Lexel can you measure the optic and see if larger domed LED’s fit under it (like LH351D). Fireflies seem to think it wont fit but that would surprise me if that was the case.
I’m really interested in what kind of runtimes we can get out of the highest regulated output for the Nichia version and if heat is an issue. I’m assuming that’s 1-1500 lumens?
Hoping I won’t regret not ordering the XPL HI version which has more throw and nearly twice the output. I was thinking the 3D tint might be too cool and the 4B tint might be too green. So I chose the Nichia, which should have great tint but won’t have the wow factor of the 3D.
The switch bezel looks to have the little notches on the inside edge. So it looks like it’s threaded. Whether or not you can unscrew it without scratching it depends on your snap ring pliers and your skill.
As far as it being glued as well, maybe someone can tell us.
I’ve got a light with what may be a press fit bezel. I was thinking of sliding a dull razor blade under the edge to try and lift it. It may scratch the finish, so I haven’t tried yet.
The black ROT66 has a black switch bezel though, painted, I guess. Probably more chances to scratch that one. I’ll try to print some plastic tool for removal when necessary.
Or I simply might remove the paint from the bezel, if scratched.
