[♛ FreemeGB] Haikelite MT09R 3x XHP70.2 25,000lm & 3x XHP35 Hi 6500LM Flashlight Group Buy -【 ACTIVE 】
Can I get a code for the XHP70.2 NW silver PLEASE?
Thank you!
Hi freeme, I am interested in both XHP70.2 and XHP35 Hi
You got mail ... again.
Anybody get theres yet? Mine should be here Today.
yes, the light (silver, NW, XHP70.2) was delivered yesterday… but I had no time to play with it yet. :frowning:
I got my light and the spring bypass changed to double springs. I think the small ones are berilyum-coppers because of the color.
It puts out 18300 Zozz lumens with 4 fully charged LG HG2 at start.
What!? The driver has a bible verse on it? That’s crazy.
Interested in XHP70.2 CW Black
Thanks
Very nice, that is what I was hoping they would do. Much better then the bypasses they were using. These are simpler and much more reliable for production.
For production it is safe and good and the 18300 lumens is brutal but as a modder I want the max. :smiley:
So I removed the little spring inside and done 18 AWG wire bypass.
Also added more solder to spring base. And I saw that the mark on battery contact board was only a small dot which is the spring end. I bented down the spring end a little and after that I see a circle mark so the spring contacts even and a much bigger area.
Glad it was Delivered, hope you can PLAY with it soon.
Yep, that is the idea, with double springs those that want can still bypass them but for the masses it is more reliable.
I had countless spring bypasses fail before I really dialed in my technique. I just don’t trust line workers to get it right.
What are the numbers now with the bypasses?
I don’t know yet. I’m at work and literally nothing to do so I brought in the flashlight to play with and do the bypasses. :smiley:
I have 9 and a half hour left here so tomorrow morning I will get the numbers when I get home.
So… I had time to play with that light. I’am impressed, it’s really very bright and at the same time very handy.
For me personally the light could have mehr throw and less flood. It’s not so glare-free at higher levels. A smaller spot would help there. And I lost the turn on button (temporarily) - it should be glued or maybe it should be bigger at it’s footprint.
She gets hot super fast, i dont know when the Thermal Protection kicks in…but its not fast enough. My hand still feels like its burning a lil bit.
By defualt it should kick in around ~55c but the variance in the thermal sensor is around +/-10c, so it could be higher.
It is quite simple to recalibrate the thermal regulation in the menu though, so feel free to do that and you can set it to whatever temp you want.
Thats hot, 131F…i saw that…if you do that…is 30sec the Minimum? Or can you set to what you want? Thanks
I doubt these are Beryllium Copper springs.
They’re probably phosphor bronze springs. They are also quite thin. Could someone measure their thickness? I would love to know.
55c is considered “safe” by most standards in the sense it will not cause burns before reflexes kick in and you can let go.
You can actually hold 55c without damage for a little bit, it is hot but possible. I do this regularly.
It is setup by temperature, the manual should explain the process but once you enter the calibration you simply turn the light off when it is as hot as you would want it to get and that becomes the new set temp for the light.
I will look into it, it is to hot for me…THANKS
