On this I have no idea. I would assume it would read normally. Some DMM just don’t read amperage accurately due to resistance in the leads and connectors. I always use a clamp style ammeter.
It means with the center of the hotspot of the beam centered directly onto the light collector (the sensor thingy) of the meter at the requested 10 meters.
No, that’s not such a good idea. The very center of the hot spot can sometimes be the dimmest area. Look at this pic of my L6 and you can see the center is definitely dimmer.
The GT at 10 meters might be a different story, but I would still move the sensor around to find the brightest part of the hot spot.
Yea, of course. I set the meter on “max hold” or whatever the setting is, and move the beam around the sensor. when I’m done, I can walk over and see what I did.
Is there anybody who still hasn’t managed to get their GT opened using the strap wrenches? I’ve used the rubber and the nylon strap ones but it always feels as though i were going to tear the strap instead, especially the rubber one. And the GT still won’t budge!
I’ve found that using max hold can give higher readings than normal. I turn the light on turbo, then wait about 30 seconds or so for the output to drop and stabilize. While waiting is when I find the brightest part of the beam. I move the sensor back and forth around that “brightest” area and see what the highest average reading is.
Then again, my lux readings always seem lower than others. So IDK.
Just a few days ago Kawiboy1428 reported at least two GT’s where the bezel threads were not cut just right or something. I dont think these were group buy lights.
Just a word of warning for future Lumintop customers.
Me and others still have unsolved shipping damage replacements.
Also we are ignored when asking about that.
I wrote Lumintop 6 days ago PW on this forum, they said, that someone will reply me shortly.
6 days and nothing.
Beware guys. No one cares about our broken lights because of Lumintop poor packaging.
Mike
well that’s just splendid. thankfully my 2nd GT hasn’t exhibited smoking, but i wonder what i should do with this one now. Any chance that Lumintop will send around that tool they use to open the head up?
No…hope not anyway since when i turn it on turbo and the grease evaporates immediately, the smoke just hovers around in there and it’s gotta settle down eventually. 6 months after receiving it after all the anticipation for this lol yes i’ve been looking around for a cheap one, vises of that size cost almost as much as the GT for some reason around here and i’d rather sell it to someone who can open it than throw that cash down the gutter
Grease can’t evaporate immediately. Based on the accounts of a buyer here, if there is still some liquid flux on the mcpcb it has to be heated up for several minutes to get hot enough to start smoking. When that happens it settles on the reflector right away.
Are you maybe seeing something other than smoke? Maybe water vapor or something?
Where do you live? Are there any mechanic shops around that will let you use their vise? None of your friends have a vice?
Do you have a set of rubber strap wrenches? Have you tried one around the upper head and one around the lower head?
