One touch Low, one touch Turbo, multiple output levels with memory, SOS function, suitable for all needs in hunting, hiking, camping or search and rescue.
● Intelligent Thermal Protection System (ITS): monitors and auto-adjusts output levels in real-time in order to keep crucial components safe for the optimal balance of performance and safety.
● Intelligent Battery Identification System (IBIS): adjusts the output according to the currently installed 18650 battery discharge rate, compatible with 18650 Li-ion batteries, CR123A batteries and Klarus 16340 batteries.
● Intelligent Charging System (ICS): micro-USB charging port with real-time monitoring of charging status to prevent overcharging, limits max charging current to 1A to avoid damage to charging devices.
● Unique lock-out mode of both side and tail switch prevents accidental activation, this stops battery drain during storage or travel and avoids eye injuries.
● Springs at bezel and tail end resist shock and drop damage.
● Reverse Polarity Protection eliminates damage from incorrect battery orientation.
● Aero-space aluminum alloy body with CNC machining, Mil-spec hard anodizing (HA III), lightweight yet robust construction.
● Stainless bezel ring offers protection from impact.
● One-piece integrated head bezel design for high efficiency heat dissipation.
● Hardened glass lens with scratch resistant AR coating.
The Klarus XT11X flashlight is an impressive tactical flashlight that delivers 3200 lumens of amazing power. It’s designed with versatility and is packed to the brim with features so you can have the flashlight that you need at any given time. It features a side switch and dual tail switches that function independently allowing you to choose how you’d like to operate the flashlight. With the six total outputs including a strobe and an SOS mode, you’re ready for any situation. The two programmable settings are the Tactical Setting and the Outdoor Setting. Both are excellent and you can switch between them at any time or pick your favorite and leave the flashlight in that setting. Whether you’re a flashlight enthusiast, in law enforcement or security, or an outdoor enthusiast, you can’t go wrong with the Klarus XT11X.
Related products:
The Manker U22 flashlight is the latest flashlight from Manker, continuing the U21 model launched in spring 2016. Manker brings some improvements to the new flashlight. The Manker U22 uses the Cree XHP35 HI LED, which has two color temperatures: 5000 and 6500K. The flashlight has a maximum power of 1500 lumens, and at 65,000 cd, the illumination distance easily exceeds 500 meters. The flashlight reflector is one of the lustrous aluminum alloys, so the beam is concentrated and the halo around the spot reaches a maximum of 100 meters. The base of the base contains four heat sinks for optimal cooling, with control buttons between the heat sinks on one side and a charging plug on the other. The control buttons illuminate and we can turn on/off or change the steps and modes of the lantern through various push modes. During operation, the button will change color based on battery level.
The lantern charging plug is USB Type-C, and can be charged from different devices: 5V minimum 1Ah adapter, portable charger, computer, car adapter. Charging the battery from the flashlight is at 1.4Ah when using a 2Ah adapter. The battery with which the flashlight can work is a new one, its type being 21700, and the battery power reaches 4800mAh. Due to the high power, the torch has a very good autonomy on every stage: in turbo mode at 1,500 lumens, the torch will work for 4 linear minutes, after which it will continue to operate at 630 linear lumens over three hours. The dimensions of the Macker U22 are much lower than the older U21 version, hence the lower and lower beats of the new U22. The torch's weight is only 254gr with the 21700 battery.
The new Manker U22 is much easier to wear in hiking, guarding / searching, or used daily around the house. In addition to generous autonomy, the U22 delivers high power and high beating distance at an affordable price.
$5 discount and free shipping coupon code of GearVita: MANKU22
Coupon price: $57.95
Coupon time: Aug 9 - Aug 17
Product link: https://gearvita.com/manker-u22-led-flashlight-1500-lumens.html
Flashlight Interface:
● To turn on the flashlight, press the button on the head, the torch will start firefighters, press the button for 2 seconds to stop.
● To change the light steps, press the button briefly until you reach the desired level, the torch will start firefighting and after the end of the cycle the flashlight will return fireflies like: firefighters - step 1 - stage 2 - high gear - stage 2 - stage1 - fireflies.
● To use the torch at the last used stage, hold the button for 2 seconds - when the torch is off. To stop, press and hold for 2 seconds, and to return to the initial step, press the button for 2 seconds.
● For direct access to Turbo mode, press the button twice quickly when the torch is off, so do whatever you want to activate Turbo mode.
● To activate special modes, quickly press the power button twice to activate turbo mode, every press on the button will change the available modes: Strobe, SOS, Flicker, Pulse Button. After flashing the button, the torch will go on the fireball.
● To set the intensity of the firefighting mode (general mode - engineer mode), in this way the engineer can set the intensity of the firefighting step by choosing from the four available options. Turn off the flashlight and hold down the button until the button lights up and then press the four-way button quickly, go through the four available options and to memorize an intensity press the lantern button a long time.
Main Parameters:
● Emitter: CREE XHP35 HI (choice of Cool White or Neutral White)
● Maximum output: 1500 lumens
● With Type-C USB charging function
● Power by 1x Manker 4800mAh 21700 rechargeable battery (battery has Included)
● Maximum beam intensity: 65000cd
● Maximum beam distance: 509meters
● Working voltage: 2.8v - 4.35v (over discharge protection)
● Driver: Most efficiency constant current circuit
● Material: Aircraft-grade aluminum body
● Surface treatment: Premium type III hard-anodized anti-abrasive finish
● Lens: Toughened ultra-clear glass lens with anti-reflective coating
● Waterproof: IPX8 (2 meter under water)
● Impact resistance: 2meters
Brightness Levels and Runtime:
● Moonlight: 1-5lm / 960h
● Low: 90lm / 25h
● Medium1: 250lm / 8.5h
● High: 630lm / 4.2h
● Turbo: 1500-630lm / 3min-4h
● Strobe: 1500lm
Related products:
https://gearvita.com/klarus-xt11x-led-rechargeable-tactical-flashlight-3200-lumens.html
Below is the picture of U22 and the comparing picture of U21 and U22:
The Manker PL21 penlight is a practical pen lamp that is always at hand thanks to the clip in the shirt or in the trouser pocket. The penlight benefits from a slim body which can get into those tight corners a larger flashlight would struggle with. It adds to this feature with three light levels, the lower of which will not blind you when you're in that tight corner searching for a contact lens! However, turn it to the higher 200 lumen output and it will light up a room.
Powered by just two AAA batteries (not supplied), with an aircraft-grade aluminium body and a runtime of 47 hours on the low setting, this is all the lighting you'll need during your working day.
It is now available for purchase on GearVita with the price of only $24.68 by using the coupon code "MANKPL21", offer lasts until 20th.
Main Parameters:
Emitter: CREE XPG3 / Nichia 219C LED
Maximum 200 lumens output
Maximum beam intensity: 1000cd
Maximum beam distance:63meters
Working voltage: 1.8 - 3.2v
Power by 2x AAA batteries (battery not included)
Driver: most efficiency constant current circuit
Surface treatment: premium type III hard-anodized anti-abrasive finish
Aerospace grade aluminium alloy construction
Waterproof: IPX-8 (2 meter under water)
Size: 133mm length x 14mm head diameter
Weight: 29g (without battery)
Low: 4lm / 47hrs
Mid: 58lm / 4.5hrs
High: 200lm / 40min
Strobe: 200lm
Product Features:
● Unique design with simple but beautiful handles, easy to use, just like a pen.
● Made of durable aircraft grade aluminum.
● Adopts CREE XPG3 LED, maximum 200 lumens output.
● Maximum light duration of 47 hours.
● Peak beam intensity 1000cd, max beam 63 meters, impact resistance 2 meters.
● Bottom switch and clip is stainless steel, strong and durable.
● Three different light modes and strobe mode.
● High-quality processing water and shock resistant.
● Driver is the most efficiency constant current circuit.
Product link: https://gearvita.com/manker-pl21-led-penlight-200-lumens.html
Manker PL21 is a light, small and powerful penlight, although the body is small that may look unremarkable, but it can provide sufficient light. With it, you won't worry about working on the vehicle or taking a walk at night because it will always illuminate your surroundings.
The Manker MK39 Ranger flashlight is one impressive chunk of aircraft-grade aluminium with premium Type III hard-anodized anti-abrasive finish. Despite its awe inspiring stature is sits very comfortably in the hand and thanks to the positioning of the handle the thumb naturally engages with the operating controls seamlessly. For long periods of use a shoulder strap is provided for easy carry.
The MK39 has a lumen output of 6000 lumens with a choice of flood or focused beam making it a very adaptable lighting tool. Search and rescue teams take note, this torch is capable of an incredible 1100 metre throw. At the touch of the button the beam will ramp up from one lumen all the way to 6000 in unnoticeable increments, allowing the user to halt the process and choose the right amount of light for the job in hand. Plus it has a strobe which can be a very handy tool in an emergency.
Runtimes vary depending on the output being used but the Manker MK39 features a automatic cut out to preserve battery life and prevent overheating during heavy use. Whilst the 6000 lumen output is chosen the torch will drop to a lower level of power after three minutes, which will ensure a longer period of usage on one battery charge.
Main Parameters:
Emitter: Emitters:
- CW: 1* Cree XHP35 HI+8* Cree XPG3
- NW: 1* Cree XHP35 HI+8* Nichia 219C
Maximum output: 6000 lumens
Maximum beam intensity: 305000CD
Maximum beam distance :1100 meters
Working voltage: 11.2V - 16.8V (over discharge protection)
Water proof: IPX-8 (2 meter under water)
Impact resistance: 1 meters
Throw mode (ramping adjustment): 1-2000lm / 48hrs - 3min + 2hrs
Flood mode (ramping adjustment): 1 - 4000lm / 48hrs - 3min +1.5hrs
Throw and Flood mode (ramping adjustment): 2 - 6000lm / 24hrs - 3min+1hrs
Strobe mode: 6000lm
Product Features:
● Made of durable aircraft grade aluminum material, the surface is treated with premium Type III hard-anodized anti-abrasive finish, lens are toughened ultra-clear glass lens with anti-reflective coating.
● Power by 4x 18650 batteries, maximum 6000 lumens output.
● Maximum light duration of 48 hours.
● Peak beam intensity 30,5000cd, max beam 1100 meters, impact resistance 1 meters.
● Four different light modes and strobe mode.
Get it with the price of $173.99 at GearVita.com by using the $25 discount and free shipping coupon code "MK39RANG" when you checkout: https://gearvita.com/manker-mk39-ranger-led-flashlight-6000-lumens.html
Related products:
Lumintop ODL20C flashlight is a throw flashlight by utilizes a Cree XHP35 HI LED and adopt the aluminum flat and deep reflector, it emits a max 2,000 lumens output and creates an 860 meters long-range throwing distance by running on a 26650 cell. Five output levels plus Strobe, SOS and Beacon modes are more fit for various lighting demands. The USB Type-C charging enables a 2A current charging current and it takes only three hours to fully charged the battery. The humanized breath lamp allows easily locate the flashlight in the dark. Lock-out function, charging indicator, low battery reminder, tail standing ability and IP68 classification protection etc. makes ODL20C indispensable in your searching, rescuing, hiking activities and so on.
Main Parameters:
Light Tint: 2A
Light Source: Cree XHP35 HI LED
ANSI/NEMA FL1: Low / Med / High / Turbo / Eco / Strobe, SOS, Beacon
Output: 100LM / 350LM / 1000LM / 2000LM / 8LM / 2000LM
Runtime: 22h 55min / 6h 5min / 2h 30min* / 2h*/9 days / /
Maximum Output: 2000 lumens
Maximum Beam Distance: 860 meters
Maximum Beam Intensity: 184,500CD
Impact Resistance: 1.5m
Waterproof: IPX-8
Low: 100LM ( 22h 55min )
Med: 350LM ( 6h 5min )
High: 1000LM ( 2h 30min* )
Turbo: 2000LM ( 2h* )
Eco: 8LM ( 9 days )
Strobe / SOS / Beacon: 2000LM
Product Features:
● Utilizes Cree XHP 35 HI LED with a lifespan of 50,000 hours.
● Powered by one 26650 rechargeable Li-ion battery.
● High-efficiency circuit with a max runtime up to 9 days.
● Smooth and deep aluminous alloy reflector creates a max 860 meters beam distance.
● 5 output levels plus Strobe, SOS and Beacon with a max output of 2000 lumens.
● Humanized breathing light inside the switch, indicates the light location in the dark.
● Durable USB Type-C charging with 2A max charging current, 3 hours to fully charged a 5000mAh Li-ion battery, fast and convenience.
● Red and blue charging indicator visually shows the charging conditions.
● One side switch operation within one hand control.
● Lock-out function prevents accidental activation.
● Enhance cooling fins ensure a comfortable holding.
● Low voltage indicator reminds to change or charge the battery in time.
● Flat tail cap with tail standing ability to serve as a candle.
● Toughened and ultra-clear glass lens with anti-reflective coating.
● Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface.
● Waterproof to IPX-8 standard, 2 meters underwater (ensure the waterproof cover is in sealed condition).
Get it with the price of $61.99 on GearVita by using the $8 discount coupon code "LTODL20C" when you checkout: https://gearvita.com/lumintop-odl20c-rechargeable-flashlight-2000lumens.html
Related products:
If you're going to be carrying a flashlight everyday, you'd better make sure that it's got all of the best features available. Fortunately the Sunwayman C23C flashlight is jam packed with the best LED flashlight technology available, equipped with a CREE XM-L2 U2 LED that allows it to emit a stunning 1000 Lumens of bright white light. With a polished smooth reflector in a slim styled housing, this flashlight is capable of throwing a beam up to 203 Meters, crushing similarly sized competitors. Available in black and natural color bodies, the C23C is a perfect choice for as a light for work, home or emergency situations.
You don't have time to waste taking batteries in and out of your vital electronics, and the folks at Sunwayman recognize just how valuable your time is. With that in mind the C23C has been made capable of charging your 18650 battery right inside the light and without any fuss. The intelligent charging system detects the voltage and capacity of your individual battery and provides rapid yet safe charging. An integrated indicator lamp located under the side switch gives a clear visual cue for when the battery is charging and fully charged.
If you thought that Sunwayman was going to make a light that didn't integrate the very best construction features known to LED flashlight, you thought wrong. The C23C is constructed from high-quality aerospace-grade aluminum that is both lightweight and durable, capable of withstanding any sort of everyday bump or drop you can throw at it. A stainless steel retaining ring holds the tempered glass lens in place which protects solid state LED technology that is virtually shock proof. Additionally this light is rated IPX-6 Waterproof and is ready for use in any sort of weather condition.
Offering 1000 Lumen output in a compact body, the Sunwayman C23C is the latest in Sunwayman's line of rechargeable EDC LED flashlights. This light allows for internal recharging of 18650 batteries utilizing a micro-USB cord, a quick and easy way to power up your every day carry. Available in either black or natural coloring, this light makes a great companion for workers, emergency responders or just every day home use.
Main Parameters:
Light Source: CREE XM-L2 U2
Output Modes: Turbo, High, Mid, Low, Moon + SOS, Aviation Signal, Strobe
Maximum Output: 1000 lumens
Max Throw Distance: 208m
Impact Resistant: 2 meters
Waterproof: IPX-6
Product Features:
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours.
● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode:
- Turbo (1000 lumens, automatically lowers to High after 3 mins continuous use)
- High (580 lumens, 2 hrs )
- Mid (130 lumens, 10 hrs )
- Low (40 lumens, 35 hrs )
- Strobe, SOS, Aviation Signal
● USB charging interface, can be charged by laptop, charger baby or direct power supply.
● Constant current circuit, constant output.
● Effective range of 208 meters.
● Uses one single 18650 or two CR123A batteries.
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern.
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top.
● Military Specification Type III- hard anodized body.
● Waterproof, in accordance with IPX-6 standard .
● Ultra-clear tempered glass lens resists scratches and impacts.
Available in black and silver color at GearVita.com, Sunwayman C23C makes a great companion for workers, emergency responders or just every day home use. Using the coupon code "SWMC23C" before 27th, spend $52.88, you can bring it home to accompany you: https://gearvita.com/sunwayman-c23c-multi-functional-flashlight-1000-lumens.html
Related products:
