ENEDED
I’m down for a 70.2 NW
Done. Ordered Black/CW MT03
im interested black CW. thanks
what are the best batteries for this flashlight?
Interested
For aors 10
Sanyo 18650GA 3500 mah mid button top
Samsung 30q 3000 mah button top.
This is definitely a high drain light.
If you use high capacity 18650 cells like Panasonic Sanyo 3500 GA, then you won’t be getting full power.
If you want full power, you should stick to 2500-3000mah high drain cells like Samsung 30Q, Sony VTC5 and 6, LG HG2, etc…
I always think solder blobbed flat tops are better than button tops, but either should be okay.
Has the new MT03 a thicker shelf than the original?
I had an old here for mod and it had only 2mm
Interested
I have not idea if they will be exactly the same as gen II host. I did feedback on the button design though. Hopefully, HKL will able to improve on it.
Interested in one in xhp70.2 NW
Interested white NW
Interested. Black. NW.
Ordered one NW White/silver. Thanks freeme!
Interested in one black NW XHP70.2 P2. Thanks.
Interested
Interested.
Black, NW,90 CRI if possible.
From what I know, the NW 4800k LED is only 80CRI, not 90CRI.
What about CW? What CRI is it? Also 80?
Cool white is standard 70CRI.
