I’m sorry for not showing the IES TM-30-15 data, this way of capturing the limited CRI data from screen is quick for me :innocent: and already shows a lot of what is going on.
So do I, because of my lack of knowledge and interest in computers and automation, led testing and doing the write-up is a quite tedious job for me, at least the new addition of some tint/CRI information is very quick this way.
Not yet that i know, of I have four of the LH351B 3000K high CRI LEDs in a lantern prototype for testing, but have not got any of the LH351D series yet. These SST-20 3000K seems to be a good LED to test too.
This led fits 100% in the XP category: same footprint, same die-size, even the same current capability so about the same wattage. Only the voltage is, like most newer leds, lower than the XP-G2, in fact very close to the XP-G3.
In fact some of it is paid by my wife :innocent: : because my wages are lower than hers, she gets to pay a bit extra tax and I receive a fairly generous refund every year. The idea is that because of my lower paid job I am expected to spend more time unpaid housekeeping and the government makes sure that I receive some compensation (this measure was originally meant to make housewives without proper jobs a bit less dependent on their husbands). I do a good amount of housekeeping but guess where the money goes? :person_facepalming:
If you round off correctly, in this Nichia terminology it would go from 9790 to 9680, sounds a bit less dramatic.
A TIR kind of makes a blend of what in a reflector light goes to the hotspot and the spill so the result could be somewhere in between the bare led and the reflector hotspot, who knows. But to know what really happens, I’m planning an E2L with this led (will not start that until a week from now), I can measure it by then.
Btw, in my taste a hotspot tint on top of the BBL is excellent!
If you choose the 3000K leds for the KD triple it should be this led, they have no other 3000K SST-20 listed, and actually AFAIK another type 3000K SST-20 does not exist has not been seen around yet. Mind that that KD triple board is not compatible with Carclo optics, only with the in-house KD optic that is sold together with the board.
The excell sheet is big, with lots of other led data as well, and I’m not too handy with excel so slicing it to size already is a challenge.
I hope the raw data will do as well? :innocent:
You should be ok with a (direct drive) triple on one 18650, if it is over 15A you get in the danger zone but with its Vf a bit higher than the 219B you will not get there. More likely you will end up at 9-12A which would be perfect. To be sure you can start with springs without bypasses and measure current.
I made a Jaxman E2L triple (shorty) with the SST-20 3000K 95CRI, to see how the led behaves in TIR optics.
Unfortunately I only had a frosted triple Carclo optic while I wanted a clear one for this build. I half polished it so that it now is in between clear and frosted.
The driver is a BLF-A6 driver. I will make a lighted tail later so I added a 680 Ohm bleeder resistor. Also I ‘fixed’ the driver from voltage spikes on the CPU as suggested by DEL (not really needed for the very tolerant Attiny13 in the BLF-A6 driver but I did it anyway).
I did no spring bypasses because I do not want to over-stress these leds and this small light with so many amps will become too hot too soon anyway.
The beam is very smooth with no disturbing tint variations, perhaps a true clear narrow optic would have produced a more distinct hotspot.
The tint and CRI has not quite suffered from this optic, to state it lightly, it is as nice as you will ever want it to be.
Hotspot at a mode under 350mA (so regulated at 350mA, ~120mA/led):
Outside the hotspot at a mode under 350mA:
Hotspot at max (on a Vapcell 18350, 1150lm, about 8 amps, ~2.7A per led)
