It’s not finished yet but I spent some time on a triple Rook conversion today. Built the new MCPCB shelf out of 18 & 22G copper I cut into rounds then soldered together. First I built the Puck then reflowed the noctigon onto it and reflowed the emitters onto the noctigon at the same time.
The tir is the deeply dished, pebble finish Cute. Emitters are what I had laying around.
Waiting on driver boards now, may piggyback something onto the stock driver as a contact till then but Idk what FW to use. It’s designed with a 25, 7135 + FET (if it were a click it’d run bistro), what do you guys suggest?
4 disks make up the puck (3 18G, 1 22G for proper thickness)
Press fit into light, center hole for 20AWG wires.
Finished head
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
Nice work on the Rook C_k ! But wouldn’t the XP-L because of the higher Vf not be sub-optimal parallel to 2 219C’s ?
Edit: just checked the curves and it is not too bad, in fact the XP-L could well be putting out about the same amount of light as the 219C’s at the same voltage (but at less current so more efficient).
Pretty sure that textured CUTE-3 is a wide angle, if that’s so then it’s going to rob you of almost 33% of your output. I built a triple for a bike riding friend a couple of years ago and he put one of those on the light then complained that it wasn’t very bright anymore. When I got it back from him I tested it against the standard SS honeycomb pattern CUTE-3 and it (the sharkskin textured wide angle) was costing 1100 lumens!!!
Neat idea, but run-time is going to be pathetic on the Rook’s 3 14500’s…
Yea definitely sub-optimal but, as I hinted to in another thread, I’m just kinda getting back into it. The only money I’ve spent this go around is on EDC lights I NEED, all these old hosts / stalled out projects are just to “sample the goods“so to speak, see if it’s just a short lived rekindling of the old hobby or if I’m really back before buying new “toy” lights / hosts / parts I don’t really need.
I had two each XP-L’s and Nichia, this is just my preferred non-ideal combo knowing full well what I’m getting (such a large vF mismatch).
Dale, thanks for the heads up, I’ve literally had this optic for YEARS and always wanted to use it, didn’t realize it was THAT bad. Definitely intended for it to be an up-close light, we’ll see if I can live with it once the drivers done or not, I have some of the spot optics as well and with the MCPCB soldered / pressed into the head it’s cake to swap optics.
Runtime, well yea… I debated making is 3s NiMH vs 3p Lion, this way I can run those 840mAh cells (still get decent current since they’re 3 in parallel dividing the load) and end up with 2520mAh total (or 2.1Ah with efest 700’s for a higher drain option), either choice trumps the 1900mAh 3S eneloop option.
Not getting my fill of moddong on the rook’s head this morning I also fixed up an sk98 that had a good driver & led but suffered from another plastic press in tail.
Couldnt find a suitable retainer ring to do this one like I did the Zuseray a couple weeks ago so back out came the Cu sheet and shears for round 2.
Huge shout out to Old Lumens, his willingness and unhindered ability to take on the big projects with only hand tools is one of the things that made me realize I could try it too! Seriously if it wernt for him building amazing lights from raw materials, by hand, I wouldn’t even have started to take on the miniscule projects I do and all I’m doing is cutting & stacking flat sheet copper, he was making sheet into tube and building whole lights!!
Started as Cu sheet, made a washer with a step bit and a pair of knipex, pretty dang happy with how it came out (and the fact I didn’t leak one drop in the process, usually I cut the crap our of myself trying to drill a hole in the center of a round thing)
Yet another very well done light CRX, don’t know where you get all these old nicely made lights to play with, you must have a link to the flashlight wormhole of eternity.
I think I may have improved on the output and throw distance of a 4D Maglite. It’s new XHP-35 emitter is running at ~2.8A and the beam shows me pretty clearly a couple of dogs at 350+ yds, I can make out a tree that’s over 500 yds away.
Because of the internal structure, this is not exactly an easy thing to do. Also had to get the LED reflector to replace the more bowl like Xenon reflector. Wiring it up between the switch assembly and the new aluminum heat sink was like performing surgery… went through the side button switch cover hole. lol Also had to inset the heavy spring all the way down into the base of the tail cap so 4 26650’s would fit. PITA working on such a long light at the lathe, I can tell ya that!
The heat sink is press fit, actually hammered it in. The top side is pocketed to fit a 32mm Noctigon, the XHP-35 utilizes the center pad and the traces are adapted to allow wires to hook up on opposing sides.
The driver is fitted into a driver bay in the base of the heat sink, this is not the first time I’ve had the wire holes actually line up beautifully but since I hold it by hand on a drill press I’m not 100% sure how… experience I reckon. (for those that are doing this without the benefit of experience, I actually used a bicycle brake pad to sit one side of the sink on so it would be angled, held it firmly while drilling at an angle down into a preset oversize hole. The angle was guesstimated, and as you can see below it worked out…. )
Anyone ever use the Mag “drop in” that Kirill sells? I don’t have a machine-shop nor access to one, but I really want to update my trusty (and pristine) 2D to something more modern, but can’t hack it up to make things fit.
There were drop-ins on FT that would’ve been nice, but they’re (of course) discontinued. I’d be okay with K’s drop-in and shaving off the “bulb-tube” from the come-with reflector, minor hand-tool stuff like that, but I’d really rather not destroy the light itself in the process if I screw up. “Measure once, cut twice… aaauuugh!!”, y’know?
I vaguely remember craziness like doing this with the set-screws, doing that with the switch, etc., which I’d rather avoid if I can help it. I’d really like something as “drop-in” as possible.
And I’m okay with 1 mode on/off, not belting out 20W, 30W, 50W, or more, etc., just upgrading the rather feeble hotwire bulb or “LED bulb” replacement like Mag’s own (1W?). Modest.
With 4 LiitoKala Black 26650’s at 5500mAh capacity and rested with a little use on em it makes…
Low 96 lumens
Medium 856 lumens
High 2563 lumens
215.25Kcd for 927.9M throw. Pretty daarn respectable for a Maglite!
The package says it made 98 lumens for 267M throw in stock form.
Nice X3, good thinking on the mechanics there! I thought about a set screw but it’s a tight fit and hammered in and the modified Mag LED reflector is seated against the 32mm Noctigon so it’s not going anywhere. I need to remove the rubber switch cover and release the switch assembly to get at the wiring and fill it with Sugru or JB Weld to pot it… the LED4POWER driver is already sealed both sides in Arctic Alumina Thermal Adhesive but this is a working man’s light and will be used daily, possibly abused daily, so it needs to be virtually bullet proof. Also intend to put a glass lens on it so it can take more abuse than the plastic stock lens.
I built a purple 2D Mag for my wife a few years back with an MT-G2 emitter and Kaidomain reflector, used a battery check module intended for a wireless helicopter and a fiber optic cable to show state of charge, this little fiber optic is just above the rubber switch cover and does a check list then glows at current state. Really like it, she’s somewhat spoiled to reverse clickies and can’t remember that this one is a forward though…
On this 4D, I know the 26650’s are considerably longer than a set of alkalines so the spring needed to bottom out, but I didn’t want to weaken the tail cap at the o-ring and there’s not a lot to work with there so I cut the base of the hole to match up top and then ramped it, left the area at the o-ring full thickness. It was a bit of a hassle forcing the spring past the o-ring section but then it flared back out into the wider base and is fully intact, seated on bare aluminum and putting quite strong pressure on the 4 cells so it should be able to be used as a baton and not lose contact. (This is a night security guards flashlight)
So, all this messing with Maglite’s got me looking at my old chopped 1D from JayRob. The Elektrolumens puck style triple drop in is very outdated, so I set out to fix that issue this afternoon. Boy what a chore! lol The aluminum heat sink is a thick walled bowl that holds a triple aluminum MCPCB and a CUTE-3 optic, there is a positive plunger/post that fits into the standard spring loaded tower in the Maglite such that you put the puck in the head and screw it back on, bingo!
I removed the aluminum non-direct-thermal path MCPCB and worked on a 32mm Noctigon to get it aligned with the mount screw holes that Wayne put in this puck. Then I used a brass screw and washer from the kit I bought from Old-Lumens to make the post with a brass Acorn nut topping it off to go into the original Mag tower. This is easy enough to say, but it took some doing! But now I have 3 Samsung LH351D 5000K 80 CRI emitters in the Elektrolumens puck (it came with XM-L T6’s), courtesy of some bits and pieces from Old-Lumens, and the puck is mounted in my ChicagoX finned head which attaches to my chopped Jay-Rob battery tube. I had long ago removed the cumbersome and high resistance bits and pieces from the original Maglite switch assembly so with this now being a full direct drive and proper DTP copper MCPCB I’m looking forward to getting some real results.
On an old Novae 32650 with the protection circuit removed it makes ~2500 lumens…
After I took these pictures I removed the bulky steel screws and re-threaded the holes to accept brass screws, gave me a better ground and a lower profile. The long coil spring in the base of the switch assembly is removed and a solid 12ga copper wire is coiled in and soldered solid in it’s place. In the sliding tower up top, I have a 20ga spring bypass carrying the current. Also have a 20ga bypass in the tail on the thick robust spring Mag uses, with the spring cut down and seated in the very base of the tail cap… the tail cap is also bored at the opening to allow the longer 32650 to protrude into the tail cap slightly.
If you’re not real familiar with a Maglite and it’s inner workings, they build in a LOT of resistance!
Where the solid 12ga wire is coiled in at the base of the switch there was what appeared to be a small low profile spring. It’s far longer than it looks and of course it’s steel, residing in a chrome plated steel cup. They don’t make them like this anymore, this is an older light. Nowaday’s they have a simpler switch assembly.
Oh, and that’s not 12 AWG, it’s a solid piece of 12ga Romex house wire.
Could someone explain to a newbie where in that picture is the resistance?
I understand what has been said about the spring. But I got an impression that the picture was supposed to show other significant sources of resistance and I fail to see them….
The spring which is hard to see is long and probably made from steel. This is a point of high resistance. By running a wire from the top of the spring to the bottom of the spring the spring resistance is bypassed.
djozz quotes, "it came with chinese lettering that is chinese to me".
Where to get this host?
I have seen it months/years ago, but I did not found it yet.
…Triple Rook conversion…
The beauty came from my private reserve sir. Post a WTB here, they sucked in stock form and I’m sure they can be found in other people’s junk drawers too lol.
Agro, here’s how the Maglite D cell switch and springs are laid out…
There’s a rather long path for both negative and positive to travel, with the switch breaking the positive path for on/off. The bi-pin Xenon bulb is modern, used to be a drop in with ground in the housing and a lead positive cap. They at least did away with the very long flat style coil spring at the base of the switch assembly, there’s still plenty of resistance in the long travels through steel.
This brass bearing is what allows the beveled lead in to the reflector to push the bulb assembly up and down for focus, by simply rotating the lights head (screw it on/off)
Look at this monster of a tail spring! They changed that for modern lights too, not nearly as many coils but still the very thick steel construction…
The inside of the light is anodized so they use a needle point on the set screw to break through the ano for ground to enter the switch assembly. Steel set screw of course. And this is the key to disassembly of the light… you remove the cells, click the light to on then pinch the rubber switch boot to remove it. A Torx 8 (with skinny shoulder) is inserted through the push button actuator into the set screw and it’s backed out like 6 full revolutions, then the assembly will drop out the bottom of the tube. Tricky, if you don’t know this!
There is a steel split ring in the upper section of the tube that the switch assembly keys off of. This steel ring is very difficult to remove (and completely unnecessary to do so)
My bad, I left out the black plastic insulator sleeve that surrounds the long spring that resides in the tower. This is necessary to separate the spring from the housing where ground is conducted, as the spring carries positive to the bulb. I took all these parts out of the Mag kit I got from Justin (Old Lumens) He loved these lights and did a lot of mods on them, taught me how to get inside actually… I played havoc removing the split ring the first time I attempted this! lol (Actually on this red chopped light, the scars reside inside the tube to this day!)
Still waiting on boards for the rook driver but in the mean time I decided to find a way to put BLF-A6 FW on some more old lights and what do you know, cut one trace, solder one bodge wire and you’re G2G!
Cut trace (done on bare board for the pic)
Run jumper from star 2
Finished head
link to djozz tests
You are on a roll CK. nice work.
Replaced the very old SSC P4 (6300k) LED with a XP-G3 S3 7B4 (3000k) in a bicycle lamp:
Beam shape is oval.
An old classic.
Nitecore EX11 v2 PD Samsung LH351D 4000K 90 CRI Rebuilt.
- LEDs & Other Stuff - - UI CheatSheets - - CRX Mods & Builds - - Stuff for Sale -
- The Old Lumens Flashlight Modders & Builders Challenge is Now Open - Link -
Nice pill Dale, here is my first for a Mag 2D :
Set screw and modified reflector :
EDIT : I can’t wait to share this with you guys
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
I just tested this 4D Mag build,
Low 96 lumens
Medium 856 lumens
High 2563 lumens
12AWG wire?
Damn. Isn’t that a bit overkill even for a spring bypass?
Way to go Dale.
Wow. That’s a lot of resistance!
I personally get my wire from power cords.
Dumpster diving behind Staples is really helpful to find 18650s and power cords, and even a power tool once
OK, thank you.
Thanks DBC.
It lives !!!
Now it only misses the glass lens to replace the stock ones which is already scratched…
The beam is not to my taste however, I might try to apply some varnish on the reflector to blend it a little…
Nice work on the Mags
Its good to see your back in action Ck. Nice work.
