I don’t think any of those fans are small enough. The smallest I saw was 60mm. For a flashlight you need much smaller, like 30mm. I didn’t see that, at least for under $45. I stopped looking after that as the sizes kept going up.
Surely somebody makes IP68 rated fans in smaller sizes, right?
I do spot some 40mm in the $55 range. That’s still pretty big.
I’ve always claimed it doesn’t favour flooders because of the Pre-diffused tube sidewalls absorbing spill/flood but people on here can’t be educated and scammers are free to scam.
About the fans, in the german video u can clearly see, it looks 30 or 40mm ? if the final will have those who knows…
What they should also do is some form of oled display or something like imalent or olight to show output etc? if just a button and its gonna glow red when low battery thats kinda weird for a light of this size…
Hello KG_Tuning, you have made your thoughts on the TA Tube abundantly and redundantly clear. Any further comments by you on this subject will only serve to stir the pot and generate arguments, so please drop the subject in all threads on this forum. Thank you.
If the same driver and emitters used in a super wide flood host and a thrower host results in about the same lumens measured in the TA tube, that clearly shows the TA tube doesn’t favor flooders or throwers. Really how difficult is that to understand? If you refuse to use reason and logic, there is no way we can help you get to the bottom of your issues.
Sorry sb56637, I was trying to give a few facts to help KG clear his misunderstanding of the TA tube but now realizes it is futile. I won’t continue this discussion further.
I just realized this light isn’t going to be like a brighter X65. I was hoping for a high lumen thrower like, “And f••• that guy in particular waaaay over there.” But looking at the reflectors it’s going to be more like an Emisar D1S is trying to escape getting eaten by an X80.
Still excited but maybe not the instabuy I thought it was going to be.
I was going through the throwers on parametrek when I realized the X65 had more throw than the X70 and I thought, “Wait wait wait. What?” And that’s when I finally looked at the head of the X70 and realized just how monstrous an X70 would have to be if each LED had a reflector like the X65 does. It would have to be vehicle roof mounted!
Where do I write the check out to? (Just kidding my wife would kill me.)
Edit: would be a great recommendation for all the people asking for a “self defense flashlight.” “Buy this thing, it’s a medieval mace with +3 fire damage.”
Isnt lights like this meant to just shoot tons of light like crazy vs throw very long? not really like throwers even tho this one is gonna go for like 1km it still impressive but u wont get that tight beam tho. Also u can take a swing at someone in case self defense would be needed lol… Im curious how the final version will be like and if they ditched the fans it means they had same issues olight had…
If neither acebeam or olight can manage to produce lights with active cooling then it seems something is wrong no? because waterproof fans etc exist so i dont get it ?
I doubt they can go fanless, even the x9r if i run for almost 3m it gets quite hot at the head, so that much more lumens is almost worthless if they go full passive since that light will produce more then what 220W of power ?
