Well, first time I’m seeing this info and their site :person_facepalming:
Doesn’t take back my point reporting to the time I got the lighr and the info, but it changes the things concerning the use of Ni-MH, not specifically Eneloops.
As I mentioned above, maybe contacting Sofirn is the best way to act :+1:
NiMH has the lowest voltage of the major types, and that’s no-load. The controller might have a hard time starting up if it’s already at a low voltage, then tries dumping lots of current to make its supply voltage even lower. At least an alkie can still register at 1.5V-ish at no load.
At lower loads, maybe the voltage holds up more. Then as things heat up and LED current decreases and/or resistance somewhere increases, the sag isn’t that bad and it steadies out.
I remember a digital watch (old-timey red LED digits) would go mental when the battery would start getting low, but noticed it was especially when more segments were lit. Ie, it might work fine at 1:17 but go mental at 12:53.
I don’t have Eneloops nor the correspondent IKEA batteries, I only have some Panasonic Evolta Ni-MH and other “Lidl supermarket” Ni-MH batteries. I do know that Eneloops perform better, but if they are not performing well on the SF14 and other Ni-MH also don’t do the job well done, the focus here must not be the Eneloops, but the Ni-MH rechargeable batteries.
And it must be addressed to the manufacturer.
I do remember that the runtimes pointed out for the SF14 and SP10A/B was only for 14500s and AAs, and for Ni-MH they should be different but they were never mentioned. So, maybe something is missing here.
I never noticed any flickering on my SF14 or SP10A/B when running with Eneloop AA but I haven’t used them since my initial play with them because I use either my Zebralight SC5W II or Reylights when I use AA lights. The Sofirn AA lights are just not bright enough.
I have three of the Jaxman E3 with a fourth on the way.
I decided to try the Sofirn SF14 because of 1) the price 2) it is slightly thinner than the Jaxman, although longer 3) and because of Jaxman’s warning about using 14500s.
The AA size lights make for good pocket EDCing. They also make good gifts. That’s why I need them to use both 14500s and Eneloops. Most non-flashaholics won’t use lithium ions. So I include Eneloops with the flashlight, along with a charger.
The Jaxman E3 produces enough light on Eneloops for me to take the dogs out in the yard to pee. But not enough light to walk them in the park. That’s why I like a light that uses both Eneloops and 14500s.
Someone mentioned contacting the maker……that is where I started…. But the only option Amazon gave me was a return.
Since Sofirn sent me a model I would consider defective AFTER they introduced their new version, I would be suspicious of what they might send me next if I bought a second SF14.
My suggestion to Sofirn — take all the version I SF14s off the market and remove the link from Amazon and elsewhere. Start a new link and label it Version II or new and improved or both.
And then specify whether or not it works with Eneloops.
Thanks for taking the time to check this. I learned something.
The delayed onset is consistent with the notion of heat being the problem. In one video I noticed that turning the flashlight off and then on, does not make the problem go away, but turning it off, and waiting a bit, does, albeit, only temporarily. The problem with NiMH might be that battery IR is too low, current is too high, and heat results.
I don’t know much about driver electronics. Is this a buck/boost driver that bucks for Li-ion (above a certain voltage), and then boosts for lower voltages, including Li-ion, alkaline and NiHM? Does it make sense that the boost section could be prone to overheating only on NiMH? Presumably this would be because of low IR and higher currents. Now that I’ve written it out, the idea does not sound very convincing.
Anyway, as others have already said, it looks like either the flashlight, the driver, or both were not designed for NiMH.
4A is no problem with Eneloops. Running voltage will be over 1.1v. Alkalines will die immediately under that current, and even at 2A will drop below 1.0v very quickly.
The new SF14 is out, and has some differences in aspect (smaller, larger, seems to have removable bezel, has “V2.0” marked on the head, …).
Let’s see if it does work better than the previous version in those aspects mentioned here!
EDIT 2: to specify if it works with Eneloops, they have to specify if they work with the N other brands of Ni-MH batteries once not all the people have the money to buy or the access to Eneloops!!! :arrow_right:
FWIW, last night I tried to duplicate the "flickering in high mode using a Ni-MH battery" anomaly in my SF14 and couldn't do it. Took an Eneloop down to 0.9 v and the flashlight seemed to remain stable all the way. But, as confirmed to me by a Sofirn rep via PM this morning, part of the SF14V2 upgrade is to address this anomaly.
The addition of a Direct Thermal Pat (DTP) Metal Core Printed Circuit Board (MCPCB) <generic illustration below>, and a throttling back of the max lumen output from 600 to 550 lumens should mitigate thermal build-up problems in the SF14V2. According the Sofirn rep I PM'd yesterday, the new MCPCB in the SF14V2 is copper and not aluminum.
The above screen shot is from a browser I had left open. One may just as well pay $16.09 (with the coupon code) on Amazon and get the flashlight with battery and charger.
I don’t know about the price fluctuation, but since it is a new product, they may be still adjusting it.
I remember that in the beginning the original SF14 costed a bit more than what it costs now. So maybe they are still adjusting values. Also, Coin values tends to make some (little) impact!
If you check the AE App, you’ll find a 0.88€ coupon for buying more than 13.03€, so it will bring it down almost 1 dollar!
At this writing, the listing on Amazon says the “upgraded” SF14 is expected in stock on Aug. 8, 2018.
The price for the upgraded version with battery and charging slot is $22.99.
The price for the SF14 alone is $14.99 — same as the old model.
But perhaps it is the old model when you purchase light alone, since it is rated at 6t00 lumens, same as the old. Whiled the updated version is rated at 550 lumens.
I do not see any coupon on the Amazon site, as of this writing.
Reducing the rating by 50 lumens and calling it upgraded makes me wonder what’s going on.
After this controversy, Sofirn should stop selling the original SF14. I hope this is simply an oversight on their part in updating the listing for the light alone.
Still no rating listed for Eneloops, or NiMH for those who may be unaware that the chemistry is the same.
