The 3500k LH351D at least from what I’ve seen online is practically a grail LED for me, with 4000k not far behind. I’d love to see the LH351D in 4000k make the cut. :smiley:
I’ll update the list later.
I’m on my mobile phone and to upgrade I need the Computer
Primary Interest List, (main): See Post # 4, Page 1 .
pepinfaxera: Interest List: See #Post , Page 111
1466 - # Post . MascaratumB
1467 - # Post . RandyC
1468 - # Post . RandyC
1469 - # Post . coban
1470 - # Post . coban
1471 - # Post . eas
1472 - # Post . Delta_V
. New requests:
pepinfaxera list updated to: 1742 : Delta_V
1473 - # Post . nsk1979
1474 - # Post . derivepower
1475 -
1476 -
1477 -
1478 -
1479 -
1480 -
600 - Post # 1293 . chinooker
Hi!
I would like to get on the list for 2 units. What a beautiful little light!
Thanks,
Randy
Hello, I've been following the development of this light for a long time--finally signed up.
Please put me down for 2.
Thanks!
Please put me down for a second light.
Put me down for one.
Been following this project for a while, and seems like a more practical D4 (fewer accidental activations due to the tail switch), and I want something with the LH351D.
Amen, great job!!! Thank you…… :beer:
Thank you, but I’m afraid there are some mistakes.
I’ve been checking from the beginning,
I don’t know if I will before the group buyout closes.
If it happens, I’ll be sorry for those who applied and are not on the list.
Greetings.
because i am a dum dum, could you please briefly explain, like im a twelve year old,
the difference in everyday use between these two optuons?
thanks.
Between the two proposed emitter options, you mean?
  • XP-L HI 3D: Throwier/narrower beam, “daylight” color
  • LH351D 4000K: Floodier/wider beam, halfway between “daylight” and “warm white” color
I meant to update the list before leaving for my trip, but I ran out of time. However, when I return, I plan to check everything since my previous update… which will probably catch any errors if there are any.
Your welcome. Don’t worry… you are doing a fantastic job. If someone asked and did not check to make sure they were on the list… that is their fault. You have asked them to do this.
Just keep up the good work. :slight_smile:
The XPL HI has a narrower beam with worse vividness / color accuracy and a tint much like the average ‘daylight white’ led you may have seen. It also costs 20% more - up to $36 from $30. The LH351D has a wider beam with very good color quality and a warmer tint than the other. Still closer in tint to most daylight leds than it is to an incandescent or many ‘warm white’ leds.
You forgot to mention that the XPL HI’s beam, while narrower is also much more intense. The beam with XPL HI will throw further (illuminate things at a distance better).
Good point Firelight2. :+1:
This light is also speced to use a Carclo Narrow Spot Frosted TIR (10511) Optic, .
So, as has been mentioned before: While the polls #1 choice, the XP-L HI; may well “throw” a bit further…. it is far from a ‘thrower’ as used in this light.
Looking forward to it.
From post #1
Optics
Hello!
Please, add me for 1 light! Thanks in advance!
My fingers are crossed for the 4000K Samsung as an available option!
See Post # 2083 , Looks like he only ordered one unit, (A flashlight)
I asked Minocc via PM (personal message).
Doubt resolved
Sorry for the inconvenience.
Me too!
