Sofirn SF14 should come with a warning
Sure, but 4A is enough that the voltage drop due to resistance in the spring, switch, etc needs to be considered.
Yes, but that would be an issue with poor design.
For example, the Zebralight SC5 has no issue putting out over 500 lumens and running an Eneloop over 5 amps. The Eneloop handles it just fine. But, you’re right, the flashlight probably has little other resistance to get in the way.
I don’t think there are many manufacturers that can afford to cater only to flashaholics. Even Zebralights, which are moderately expensive even by flashaholic standards, must have to sell far more lights to “regular guys” than they do to flashaholics. So there must be a market for selling $100 flashlights to lots of people. Granted, they’re probably outdoor enthusiasts and not couch potatoes, but they must outnumbers flashaholics by a large amount.
The only brand I can think of that likely caters to flashaholics (and maybe some ridiculously overpriced government contracts) is HDS. But with them you’re paying astronomical prices for a relatively unimpressive light (though very tough from what I hear). They probably have to charge so much because the volume is so low.
Sorry, but this seller may not be ready for prime time.
First it sent me a defective SF14 AFTER announcing that it had a new, improved model.
Then, when I placed a second order, for the new improved SF14, it said no stock available until Aug. 8, for a nearly two week wait. Fine, no problem. Then, suddently, it said my item was in stock.
Finally, it sent me some other model: a side switch instead of the tail switch I wanted; 18650 instead of the AA I wanted; and a confusing user interface. I would gift it, but doubtful that a non-flashaholic would want it.
Sorry dude. Contact us via email or PM us, we will make it right. You are right, it’s not Sofirn’s prime time. We are trying to survive in the market actually. :cry:
This is the thing. We sent inventory to amazon FBA warehouse, then it depends on amazon when it would be available, not Sofirn. :person_facepalming:
And then the weird issue happened, some items are relabeled! the wrong label is of SP32A V2.0!
We put the two product in different boxes and sent together. Don’t know why they are mixed up. Who relabeled our inventory? How many of them are incorrectly? amazon told they need time to investigate and can’t tell more information before they make it clear. :person_facepalming:
All right. We closed the listing of FBA, what’s all sale now will be shipped from China directly. Amazon.com
Hope amazon will make it clear and tell us what’s wrong. Below is how I was answered :frowning: :frowning: :frowning:
Just hang in there Sofirn & weather the storm. Sorry the mislabeling thing happened ar the Amazon FBA Warehouse… but that is not your fault.
It is just an unfortunate thing that happened. My SP32A V2.0 order was mislabled also. A SF14 V2.0 had a SP32A V2.O label on it.
I have sent pictures & you all are working on the problem…. good enough. :+1:
You will get it sorted out & hopefully things will go smooth.
Take care & keep going!! :slight_smile: I am liking your lights a lot!! :+1:
Well as far as I am concerned it is a shame that it appears Amazon puts the wrong (Amazon) label on the lights at the FBA warehouse in the USA & then it takes them (Amazon) 14 - 21 days to “investigate” their mistake??? :person_facepalming:
That sux, in my humble opinion. :frowning: … Amazon should own it & fix their mistake quickly.
I ordered a Sofirn SP32A V2.0 & it arrived in 2 days.
Only problem was it was a Sofirn SF14 V2.0 that had been incorrectly relabeled as a SP32A V2.0 with a label stuck on right over the original part number on the box.
See the picture below. The incorrect label has been peeled off & is now stuck above the part number on the box.
From examining the two above pictures it appears the labels of the SF14 V2.0 and the SP32A V2.0 were reversed & put on the wrong boxes.
Hopefully it won’t take Amazon 14 - 21 days to figure this out.
This is one of the reasons I don’t buy more from Amazon (apart from the aspect that most of the things don’t ship to Portugal…).
I prefer to way about 3 weeks or a month to get a thing from the original store/seller (like from AliExpress stores) than buying from Amazon! Only when I need things “faster” I order from there…
It is a shame that this “store” (Amazon) harms sellers and products from companies that are struggling to make the things right, like Sofirn (despite all the “mistakes” that Sofirn may incur in)!!
We got your back Sofirn and it is good to have a manufacturer like you on BLF, making lights, asking buyers and enthusiasts opinions, accepting small and big projects that other “major” brands don’t accept! It surely tells me (us?) that if we can count on you, you will probably count on us too :+1:
Thank you kindly for responding. I am sorry for your trouble. You seem a decent sort.
I just want my light. If possible, I prefer to order on Amazon. My cc was hacked while ordering through an overseas outlet (not you) and I would like to be able to order a flashlight without having that trouble again.
Please see my PM and thanks.
I’ve had Amazon send the wrong item due to mislabeling. Contacted them, they sent a replacement, and said to keep the other item. I’m not sure who eats the cost when that happens, but it does happen.
If those ASIN bar code labels were pre-applied by Sofirn before shipment to AMZ, then the latter seems to be clearly at fault.
Bezos’ minions who received and processed those shipments should have noted the ASINs, and applied the correct descriptive labels.
But, one could argue that Sofirn’s generic packaging might have helped bite them in the rear as well. OTOH, the item I mention above was clearly identified by the package as not matching the description on the label, so it may not matter, if those in the warehouse don’t take notice.
I’d still rather Sofirn spend the money on the product rather than fancy packaging, but perhaps some minimal labeling in descriptive, readable form could have helped.
I trust them to make it right, though.
Sofirn has already stated the stick on labels were not applied by them. They were applied by Amazon.
Which label? The one with the ASIN and barcode only? The one with that, as well as the description? Or both?
The former appears to be applied in an area specifically designated for labeling, which suggests some care was used, and it was pre-applied by the sender, like bulk mail submitted to the post office.
The latter, based on my experience, is usually placed haphazardly, like the tail on a donkey, and there’s no doubt only AMZ was involved with it.
If AMZ (mis)applied both, that the possible downside of using generic packaging becomes that much more apparent.
One “label” is printed on the box itself. It is part of the box.
The “stick on” label with the description was ‘stuck on’ the box over the original one that is printed on the box itself. This is the one Sofirn says Amazon added at their warehouse in the USA.
It’s not printed on. I have a SP32A 2.0 box on the desk in front of me with nothing but a blank field inside those alignment marks, direct from Sofirn via AX.
Look again. The two pictures above show boxes with stickers of two different sizes, placed askew and in offset positions. The one with the larger sticker is rotated about 5 deg clockwise and covers the lower right mark. The smaller one doesn’t even cover the same space and isn’t anywhere near that alignment mark. If that’s a printed result, Sofirn needs to find someone else to produce their boxes.
Logic alone should indicate that Sofirn isn’t going to print Amazon’s SKU numbers on all their boxes, never mind with such a crappy result.
Yeah your right, it is not “printed on the box”. Mine was on so straight I just thought it was printed on the box… until I just checked again. My bad. :person_facepalming: … :+1:
BUT the bottom line is the wrong label was put on by Amazon. End of story.
And yes… the wrong label is the larger one that covered the smaller one.
Pick any SK98 or SK68 and lookit the reviews. They’re interchangeable. Reviews for the ’68 have complaints about some weirdo battery it needs (ie, an 18650), and reviews for the ’98 grex about getting a teeny light that takes AAs (ie, the ’68).
So does anyone think they’d know the diff between a SF14 and SP32A?
I’m not exactly sure who the “they’d” is your referring to LB…… but if they can’t tell the difference between a AA, 14500, & 18650 or a SF14 V2.0 & a SP32A V2.0…… they need to regroup. :smiley:
Amazon, the way they horrendously conflate reviews.
You read some of them and sometimes ask, “wotnahell are you describing??”, because they don’t match.
Oh… I see LB. My bad, I’m kinda slow it seems. :wink:
https://www.amazon.com/BESTSUN-SK98-Flashlight-Flashgliht-Adjustable/dp/B00X0QFZ06
SK98, right? Eg:
alpine
1.0 out of 5 stars
Does NOT use 18650 battery as advertised. DO NOT PURCHASE
November 18, 2015
Verified Purchase
This does NOT take a 18650 battery.
I have tried several different 18650 batteries, none of them will physically fit.
it takes AA battery.
I have 2 of these, one lasted for about 2 hours, the second one lasted for about 25 seconds.
DO NOT PURCHASE THESE.
…and so on.
/\…. Yep, I see what your talking about. :smiley: :smiley: :smiley:
