Thanks :+1:
Wow this emitter looks amazing! The CRI performance is even better than the E21A and 219B 9080. I was looking for a 2700k or 3000k 219B 9080 for a while but this seems to be an even better emitter. Higher CRI, brighter and more efficient, and even better tint. I calculated a duv of –0.0056, which means it is as rosy or rosier than the E21A. Thanks for posting these results!
Do you have any beamshots by any chance?
nice test!
I wonder how this compares to the new Samsung LH351 3000K high CRI series?
About as efficient as a 3000k LH351B 90+CRI in terms of lumen output.
Less efficient than a 3000k LH351D 90+CRI though, since it has a smaller die.
All in all, it looks like to be a wonderful LED.
Has anyone done any testing on the 3000k LH351D 90+CRI?
Strangely enough, not at all.
Thanks for sharing your results!
I have a few of these on there way to me from KD already.
This might have made a nice choice when the poll for the FW3 emitter was being taken.
I have more high CRI emitters than I know what to do with right now. My LH351D’s from the group buy came earlier this week, my order from 219Bs from that group buy came a few days later, and I already had more 80+ and 90+ nichias from Mtn that I had plans for.
And then there are the 9 70+ SST-20s, and roughly as many SST-40s.
I think I need to order some triple emitter hosts from Jaxman and Sofirn. That’ll be a good start…
Thanks! I would appreciate the lm/Vf data in a number format as well
Is this the led you purchased? http://kaidomain.com/Luminus-SST-20-J3-HD2-Warm-White-3000K-LED-Emitter
At least the part number on the package matches yours, but their other info can’t always be trusted.
djozz, please give a link for this LED.
Thnx Djozz! Nice numbers and was looking for some 3kK emitters. Ordered some to try.
That is the correct link, Kaidomain left out the CRI number in the description.
Nice! :sunglasses: :+1:
Thanks for testing!
Thanks for the hard work mate. How does your standard SST-20 perform are they any good?
I have built a Convoy S9 shorty with this led. Current 160mA/880mA/1.85A, output on high 350 lumen. That makes the efficiency of this flashlight on highest setting about 50 lm/W which is not bad for a light this warm and high CRI.
Important for the performance of this high CRI SST-20 is how the beam looks like and how the tint/CRI is affected by the (OP-)reflector and lens (the lens of the S9 does not seem to be AR coated, which is nice for very high CRI builds)
The beam is a beauty, I say 219B-quality:
The light quality in the hotspot:
The light quality halfway the spill:
So compared to the bare led, in such a build you loose a small bit of CRI and the rosiness is a bit less, in fact the hotspot ended up almost on top of the Black Body Line. If you really want to retain the rosiness of the bare led you need to use this led in an aspheric lens flashlight.
That looks great with only a little tint shift. I also briefly tested the cool white SST-20 and the beam looked nice and even cool white with a S2+ sized OP reflector.
edit: I like how the Gossen tells you all the important details right on the screen!
I’m sorry for not showing the IES TM-30-15 data, this way of capturing the limited CRI data from screen is quick for me :innocent: and already shows a lot of what is going on.
So do I, because of my lack of knowledge and interest in computers and automation, led testing and doing the write-up is a quite tedious job for me, at least the new addition of some tint/CRI information is very quick this way.
Are you saying that you’re not paid for spending hours doing this??
Not yet that i know, of I have four of the LH351B 3000K high CRI LEDs in a lantern prototype for testing, but have not got any of the LH351D series yet. These SST-20 3000K seems to be a good LED to test too.
Thank you djozz for your time to make this testes, it is really very important to us
Question is sst-20 a 5 watt emitter like the XP-G2 or 10w like the XP-L ?
Sorry i am confused
