Meh pointless 3000 lumens for how long 10 seconds? I measured my Nitecore HC33 at 2200 lumens and that steps down straight away. This light looks the same as the HC33 might be the same body?
It is what it is, a body this size can only handle so much power continuously, everything higher will need a stepdown. I like the option of a short burst of wow in a flashlight, as long as the lower continuous modes are easy to find and the user interface is good.
I’m very interested, would love a headlamp with xhp 70.2, even if I never used the turbo mode. But one thing I appreciate about Thrunite flashlights is the removable bezel, for easy emitter swaps. This one looks like a press fit, curious if it can be opened up.
That does seem heavy compared to a skilhunt H03 which quotes 44g without battery, but I remember there being some inconsistency with how thrunite quotes headlamp weights. I think the quoted 123g might be including the head strap assembly.
I really want to see some test on this one. I’ve been using the Acebeam H15 for my indoor inspection work and it’s bright and great for photography given it’s very wide floody beam. However, it does get very hot and the battery doesn’t last very long at all. The annoying low voltage blinks occur too soon for extended use.
Some companies quote weight with headstrap (nitecore HC50, thrunite TH20) and others without headstrap (H03). And the strap can weigh between 20 and 50g depending on style. So we really can’t discuss the quoted weights without clarifying.
IMO it’s just the flashlight weight that’s important because the strap weight is distributed around your head and won’t contribute to the light flopping around.
At some point you need to draw the line. It’s more of a pissing contest now, who’s got the bigger numbers. I understand lumens sell that’s why they sell and make lights like this.
How long could you possibly use all 3350 lumens maybe 10-20 seconds if even that before dramatic stepdown? Is it really worth it? It’s more of a bragging right at this point?
Personally as a headlamp user it doesn’t sell me a headlamp.
I don’t even bother to use the turbo setting in my HC33. If it’s a cold day you can run the HC33 at turbo and it just manages to do 30 seconds before going below 1800 lumens. On a hot day good luck. This light looks like same body but with almost twice the power.
Not a stab at Thrunite. Yes I would build a light like this but I would not place it on my head or sell it to an everyday consumer.
I respectfully disagree, for three reasons. First, the 70.2 is produces more lumens per watt than most other emitters, so you’ll get more efficiency at every level, except perhaps firefly/moonlight. Second, the floody beam of the 70.2 in a small reflector is perfect for a headlamp. Third, I frequently use the turbo mode in my ArmyTek Wizard xhp50, for example, when doing snow removal in the dark. We only get about eight or nine hours of daylight during our long winters here in Minnesota. Not sure if Thrunite’s thermal stepdown is time or temperature-based, however.
