ENEDED
Ordered one NW White/silver. Thanks freeme!
Interested in one black NW XHP70.2 P2. Thanks.
Interested
Interested.
Black, NW,90 CRI if possible.
From what I know, the NW 4800k LED is only 80CRI, not 90CRI.
What about CW? What CRI is it? Also 80?
Cool white is standard 70CRI.
Interested in NW
Ordered one black NW.
In the post #1 it says 5mm.
BG 12th Anniversary Sale Price: $95.20 ( usual $119 )
Coupon: AC18
interested
I am interested in the NW version. Sign me up please.
Any chance at a host?
Only full light.
Thanks for the coupon code FreeMe. Good enough price for me. I placed an order: White with NW emitter. BG was low on stock on hand. I may have gotten the last white one in stock. Will power it with 4 Orbrtronic 3120mah 18650s which together can push out a continuous 120 amps.
I’m afraid your mistaken. There are no 18650 cells that do 30A continous at anywhere near 3000mah. Orbtronics have the rating wrong on this battery. Actually, they try your word it cleverly so as to trick people.
After digging around for awhile I found some info that points to this battery being a Sony VTC6 under the wrapper. HKJ tests this as a 15A continous cell.
Sure, it can sort of do 30A continous, but it will overheat like most batteries. You have to manually reduce the load once it gets to 80°C. This is not the definition of continuous. For it to truly be continous, it needs to not exceed 80°C from start to finish.
Yeah nooo.
That VTC6 rewrap is rated to 30A per cell is not continuous, but rather until temps reach 80°C.
The VTC6 is rated at 20A continuous discharge rather. So you will still get 80A at 3,6V, 40A at 7,2V, and 20A at 16,8V.
So yeah, a lot of power is in your hand, but not 120A.
Both Mooch and HKJ showed it went over 80°C at 20A so they rated it 15A continous.
In short pulses like 6 seconds, the VTC6 can do 80A. Four of those is 320 amps! It’s just for 6 seconds, though. :smiley:
Thank you for your support!
