The excell sheet is big, with lots of other led data as well, and I’m not too handy with excel so slicing it to size already is a challenge.
I hope the raw data will do as well? :innocent:
You should be ok with a (direct drive) triple on one 18650, if it is over 15A you get in the danger zone but with its Vf a bit higher than the 219B you will not get there. More likely you will end up at 9-12A which would be perfect. To be sure you can start with springs without bypasses and measure current.
I made a Jaxman E2L triple (shorty) with the SST-20 3000K 95CRI, to see how the led behaves in TIR optics.
Unfortunately I only had a frosted triple Carclo optic while I wanted a clear one for this build. I half polished it so that it now is in between clear and frosted.
The driver is a BLF-A6 driver. I will make a lighted tail later so I added a 680 Ohm bleeder resistor. Also I ‘fixed’ the driver from voltage spikes on the CPU as suggested by DEL (not really needed for the very tolerant Attiny13 in the BLF-A6 driver but I did it anyway).
I did no spring bypasses because I do not want to over-stress these leds and this small light with so many amps will become too hot too soon anyway.
The beam is very smooth with no disturbing tint variations, perhaps a true clear narrow optic would have produced a more distinct hotspot.
The tint and CRI has not quite suffered from this optic, to state it lightly, it is as nice as you will ever want it to be.
Hotspot at a mode under 350mA (so regulated at 350mA, ~120mA/led):
Outside the hotspot at a mode under 350mA:
Hotspot at max (on a Vapcell 18350, 1150lm, about 8 amps, ~2.7A per led)
Yes the wall is white, and I even made the effort to post-edit the white-balance of this pic to match my phonescreen with what I see in reality. (which will be a bit different again on any other screen of course).
At under 3000K the light will appear yellow anyway, even under the BBL, it is the added rosiness that makes it look so good (or boring for that matter, it is indistinguishable from a halogen spotlight).
I can not measure that now because I have no bare led reflowed at the moment to check just a few mA. The triple at moonlight is of course a PWM-ed 350mA so if moonlight is made that way the tint will be just as good.
I think they might have recently revised their triple boards to be compatible with Carclo optics because I just tried the Carclo and it fits perfectly. It’s interesting that KD sells the triple emitters soldered to the board for so much cheaper relative to buying single emitters.
And please remember that kd triple MCPCB is only 1mm, so carclo legs HAVE TO be shortened to ensure proper tension and thermal contact with a pill / shelf.
