Would 4 XPL HIs or 4 XPG2s be better for running a hypothetical sustained output around 1000 lumens? Would there be any heat issues with the host and how long would the 26650 last?
I ordered the XPL-HI 3A. Wanted the Nichia but I remembered how hot my D4 Nichia got so… Hopefully we can run these at around 1000 lumen and still be able to hold on to it indefinitely. I know that my TC20 at 1800 lumen is hard to hold onto for an extended period. But I’m pretty sure the D4S is going to be quite a bit smaller than the TC20.
I’ll have to take a closer look at the firmware changes. Is there a way to go max regulated now?
So, to answer the original question, there are no known bugs to fix in V3, no current plans to change it and make a V4.
Like in V2, the user can still reset to the maximum fully-regulated level by loosening and tightening the tailcap. If the aux LEDs aren’t enabled, it may also be necessary to click the button once while the tailcap is loose, to drain any remaining charge in the driver.
Hmmm…
How long does Intl’s shipping usually go to europe?
I ordered like 5 Minutes ago and still haven’t received my light :smiling_imp:
I also ordered the XP-L Hi 5000K Version - I have 3 kinds of 26650 - the old golden 4Ah KingKong, 4,5Ah Basen 60A and the Liitokala 5Ah 50A
WHich one should give me the best result? I would choose the Basen, but I can’t find a review of those from HKJ
Firstly is the Shockli 5500 which is recommended by a lot of people on here a flat top head or a button top? As I want to get the correct ones and the sites I look at have both flat tops and button tops? Also the litikola battery you can purchase when buying the torch on the website is it possible to buy 2 batteries when ordering??
Toykeeper could you measure the screw distance on the MCPCB screws for Aux board design
it looks like 10mm from center counting pixels, but I am not sure maybe 4 inch
for Emisar lights you should prefer flat top batteries so the head spring has more direct contact to the batterie. And it’s not possible to ship two batteries as far as I know, because inside the light there is only enough space for one.
Nope, sorry. I’m still not back at my lab, and probably won’t be for a while. I don’t have many tools with me, and people might already have the D4S they ordered by the time I get back. That’s why I put out as much information as I could before I left.
in my experience you can order as many batteries as you like as long as there’s a flashlight in the package. otherwise here in the usa, when i order just batteries, they slap that giant hazmat sticker on the huge box for some tiny little batteries.
on another note, since there was no grainy white or superman blue, or robin’s egg, or parrot green, i went with basic black coupled with a whimsical 219c rose (didn’t know how to put an accent mark on the ‘e’)…isn’t it time we stepped up the color game?
My XHP35 HI had a perfect beam and theres no dreaded green or yellow. I cant stand green yellow tint. Maybe I won the Cree tint and beam lottery or maybe the HI version is better than the HD
