Aaand it already died :cry:
I tried to measure lumens at 30sec. Right at 30s the light turned off. Or I thought. Now it has ramping to 400 lumens and instead of turbo it barely glowing leds. I think the fet died.
So don’t bypass your springs with wires!
Yes it has burnt smell. I made a video of the behaviour.
And opeled it up. The fet burned. I don’t know but the driver has two places for fet. Does haikelite cut corners and used one instead of two? TA designed it to use two because the high current or not?
I think it was also melted the solder and raised by the pressure when the magic smoke came out.
I did not find any datasheet of this manufacturer by googleing the markings.
It does indeed sound like the first channel is still working but the main FET is not.
I know they said they could not get the SIR800 FET I speced for the driver in China (and used for the ~100 lights I built with high CRI LED’s that pull WAY more current then the LED’s they use).
I am thinking that instead of ordering the more expensive SIR800 from mouser / Digikey / Arrow like I suggested they changed the FET to another model.
Please do let us know what FET they are using now.
That is even more strange, the R800 is the same as the ones I have but the rest of the markings are different and the font / layout is completely different from the SIR800’s I have.
Lexel showed another FET with the R800 marking that was rated much lower, I wounder if they used that thinking it was the same thing instead of the full model number I sent them. I sent them the parts to build 100 drivers with the proper components as well.
The high CRI 4000k LED’s I used in most of the lights I built generally pull around ~25-30% more current then the stock LED’s and they were bypassed springs as well.
So I know that the proper SIR800 can handle the stock LED’s no problem seeing as I have not heard of an issue or failure of any of the ~100 lights I built.
True but if they are bypassing the springs then I guess it is safe to assume they can solder
That said naturally I wish they had contacted me for a replacement FET suggestion instead of just using something they found. Last I heard I sent them a link to Arrow that had free international shipping on the SIR800 and assumed they would use that.
Where do you apply the hot air?
Not from other side of pcb I assume as the heat doesn’t go through.
Not directly on top of the FET as that can damage it I assume.
So around the edges of the FET?
Does the heat penetrate fully underneath it?
Thit is also for TA:
Does the driver has enough cooling for the fet? At work on one line we make seat heater circuits for cars. And we had problems with fets at testing them for over current protection. They had 76A continuous current rating at same package we use in flashlights but the datasheet said 6 cm2 pcb area with a specific copper layer thickness is need for cooling. The pcb designed with 1 cm2 cooling area. So we burnt a lot fet at 32A current in the testers. Do you count fet cooling specs in when design a driver?
You can do it from the bottom but you have to be careful to not burn the pcb with the air temp too high, it takes a lot longer this way. I generally only do this for small components that could be blown off the pcb.
For the FET you just set the temp correctly and then aim it directly over the FET, as long as you are using a hot air gun with the proper temperature the FET will be just fine. You can use a piece of normal solder under the FET but solder paste is much easier and makes it a very simple process.
I didn’t do a lot of technical calculations for the FET cooling but it has a fairly large copper pad for cooling and the wires also act as heat sinkes as well. I did check the FET temperature under load and it stayed well within spec even under extreme conditions.
IIRC the highest temps I saw on the FET itself was around 100c or a bit more under max load and it is rated for 150c. So the temps should not be an issue with the real SIR800DP FET like I used.
