Any battery suggestions?
Flat or Button top?
High Amp but how high?
Manufacturers recommended and ones to avoid?
Max dimensions?
Assume not protected…
Thanks,
Nite Shadow
Basically I could add the Maxim chip that I am planning for my LVP Tail boards as well to the aux board, but there is like no chance to make it fit on the normal d4 for size reasons
It is planned to do a color change on low voltage and shut down at LVP
Problem is I am waiting on the first to be delivered even if I ordered them 4 weeks ago
so first I have to test the tail boards successfully and the basic aux boards
It would help to know the optics and MCPCB specs on the D4S
on a Fireflies light the low battery and LVP shut off fits barely on 2 layer from space and trace routes
Efest batteries lie about the discharge capacity. I think Ijoy INR26650 is the best option in Nkon for D4S.
If you are from UK the Vape Club web store have Vapcell 26650 wich is one of the best batteries in this format.
You can look at the Mooch recommended batteries:
Efest cells are among the top cells available, I have dozens of them and they are no problem… sometimes best sometimes just in the top 3.
I have the iJoy 26650 and it’s not an impressive cell in and of itself. The black LiitoKala 5000mAh is one of the best, alongside the horizontally labeled black Shockli 5500mAh. When it comes to this type of light, one of these two black cells is what I will personally use.
Any idea what’s inside the Orbtronic cells? They mostly just rewrap other brands.
I mean, they generally choose good cells. But they don’t make them; they tend to just add a button top and/or protection circuit and a wrapper. So someone else probably came out with a new 5750 mAh cell and it’d be useful to know what it is.
