A note for anyone that has an off center emitter:
Unscrew the bezel enough so you can lightly tap the light and nudge the reflector (in whichever direction you need) just enough to center the emitter with the centering ring. Worked for me.
Not meaning to flood with posts but my MF04 had smoke coming from the emitter?..…now no more smoke after ran it on turbo a few times. Uhhh is that normal? I’m thinking maybe some sort of residue was getting burnt up.
Got 980K max Lux measured @14m on a UNI-T Luxmeter. Emitter is not properly centered though.
After recalibration 1.05M Lux. Emitter is still not 100% center, I might try again later.
Tested the light outside for the first time. This is absolutely insane. I wasn’t this impressed with a light in a long time… the reach is ridiculous. :sunglasses:
Anyone tried both MF02s and the MF04? Is the difference huge? I have a MF02S on order and I’m going to use it to watch for deer on my property. Furthest distance would be approx 600meters before the woods make it impossible to see anything so it needs to throw good at that range.
Thank you that was perfect. Looks like the MF02S might be to little to reach good out to 600meters… So is the MF04 the thrower king atm considering HID lamps and such also?
Leds can’t match the HID in distance, but are much more practical in use such as immediate turn on and better efficiency.
The MF04 and BLF GT are good throwers, but if distance is all you care about, there are lights with smaller, weaker leds and big reflectors that create a real pencil beam and go farther.
You also have lights like the new Acebeam W10 that is pocket sized, 250 lumen and can go 1000 meters. It’s a really tight beam.
So you have to decide what you want as far as distance and how big a hot spot.
Ok. It’s not all but I have a MF02S that’s arriving in a few days that should do some throw/flood and I ordered a Emisar D4 + Convoy S2. It would just be nice to have something with good throw to be able to scout for deer around on the property. 6-700meters should be plenty but it should be more than moonlight at that distance. I have no experience at all with flashlight but I’m just guessing that a beam that is very narrow will be hard to use for that purpose. There are way to many nice flashlights
