[2018-07-30] "Not secure" browser warnings, all is normal
30 posts / 0 new
sb56637
sb56637's picture
Last seen: 3 hours 45 min ago
Hi everyone,
You might have noticed that some web browsers are displaying a scary looking “Not secure” warning for BLF. Everything is normal, and there is NO reason for concern.
Basically, it has to do with the simple fact that BLF doesn’t use SSL (the https:// protocol). Since BLF doesn’t process any sensitive information it’s not imperative to implement SSL. The site has NOT been compromised, nor does it have viruses or anything of that nature. It’s just an overly-alarming warning from the browser that it displays on all sites that use the http:// protocol with any sort of user login feature.
When it comes to “web security”, there are a huge number of factors that are often confused:
1. The risk of malware on your device that logs your personal data and “phones home” to the attacker. This is by far the most common attack.
  • SSL (https://) does NOT protect against this risk.
  • As the administrator of BLF, I can’t do anything to protect users from this risk.
2. The risk of somebody tricking you into revealing your password(s) and/or financial information by pretending to be somebody else. This is also a common attack vector.
3. The risk of somebody hacking into the web server and installing something malicious that infects visitors. This is also relatively common.
  • As the administrator of BLF, it is entirely my responsibility to protect my users against this sort of attack, and I take it very seriously. There are a huge number of best practices for administrating a web server that I adhere to to keep the server as secure as possible. Usually if there is a sudden unplanned maintenance window for BLF, it’s because I’m applying security patches.
4. The risk of somebody hijacking the webpage data while it’s in transit “on the wire” between the web server and the visitor and modifying and/or stealing the data. This is not common.
  • This is what SSL (https://) is designed to protect against.
So I don’t see any imminent risk for BLF users by not immediately implementing SSL. I’m sure I will eventually, but it’s not a priority. A frequently overlooked downside of implementing SSL is that it requires significantly more server resources to encrypt and decrypt all the traffic. The BLF server is already under rather heavy load most of the time, and SSL would surely push it over the edge, requiring another server upgrade or even a migration to a different host.
Thanks for reading. Have fun!
Edited by: sb56637 on 11/22/2018 - 09:27
MRsDNF
MRsDNF's picture
Last seen: 23 hours 57 min ago
Thanks for the update sb. l’m glad the forum is secure. Beer
Now can you do something about the insecure members here? I know I am not the only one. Silly
raccoon city
raccoon city's picture
Last seen: 9 hours 27 min ago
security
:THUMBS-UP:
sb56637
sb56637's picture
Big Smile
Barkuti
Barkuti's picture
Last seen: 9 min 25 sec ago
I use the pickiest Android browser (Chrome), and I've not seen a single warning.
Now that we're here sb56637, I am going to suggest a forum improvement in emojis/emoticons. The available range via simple post editor is a little bit Crying limited and definitively Oops outdated (and not to say the advanced post editor is a @#$% in this regard) . I know you just have to host a good handful of emoji images and make them available for insert via some small applet, there are plenty of nice emoji sources free to use nowadays. Hijacking outside bandwidth to make use of them is uncomfortable and worries  me a little bit.
Thanks.
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Man Without Shadow
Man Without Shadow's picture
Last seen: 57 min 5 sec ago
He didn’t say it was secure, just that it wasn’t necessary to be secure…as we don’t process transactions on the site or share detailed personal information.
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
Joshk
Joshk's picture
Last seen: 20 min 37 sec ago
I understand SB. Thanks.
I vote for SSL though. It’s fast, free, and renews itself. I’d love all sites to use it.
//Install LetsEncrypt//
add-apt-repository ppa:certbot/certbot
apt-get update
apt-get install python-certbot-apache
//create certificates
certbot —apache -d example.com
//Test the renewal process. It will keep itself renewed.
certbot renew —dry-run
certbot renew
//See certificates
/etc/letsencrypt/live
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 5 hours 30 min ago
Its Google they updated the verification process and if a website doesn’t have a SSL its flagged as unsafe they want all servers/websites to use HTTPS. Is the issue only with Chrome?
Henk4U2
Henk4U2's picture
Last seen: 4 hours 20 min ago
Firefox gives me a warning when I log in.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
raccoon city
I use a lesser known browser, Opera.
I haven't received any warnings, so far, that I remember.  :BEER:
CrashOne
Last seen: 7 hours 13 min ago
apt-get update
certbot renew
//See certificates
The problem is not the installation of a certificate, but all the other services that are only available through http. You will get an unsecure/mixed content loaded message (there is a workaround: Load all external content through BLF server).
But I agree, https is the way to go: https://doesmysiteneedhttps.com
Flashy Mike
Flashy Mike's picture
Last seen: 4 hours 52 min ago
I’d prefer HTTPS at least for log in data.
Barkuti
Barkuti's picture
Opera uses a Chrome engine.
And G00gl€ can $#%& my @#%$ with the security stuff and whatever, by the way. They get bully with sheesh and I hate that. I've posted a few messages in the G00gle help forums and its surprising to see how awkward and @#$% is the code/engine which runs them. Its a unbelievably freakin' mess.
G00gl€, Appl€ and the dimwits feeding them blindly need a flogging.
Off-topic again, sorry.
Cheers Party
CRX
CRX's picture
Last seen: 2 weeks 1 day ago
What about our personal messages?
sb56637
sb56637's picture
In theory there could be personal information in PMs. But when it comes to “web security”, there are a huge number of factors that are often confused:
atbglenn
atbglenn's picture
I use a unique password generated by Lastpass for each and every website. That said, I don’t give out personal information on websites that are not secure. Plus, I use a VPN. I’m no expert, but I think I’m a couple of steps above the average Joe.
Boycott Nike
Joshk
Joshk's picture
My home ISP injects advertising into web pages that are not encrypted.
My cell ISP severely reduces the quality of the video clips I text out if they can process them. (non iMessage encrypted deliveries)
If they have the balls to do that, they have the balls to profile me based on comments I post on BLF. For that reason I wish BLF had SSL.
Barkuti
Barkuti's picture
My cell ISP _+severely+_ reduces the quality of the video clips I text out if they can process them. (non iMessage encrypted deliveries)
I'd tell your ISP to lick my @#$%.
With regards to advertising I have it blacklisted by default on Android thanks to AdAway (root). It can also be done by other means on Windows (done it) or Linux machines.
Adverts are an unnecesary pester illness in my honest opinion. I never buy based on advertising alone (if at all), but rather on my own needs and objective reviews.
Cheers Smile
Joshk
Joshk's picture
I have NO choices for ISP. If I want home internet, there is only one choice.
bmengineer
bmengineer's picture
That’s just not true. At very least, BLF processes email addresses during registration. If my contact information doesn’t fit your definition of sensitive, what more do you want?
It’s not good practice, but I’m sure enough users also use a generic password for this site as well – that could definitely be considered ‘sensitive’, depending on what else it’s used for.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Joshk
Joshk's picture
How much money would you need to raise to add more processing resources to your system SB? I would chip in yearly. Many would. I would like to see BLF grow.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 16 min ago
Joshk wrote:
//Install LetsEncrypt// add-apt-repository ppa:certbot/certbot …
If I recall correctly, BLF runs on a SuSE-based platform. But I might use your cert tips for a project I’m doing… thanks! Smile
(mostly, I just need ssl for a bit of a toy project, to enable secure cross-site data transfer)
I would also find it useful if BLF acted as an oauth2 (or similar) identity provider, which requires ssl, so I could slave other sites/services off it using a single sign-on. I’ve been tempted to add some kickstarter-like features to make community projects easier for everyone. But even if BLF had identity provider features, I’m not sure I’d actually have enough time and motivation to do the rest. Too many projects.
This would create a whole lot of warnings and/or break a lot of image links. Like, I’d probably have to add https to my site (finally) and edit every post I’ve ever made with images. Which isn’t really all that much of a problem for me personally, but in a site-wide sense it would be pretty disruptive.
The server-passthrough workaround could reduce disruption, but it’s even more complication and more server load for sb to deal with. And some of the sites I’ve seen with that method end up breaking half the time anyway.
sb56637 wrote:
3. The risk of somebody hijacking the webpage data while it’s in transit “on the wire” between the web server and the visitor and modifying and/or stealing the data. This is not common.
It’s certainly an open attack vector, but it hasn’t been a problem here that I’m aware of. There are probably people in the NSA and KGB quietly collecting our login data and stuff. Large-scale route hijacking attacks have been found in the wild for at least the past five years, ever since people noticed BGP attacks routing traffic through Iceland in 2013.
But if they were to ever actually use that data, we’d have much bigger things to worry about. And in the mean time, ssl is a significant cost and complication for BLF.
TL;DR: What sb56637 said. Https should probably happen eventually, but it’s a major PITA.
Joshk
Joshk's picture
You don’t have to force https. Just answer “no” to the force https option at install and nothing changes as far as the public sees. Leaving SB and some users free to doddle around with the https.
Joshk
Joshk's picture
As the very title of this thread makes clear, browsers are on the verge of out-right blocking users with a red screen and scaring them away if the site is not https. Requiring SSL really is something that is going to happen soon. There are been years of marching, and some companies are now pushing hard.
ToyKeeper
ToyKeeper's picture
Oh, cool. That certainly helps. Smile
(in case it wasn’t obvious, I’ve been dragging my feet about https for a long time and haven’t really dived in yet… last time I really looked at it was before it was compatible with name-based vhosts, so I didn’t implement it then and haven’t gotten back to it since)
tenohfive
Last seen: 8 months 8 hours ago
I’ll be honest, I expect SSL on any site I visit and it puts me off when I don’t see it. I’ve dipped into these forums over the last few months but would only login if I really needed something. Frankly there’s too much bad stuff happening on the web to be worrying about how secure my credentials are – I’d rather avoid a site entirely and avoid the issue.
Barkuti
Barkuti's picture
tenohfive wrote:
Joshk wrote:
As the very title of this thread makes clear, browsers are on the verge of out-right blocking users with a red screen and scaring them away if the site is not https. Requiring SSL …
I'll be honest, I expect SSL on any site I visit and it puts me off when I don't see it. … Frankly there's too much bad stuff happening on the web to be worrying about how secure my cred…
Right now I am not seeing such “explicit” warnings. Why? Namely because I “downgraded” my browser version a little bit. I do not update my software if the developer is screwing up. I am the one deciding how and when to update my software. Those of you who regularly go to whatever software “stores” to “upgrade” your software blindly are allowing yourselves to be manipulated, sorry to say. Nowadays software development is quite focused on milking the cows and this means speaking half truths to people (how not?). SSL is not really necessary for many stuff no matter what bullying G00gl€ says.
There's too much bad stuff happening? Sorry?  Bad stuff happens to those of you who allow it via your subconscious beliefs. My advice is for you to believe right, as the reality you experience is created via your chosen beliefs (as above, so below), not the other way around.
Cheers Party
sb56637
sb56637's picture
I understand your viewpoint, and it’s definitely commendable to be conscientious about security. But please remember to always use a different password on all different websites, which will avoid most risks.
withoutink
As mentioned above let’s encrypt would be a great idea… at least the login in page. Also, Google will be prioritizing ranking based on certain security variables including SSL.
Cheers-
Withoutink
My Flashlights
Instagram | YouTube
VaKo
You really won’t have much choice about implementing SSL going forward, it’s not going to be long until this is required by most consumer browsers and search engines.
