GearVita New Arrival: $6.99 Yeelight YLYD09YL Night Light - Photosensitive Sensor, Plug and Play, Ultra-low Power Consumption
Fenix UC35 has been upgraded and now comes with a second generation version - the Fenix UC35 V2.0 flashlight, it is a pocket-sized, compact tactical flashlight featuring micro USB recharging, with exquisite appearance, far-reaching beam and one-handed operation.
It is fitted with a CREE XP-L HI V3 LED that delivers a maximum output of up to 1000 lumens and a max distance of 266 meters. One tactical tail switch and one functional side switch control five output levels and strobe mode. Boot-up battery level indication ensures users are well-prepared.
The included Fenix 3500mAh 18650 Li-ion battery, plus compatibility with cold-resistant CR123A batteries, thoughtfully caters for the demands of various application scenarios. The Fenix UC35 V2.0 is your perfect tactical flashlight for military, policing, outdoor lighting and emergency standby.
2018 upgrade improvements over prior UC35:
● XP-L HI v3 LED provides greater brightness, efficiency and throw.
● Improved stainless steel side switch with battery level indicator.
● New body design is more compact.
● Includes higher capacity 3500 mAH rechargeable battery for longer runtime.
● USB port improved to charge faster and is easier to activate.
● Improved waterproof and dust-proof rating (IP68).
Product Features:
● Cree XP-L HI V3 LED, with lifespan of 50,000 hours.
● Powered by one 18650 rechargeable Li-ion battery or two 3V/CR123A Lithium batteries.
● 5V/2A Micro USB rechargeable, included 18650 rechargeable Li-ion battery.
● Battery level indication and low-voltage warning function.
● Digitally regulated output maintains constant brightness.
● Reverse polarity protection to protect from improper battery insertion.
● Anti-roll and anti-slip body design.
● Tactical tail switch features instant activation.
● Functional side switch for output selection.
● Made of durable high-strength and oxidation-resistance aluminum.
● Premium type HAIII hard-anodized anti-abrasive finish.
● Toughened ultra-clear glass lens with an anti-reflective coating.
It is now available at GearVita.com, see more details please click: https://gearvita.com/fenix-uc35-v2-0-usb-rechargeable-flashlight-1000-lumens.html
The Fenix LD02 flashlight is an AAA-powered flashlight in Fenix's legendary LD series. Its compact power source makes for a compact device that can go with you anywhere you need it. Whether you're hiking through the back country or navigating the urban jungle, you're sure to be in countless situations where a powerful flashlight will get you out of a jam. Ultra-tough construction ensures you can rely on this light when you need it most.
Product Features:
● Cree XP-E2 LED with a lifespan of 50,000 hours.
● Three modes of operation.
- High: 100 Lumens (45 min. using Ni-MH battery; 30 min. using Alkaline battery).
- Mid: 25 Lumens (4 hr. 15 min. using Ni-MH battery and Alkaline battery).
- Low: 8 Lumens (14 hr. 30 min. using Ni-MH battery and 15 hours using Alkaline battery).
● Digitally-regulated output: maintains constant brightness.
● Broad beam lens provides soft, even beam for close-up illumination.
● Push-button tailcap switch for one-hand operation and output selection.
● Made of durable aircraft-grade aluminum with rhombic knurling.
● Premium type 3 hard-anodized anti-abrasive finish.
● Waterproof to IPX-8 standard (under water up to 2 meters).
GearVita.com offers it with the price of $29.88, welcome to buy: https://gearvita.com/fenix-ld02-mini-led-flashlight-100-lumens.html
Related product:
Fenix LD15R flashlight is a compact and handy right-angle flashlight with dual light sources: white and red lights. Powered by one 16340 rechargeable Li-ion battery, it is also compatible with a cold-resistant CR123A battery. The large pushbutton switch located on the top of the light makes for easy operation, it delivers a max output of 500 lumens and a max beam distance of 85 meters. Featuring four white and three red light output levels, plus Micro USB charging, battery level indication, two-way body clip and a magnetic tail, the LD15R will be a good aide for repair work, outdoor activities and daily use.
Product Features:
● Cree XP-G3 white LED with lifespan of 50,000 hours.
● Primary white LED for general illumination plus low light red LED preserves night vision:
☼ Turbo - 500 lumens, 1.3 hour accumulated runtime (downshifts to 200L after 5 minutes)
☼ High - 150 lumens, 2 hour runtime, 123 meter beam range
☼ Medium - 30 lumens, 13.3 hour runtime
☼ Low - 3 lumens, 110 hour runtime
☼ Red - 4 lumens, 30 hour runtime
☼ Red Signal (slow flashing)
☼ Red SOS
● Maximum beam range of 278 feet in Turbo (85 meters).
● Waterproof (not dive rated).
● Powered by one 16340 rechargeable Li-ion battery or CR123A Lithium battery.
● 5V/1A Micro USB charging, 1.5 hour charging time.
● Battery level indication.
● Two-way body clip and magnetic tail.
● Low-voltage warning reminds when battery replacement is needed.
● Constructed of aircraft grade aluminum with premium type HAIII hard-anodized anti-abrasive finish.
● Fitted with high quality optical lens.
● Heat control circuitry when using Turbo prevents damage to the LED
▹ Brightness drops to 200 lumens after 5 consecutive minutes in Turbo.
● Battery status indicator in switch
▹ From off, click the switch; indicator will show battery status for 3 seconds.
● Pushbutton switch (located on top)
▹ Press and hold switch for 0.5 seconds for on or off.
▹ From on, quick press to change brightness level.
▹ Press and hold switch for 1.2 seconds for red.
This is the first right angle flashlight on GearVita, it is unique. Nowadays, right angle flashlights are becoming quite popular. Compared to traditional flashlights where the lens and body are parallel to each other, a right angle has a head that's positioned 90 degrees to the body. This style of lights are good because they incorporate some abilities and features you don't see on the standard lights. You can buy it here: https://gearvita.com/fenix-ld15r-right-angle-flashlight-500-lumen.html
Related products:
Lumintop C01 bicycle light is a versatile rechargeable bicycle headlight, which designed for urban cycling commuting. By adopting the anti-glare multi-faceted reflector, it produces a equal ray, takes care of near and distance illuminations. At the same time, it prevents dazzle to the on coming people and vehicles. Utilizes Cree XP-G3 LED with neutral white color, it has better penetrability, even in rainy and foggy weathers. Three general output levels plus Strobe, SOS, and Beacon with a max output of 400 lumens, it meets the commuting and daily lighting demands. The built-in 1,400mAh high-capacity lithium polymer battery provides a maximum runtime of up to 10.5 hours which meets long-distance cycling requirements. Micro USB direct charging function allows you to charge the light at any time to ensure a sufficient power of your ride. Charging indicator, low-power warning, quick-release structure, IPX-8 waterproof design etc., C01 is your reliable partner in daily commuting, road riding, or in daily use.
Main Parameters:
Light Source: CREE XP-G3 LED
Switch Mode: Low / Medium / High / Strobe / SOS / Beacon
Max Lumen: 450
Lighting Distance : 100 - 200m
Voltage Regulator Support: 5 - 8 files
Body Material: ABS
Battery Type: Li-polymer battery
Waterproof: IP68
Brightness Levels and Runtime:
High: 400 Lumens ( 1h 45min )
Med: 225 Lumens ( 3h 30min )
Low: 75 Lumens ( 10h 30min )
Strobe / SOS / Beacon: 400 Lumens
Product Features:
● Utilizes Cree XP-G3 neutral white LED with better color rendering and a 50,000 hours lifespan.
● Six output levels with Low, Medium, High, Strobe, SOS and Beacon, max 400 lumens.
● Built-in 3.7V/1400mAh Li-polymer battery, provides a 10.5 hours max runtime.
● Micro USB rechargeable with charging indicator.
● Featuring low power indicator and intelligent output downshift function.
● Tapered surface reflector designed with German standard, reduce the hazard of glare to oncoming people.
● Detachable and adjustable bike mount, fit for 19-33mm diameter bicycle handlebar.
● 360-degree rotatable on the mount allows easily to adjust the shooting direction.
● One switch for fast and easy operation.
● Versatile to serve as a bicycle light and handheld flashlight.
● Made of high-intensity ABS materials, solid and lightweight.
● IP68 rated protection, 1.5 meters impact resistance.
Is your bicycle still missing a front light? Let Lumintop C01 illuminates your ride. You can get it from GearVita: https://gearvita.com/lumintop-c01-bicycle-front-light-400-lumens.html
Related products:
https://gearvita.com/fenix-bc30-led-bike-light-1800lm.html
https://gearvita.com/nitecore-br35-rechargeable-bike-light-dual-distance-beam-1800-lumens.html
Tank007 EC01 flashlight is a powerful mini USB rechargeable flashlight, it is powered by one 16340 battery and can throw light up to 400 lumen. This flashlight is good for outdoor activities like campint, hiking, riding, etc.. In addition, thanks to the bright light, it is also a good self-defensive tool for girls who often go out or walk home alone. As a magnetic flashlight, it can be a good help when you need to repair your car or do something else.
Main Parameters:
● LED Brand and Models: orginal imported USA CREE XP-G2 (R5)
● LED Lifespan: more than 100,000 hours
● Maximum Brightness: 400 lumens
● Effective Throw Beam: 200 meters
● Battery: 1* 16340 batteries (rechargeable ) or 1* CR123 batteries (non-rechargeable )
● Lens: toughened ulrtra clear glass lens with AR coating
● Waterproof Grade: IPX-8
● Anti-drop Height: 1.5 m
6 Groups of Lighting Modes:
>> Group 1: Highlight – Medium light – Low light
>> Group 2: Highlight – Strobe
>> Group 3: Highlight – Medium light – Low light – Strobe – SOS
>> Group 4: Highlight – SOS – Strobe – Slow flashing – Indicating signal (Low light flashling)
>> Group 5: Highlight
>> Group 6: Highlight – Medium light
Product Features:
● This is a mini USB rechargeable flashlight
● Could be directly rechargeable by the universal micro-USB charging cable nowadays
● With charging indicator, red light displays during the charging process and green light when fully charged.
● Tail with strong magnetism, so it could also be ighting when adsorbed on the iron surface
● With multiple dimming modes, in order to meet the various conditions
● Circuit board with memory function, so it can effectively remember each mode. Users can manually switch different modes.
GearVita offers this mini flashlight for you with the price of $29.88: https://gearvita.com/tank007-ec01-mini-magnet-flashlight-400-lumens.html
Related products:
https://gearvita.com/xiaomi-minimalist-portable-flashlight.html
I like the Tank007 EC01 a lot, but the dimensions that Tank007 gives are wrong (the length is not 124mm but clearly shorter, and I expect the diameter a bit slimmer than 24mm).
Could you measure the true dimensions of the EC01 for me?
The dimensions is 74.5mm (length) * 20.4mm (diameter) * 20.4mm (head diameter).
Thank you :slight_smile:
Tank007 E10 flashlight is a powerful outdoor mini flashlight that can power up to 120 lumens. Mini of light weight and small size, convenient for outdoor activities, it is a very practical addition to any pocket. Head, tail and tail cap are made of 304# stainless steel, combined with the black color of aluminum body, the flashlight looks extraordinary.
Product Features:
● Mini flashlight of light weight and small size working with only 1xAAA battery.
● Head, tail and tail cap are made of 304# stainless steel, combined with the black color of aluminum body, the flashlight looks extraordinary.
● Stainless steel tactical head which can be used for glass breaking.
● End click switch, convenient and practical. The flashlight can stand on tail.
● Bio-direction pocket clip can work as penclip or capclip under different circumstances.
● Three lighting modes for use in different circumstances.
● Intelligent memory function.
● Constant current circuit chip for constant brightness.
Product link: https://gearvita.com/tank007-e10-outdoor-mini-flashlight-120-lumens.html
If you think that a flashlight over the size of palm is a burden for you, then this mini flashlight will be a great choice. It satisfies your general demands for flashlights with its small body. If you don't want to spend too much money on a flashlight, it just happens to meet your need. With the price of $24.88 at GearVita.com, it is really your helpful small assistant for outdoor activities.
Related products:
The Tank007 E18 flashlight is an ultra compact everyday carry torch which can deliver up to 180 lumens on the highest setting.
It can be powered by one CR123A lithium non-rechargeable battery, or one 16340/RCR123A rechargeable lithium-ion battery. Two brightness settings and strobe are available, which are cycled through using the simple twist switch head of the torch.
The tempered optical lens lens that sits in front of the Cree XP-G R5 LED combined with the orange peel aluminium reflector provides a beam range of up to 100 metres.
Weighing only 19 grams and measuring 65 mm in length, you won't even notice you've got this handy piece of kit in your pocket.
Main Parameters:
Luminous Flux: 180lm
Throw Beam: 100 meters
Lens: Tempering optical lens
Construction: Waterproof to IPX-8 standard
Impact Resistant: Anti-drop height of 1.5 meters
Battery Quantity: 1 x 16340 or 1 x CR123 battery
Input Voltage: 0.8V - 4.2V
Burn Time: High light for 0.8hours, low light for 2.5 hours
Product Features:
● Candle finger-sized, very convenient to carry on with a keychain, when you travel, outdoor, camping ect.
● Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● Powered by 1*CR123 or 1*16340 rechargeable battery.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable.
● Anti-slip pattern on the light head, convenient to secure grip and switch mode.
● Head rotation switch, which is durable and easy to operate even with single hand.
● Six square light anti-roll body, it will not roll on flat surface.
● Capable of standing up securely on a flat surface to serve as a candle.
● Constant current circuit chip maintains constant brightness.
● Waterproof to IPX-8 standard, anti-drop height is 1.5 meters.
● Three modes of lighting can be applicable to your lighting requirements for different environments.
● Mode selection: rotate head repeatedly to select the mode needed. Then light memorizes the last mode which continued for at least 2 seconds. For example, when you switch the mode to low light, keep it for at least 2 seconds, and then restart the flashlight, you will get the low light again.
GearVita offers this compact flashlight for you: https://gearvita.com/tank007-e18-camping-flashlight-180-lumens.html
Related products:
Wuben E01 flashlight uses aluminum alloy material, it is non-slip, waterproof, and abrasion resistance. It utilizes Cree XPG3 LED, powered by AAA battery, with 3 output levels, maximum 100 lumens, all controlled by the tail switch. High, medium, low, SOS, four modes, so many brightness options are convenient for us. LED will give you stable and bright light, nonthermal radiation, safe and reliable. It is suitable for camping, fishing, hunting, hiking, searching, working.
High: 100lm ( 1h )
Med: 20lm ( 5h )
Low: 1lm ( 20h )
SOS: 20lm
Product Features:
● Hard anodizing hoursing
● Utilizes Cree XPG3 LED, lifespan of 100000h
● 100 lumens max output
● 40m max beam distance
● Powered by 1* AAA battery
● Intelligent hybric circuit
● 99% high transparent rate lens
● Precise vacuum plating reflector
● IP68 Water proof( 2m beneath water for 1 hour )
● 3 output levels
Wuben E01 is the first mini flashlight powered by 1* AAA battery among all Wuben flashlight, total length of 82.5mm, weights 29g with the included battery. Simple design and easy operation makes E01 a perfect EDC flashlight, you can check and purchase it at GearVita.com if you are interested in it: https://gearvita.com/wuben-e01-mini-portable-led-flashlight-100-lumens.html
Related products:
way too long for a 1xAAA!
wle
Tank007 PT12 flashlight is a high power tactical LED flashlight with high brightness and medium volume, suitable for military, police, seaqrching, outdoors, camping, riding, etc. Powered by high power Cree XM-L 2U2 LED with life time 100,000 hours, relatively longer burning time can meet you long time lighting need. With a specially desgned stainless steel attack point at the tail, you can broke glass and other objects to save you in emergency. Anti-incorrectly inserting battery design can protect the flashlight, even the battery is incorrectly input, the flashlight do not get hurt.
Main Parameters:
Light Source: Cree XM-L U2 LED
Battery Required: 1 x 18650 battery ( Not include )
Input Voltage: 3.0V - 4.2V
Run Time: Up to 10 Hours
Brightness: 800LM (max)
Beam Distance: 300m
Operating Modes: High / Low / Strobe
Burn Time: High - 1h 30min, Low - 10h
Impact Resistance: 1.5m
Waterproof: IPX-8, 1.5 meters underwater
Product Features:
● Made of durable aircraft-grade aluminum T6061.
● Premium Type III hard-anodized anti-abrasive finish.
● Steel optical glass.
● Relatively longer burning time can meet you long time lighting need.
● With a specially desgned attact point at the tail, users can broke glass and other objects to save themselves.
● Orange-peel reflector, high efficiency, perfect even spot.
● Scientific structure design, exqusite workmanship.
● Constant current circuit chip to maintain stable and continuous brightness.
● The circuit uses anti- incorrectly input battery so as to protect the flashlight.
● High power Cree XM-L 2U2 LED, with life time 100,000 hours.
This is really an interesting flashlight, right? If you are also interested in it, you can check the details at GearVita.com: https://gearvita.com/tank007-pt12-high-power-tactical-flashlight-800lm.html
Related products:
Tank007 UC17 flashlight is a stylish and compact rechargeable flashlight. Only with a 18650 battery achieving 800 lumens of brightness and a range of up to 300 meters, UC17 will meet your needs such as camping, riding, and searching etc. In addition, with 5 model of high med and low strobe SOS, it could suit for everyday lighting perfectly. It can also be used as a mobile power source to provide powerful lighting support for outdoor travel and emergency. With anti-slip texture and prevent overheating design, you will love with this exquisite fellow.
Main Parameters:
Emitters: 1* Cree XM-L2 LED
LED Lifespan: above 100,000 hours
Battery Type: 18650
Max Brightness: 800 lumens
Beam Distance: 200-300m
Max Runtime: 30h
Input Voltage: 3.0 - 4.5V
Impact Resistance: 1.5M
Mode: 5 modes (High - Med - Low - Strobe - SOS)
Waterproof: IPX-6
High: 800lm - 100% power ( 1.5 hours )
Med: 400lm - 50% power ( 4 hours )
Low: 200lm - 25% power ( 30 hours )
Product Features:
● Charging with indicator function, red is not full of electricity, green represents a full charge.
● Constant current circuit chip for constant brightness. The flashlights has memory function to memorize the last mode.
● Max 800 Lumens, can meet the requirement of high power lighting.
● The United States imported Cree new generation of LED lamp beads, energy saving, life of 100,000 hours, brightness of 800 lumens, battery life of up to 30 hours, meet your lighting needs.
● Constant current circuit chip which maintains constant brightness.
● Made of durable aircraft-grade aluminum T6061, hard-anodized anti-abrasive finish
● Head rotation switch, which is durable and easy to operate.
● 5 modes of lighting can be applicable to your lighting requirements for different environments.
● Powered by 1 x 18650 2600mAh rechargeable battery.
● IPX6 waterproof design, can satisfy daily waterproofing requirements.
● Intelligent memory gear position automatically remembers the gear position when it was last turned off.
● Body is light and compact, the distinctive head button design makes it easy for you to control with one hand.
Tank007 UC17 in its class is an ideal cost-effective USB charging flashlight with high quality on the market. Thanks to the practical features, it is a practical luminaire for outdoor activities and everyday use. GearVita offers it for you via this link: https://gearvita.com/tank007-uc17-usb-rechargeable-flashlight-800-lumens.html
Related products:
Tank007 E13 flashlight is a mini portable led keychain flashlight with pocket clip provided, weighs only 10g, very easy to carry everywhere, can be used as an emergency light. It is powered by 1*AAA battery, which is easily obtainable, but with 120 lumens brightness. It is switched on by simply revolving the head, with one mode design, easy to operate.
Tank007 E13 is well protected, resistance to falling and waterproofing are inherent characteristics. 1*AAA battery is enough to make it last more than 1 hour of lighting. Especially small, such as the usual small clips. If you go out or camp, it is very convenient to hang on the bag.
Main Parameters:
LED: Cree XP-E R3
Light Source: 3W LED
Power Source: 1*AAA battery
Power: 10W
LED Lifespan: above 50,000 hours
Max Brightness: 120 lumens
Beam Distance: 80m
Input Voltage: 0.8 - 3.7V
Output Level: one mode
Burn Time: high light - 0.6hours
Waterproof: IPX-8
Anti-drop Height: 1.5m
Product Features:
● Mini Portable
E13 is a very small flashlight, like keychain.
● Aluminum Material
● LED Source
● Small but Powerful
● Convenient for EDC
Keychain and clip can attach E13 to pocket, bag, belt, hat or anywhere you want.
● Simple Operation
● Wide Usage
It is suitable for camping, fishing, hunting, hiking, searching, working. Thanks to its much portable feature, it can be with you anywhere to work as an emergency light.
This mini keychain flashlight has a small body but contains great energy. You can go to GearVita to feel its charm: https://gearvita.com/tank007-e13-mini-portable-flashlight-120-lumen.html
Related products:
https://gearvita.com/olight-i1r-eos-led-keychain-flashlight-130-lumens-rechargeable.html
https://gearvita.com/nitecore-tini-rechargeable-led-keychain-flashlight-380-lumen.html
Tank007 PA01 flashlight is a mini portable flashlight with pocket clip provided, which has finger size, short and exquisite, easy to carry everywhere. It is powered by 1*AAA battery, which is easily obtainable, but with 90 lumens brightness. Professional and user-friendly design make you comfortable and convenience.
Main Parameters:
Emitters: OSRAM LED
Power Source: 1 x AAA battery
Max Brightness: 90 lumens
Throw Beam: 80m
Burn Time: High light - 0.8 hours; Med light - 3 hours; Low light - 15 hours
Output Level: one mode ( High) or three modes ( High - Med - Low )
Waterproof: IPX-8
Product Features:
Tank007 PA01 is a portable mini penlight working with only 1 x AAA battery, with waterdrop shape knurling in the tube, natural and beautiful.
● Adopt the Hard-anodized to finished the body, which makes it hardly to be scratched or faded.
● One mode or three modes for your choice, constant current circuit chip for constant brightness.
● End clicky switch with feel comfortable.
● With a pocket clip, it be can be put in your pockets, which is very convenient to carry.
● Unique golden ring embedded in the connection between battery tube and the tail part, harmonious, graceful and royal.
● With diffusers specially designed, it can work as a camping lamp, signal stick or bracket light.
● Very brightness with a small size, a good choice for no matter outdoor or home use.
Carry the PA01, its beautiful design and powerful light will make you outstanding in the crowd. Of course the price on GearVita is as cheap as ever, only of $14.99: https://gearvita.com/tank007-pa01-pocket-led-flashlight-90lm.html
Related products:
I have copied the “quote” from above the OP, so technically is was not in previous post.
And there was no mentioning of using it as a caplamp in the post before this one.
But: how can we use it as a caplamp, when there is only one groove in the body: at the tail side.
Unless the body can be reversed, of course
The bio-direction clip makes the flashlight a caplamp or pen light, Tank007 official website is written like this.
I’ve read that. Question remains: is the body reversible? Because there is only ONE groove for the clip.
This clip is bidirectional, which means that the grooves at the head and tail are all available as clips, so that the body don't need to reverse. I think this sentence should mean this although I don't know if this is feasible.
