[♛ FreemeGB] Haikelite MT09R 3x XHP70.2 25,000lm & 3x XHP35 Hi 6500LM Flashlight Group Buy -【 ACTIVE 】
Glad it was Delivered, hope you can PLAY with it soon.
Yep, that is the idea, with double springs those that want can still bypass them but for the masses it is more reliable.
I had countless spring bypasses fail before I really dialed in my technique. I just don’t trust line workers to get it right.
What are the numbers now with the bypasses?
I don’t know yet. I’m at work and literally nothing to do so I brought in the flashlight to play with and do the bypasses. :smiley:
I have 9 and a half hour left here so tomorrow morning I will get the numbers when I get home.
So… I had time to play with that light. I’am impressed, it’s really very bright and at the same time very handy.
For me personally the light could have mehr throw and less flood. It’s not so glare-free at higher levels. A smaller spot would help there. And I lost the turn on button (temporarily) - it should be glued or maybe it should be bigger at it’s footprint.
She gets hot super fast, i dont know when the Thermal Protection kicks in…but its not fast enough. My hand still feels like its burning a lil bit.
By defualt it should kick in around ~55c but the variance in the thermal sensor is around +/-10c, so it could be higher.
It is quite simple to recalibrate the thermal regulation in the menu though, so feel free to do that and you can set it to whatever temp you want.
Thats hot, 131F…i saw that…if you do that…is 30sec the Minimum? Or can you set to what you want? Thanks
I doubt these are Beryllium Copper springs.
They’re probably phosphor bronze springs. They are also quite thin. Could someone measure their thickness? I would love to know.
55c is considered “safe” by most standards in the sense it will not cause burns before reflexes kick in and you can let go.
You can actually hold 55c without damage for a little bit, it is hot but possible. I do this regularly.
It is setup by temperature, the manual should explain the process but once you enter the calibration you simply turn the light off when it is as hot as you would want it to get and that becomes the new set temp for the light.
I will look into it, it is to hot for me…THANKS
I wonder why they didn't consider deep fins design like MT03 for MT09R?
0.5mm
That is quite thin. As expected from just looking at the picture.
I think they could have gone with thicker wire, like 0,7mm, or even 0,8mm. But that still is a better decision that either leaving the steel springs alone, or bypassing the springs, which comes with a huge risk from the manufacturer.
It just means the MT09R is the true grail light.
I’m home. The batteries at 4.01,4.05V and it puts out with these 19950 lumens. Now I putted them on the charger and wait because I want to use same set as the stock 18300 lumens measurement.
Please me coupon
Interested. Thanks
My final number with all spring bypasses with 20 AWG in battery tube and 18 AWG on driver. Fully charged LG HG2s.
21120 lumens
I did a video on setting the temperature. If your in ramping mode, make sure you ramp down and hold to get into the menu. Normal NarsilM is usually 8 secs, but I think NarsilM on the MT09R you hold down for 20 or so seconds?
Anyway, after that it should be the same menu settings and procedure.
Aaand it already died :cry:
I tried to measure lumens at 30sec. Right at 30s the light turned off. Or I thought. Now it has ramping to 400 lumens and instead of turbo it barely glowing leds. I think the fet died.
So don’t bypass your springs with wires!
