Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
thanks,This one doesn’t copper as declared but brass
right?
brass looks different: https://www.fasttech.com/p/1208600
I think someone wrote that he has bought it an it was realy copper.
Whats the price for the Courui D01 Pill? And whats the material?
$25, copper
Hi Kiriba
can you please PM me for 2 (Copper spacer+brass centering ring set for quad mod Convoy M2)
Ok, I let my custom aluminium Pill inside.
∅20mm H1-A driver can be used soldering it to the pill with a hot air gun. H1-As maximum Vout can be modded for triples, see Jensen567's work.
This is a little job I've done with a genuine UltraFire SK98 flashlight's pill.
Inner cylinder is ∅11.1mm approximately, made of two 1mm thick copper discs. Under it is soldered to a ∅18mm 1mm thick disc, and thermal glued to the pill's balcony.
This model would thank a nice and beefy copper pill, it is very easy to mount an H1-A driver in, fits snugly.
Originally posted on Sun, 07/29/2018 - 19:38. Added comments. Further edit to remove wrong white balance pics.
mtnelectronics is supposed to have something in the works, available at the beginning of August! I suspect a copper pill will be quite necessary when running an XHP in an S2+
Thanks for the info mate! I’ve been reading RMM’s thread and noticed that recently :wink:
I’ll be looking for it on both thread and in MTN site! Thanks for sharing :+1:
Thanks kiriba-ru. Could you please put me down for two B158 pills?
Im sorry, it requires as much as 20x S2+ spacers in material and as much as 10x S2+ spacers machining time.
Money is not target, I left the message to finish as much custom (small quantity) orders as it is possible ATM.
If you think parts are overprices, you are welcome, just $10 for any die (I will help with tips and drawings), it would be great if another BLF member would provide this pills could keep prices at better level.
I do not have a the possibility to make something like this and I do not say, it is overpriced. But its not worth for me for this flashligt.
Got my goodies, tnx!
Now I’ll see what a triple of 351Ds will look like… :smiley:
Hi, I’d like to order
  • Carclo 10622 24mm quad Narrow Spot Plain TIR (for M2, P60, U11 quads) – $1.5 in stock
  • Copper spacer+brass centering ring set for quad mod Convoy M2 – $10, 55g
Thanks!
I got my S2+ Parts today, great packed & shrouded with wrapper… And Postman rings for it… 9 days to germany… Great Job… :crown:
Thank you kiriba-ru
New build today: Convoy M2 quad with Optisolis 4000K. Thanks kiriba-ru for your excellent parts :slight_smile:
I received my copper S2+ spacers in less than 2 weeks to the US! Packaging was excellent! Thanks!
I would like -
Copper pill triple Convoy S2+ (Convoy retaining ring)
Copper spacer for Carclo triple Convoy S2
Plaese PM me with details
Thank you
All triple pills are gone. I think single led copper pill looks more interesting since 17mm boost driver is available, so single pill is next to be produced. I havent seen great demand for triple pills last time, not sure I should make more of them. Please leave your comment if you dont agree.
