✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Nitenumen NE01-H XM-L2 U2 1000LM 5Modes USB Rechargeable Long-range Searching EDC LED Flashlight Bicycle Front Light
Coupon code with nice discount is available.
» :email:Request via PM here«
» Jump to First post quick links/deals list «
Jetbeam WL20 XPG3 1000LM 8Modes White & Red & Green Lights Tripe Switch Tactical LED Flashlight
Jetbeam IIIM2017 XHP35 E2 LED 1580Lumens 7Modes Dual Switch Brightness Tactical LED Flashlight
Skilhunt PL1 230LM 6Modes USB Rechargeable Hands Free Patrol Light Emergency Signal Light Clip Pocket EDC Flashlight 4 Colors Optional
Klarus G35 XHP35 HI D4 2000LM 18650 Outdooors Illumination 1000m LED Flashlight
Use coupon code PKR53 to get -$27.98 discount.
Amutorch AT40 4x Nichia 219C/2x XP-G3 1200LM 3Modes Memory Function Convex Lens Professional Floodlight Titanium Alloy EDC Flashlight
Use coupon code PAMT4 to get $29 price (-$7.99 / –22%)
2 versions are available: 2x XP-G3 or 4x Nichia 219C
Astrolux MF04S XHP70.2 6000LM 8Modes Professional Procedure Super Bright Floodlight Flashlight
Use coupon code PMS4S to get $172 price (-$67.00)
The S version uses Cree XHP70.2 for 6000lm instead of XHP35 in MF04.
Cool white and neutral white versions are available.
Convoy C8+ Black 7135*8 XPL HI 1100LM LED Tactical Flashlight Memory Function Professional-level 12-Group Dimming Modes
Use coupon code PCY9P to get 18% discount
4 tint options available: U4-7A(warm), U6-3A(neutral), U6-4C(neutral), V2-1A(cool)
I received the Nitenumen X1 order yesterday. In summary:
- No mode memory. Sequence is High-Medium-Low-Strobe-SOS-Off. It has to be played all the way, no way to turn it off directly.
- Small size, hardly bigger than a 18650 cell.
- Takes button top cells only
- Warms up very fast. In 5 minutes it became too hot to hold in High mode. No sign of temperature regulation, I switch it off to avoid meltdown.
- Spring was too flat to make contact, I had to bend it with a plier.
- Scaling is poor, Low mode is too bright. Actually, flashlight is noticeably hot in Low mode
- Comes in a nice paper box, with USB cable, spare o-ring and charger cover
  • USB charging terminates at 4.24V - acceptable, not too high to damage Li-ion cell
It looks like they wasted the potential of making a nice light.
Nitenumen TA03 code please :smiley:
PM sent :slight_smile:
Exactly… They already had good driver like the one used in NE01 so this is disappointing. No long press to turn off is major drawback imho.
It’s a shame because I like the look of this light, the compact size and steel head…
What about modding potential? Is it glued or there’s driver access? In light of the above driver swap is essential.
Astrolux S1 XPL 1600LM 7/4modes 3D Mini LED Flashlight 18350
Use coupon code 59596c to get $16 price (16% discount)
Matching 18650 body tube in each color available here:
Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or less with BG points.
Rofis MR50 XHP50.2 2500Lumens 6Modes USB Rechargeable Charging Indicator LED Flashlight
Probably first decent 21700 battery flashlight, has built in charger as well.
The tailcap can be unscrewed to insert 18650 battery, and that is all. Head part is firmly glued together. :frowning:
The Nitenumen X1 driver reminds me the cheap XANES WT518 or XANES 1301 flashlights - the are also USB rechargeable.
The body of X1 is of better design and the bezel is stainless steel, but apart from that, their functionality is the same.
And a little surprise: Nitenumen’s home page does not have a Nitenumen X1 model… A C10 flashlight is similar in looks, but its functionality is better.
WTF?
Seems unlikely. You would lose the built in charging for one thing. It also looks like the switch is attached to the driver. So you need to rig up a new side switch. It’s not worth it for me to try and swap a driver.
That’s a shame and wasted potential… there’s not that many nice looking flashlights with steel bezel and decent price. Standard alu bezels are not very durable and dents or chips after just one drop…
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
Use coupon code 1149 to get $11.96 discount. (I noticed this code is a little misleading:stuck_out_tongue: )
For use with high current 18650 cells to achieve full light potential additional 18650 body tube is available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$2.80
$2.76
$2.73
$2.70
$2.63
Haikelite SC26 XHP35 HD/HI 2050Lumens Modes Set Brightness Portable EDC 26650 LED Flashlight + 26350 Tube
Private coupon code with best available discount is up for grabs!
  • 20 color/LED combinations to choose from
  • XHP35 HD/HI CW/NW
  • included short 23350 tube
