Which one of your AT40’s is the bigger one? The quad mule or the 2 x XPG-3? I thought they were the same size, but according to your photo one is bigger than the other.
Where can I get a clip like that (on your Manker E14) for my Manker E14?
The 4* nichia is 100mm long. The 2* xpg3 is 98mm long. The difference is in the bezels. Upon checking this I found an o-ring missing on one of the heads The threads are also anodised so feel a little rough, no biggy but just saying.
The pocket clip on the e14 is a steel one that came as a spare with a used light I bought a couple years ago. It looks a lot like the ti mcgizmo clips that Lightknot was selling a short time ago but it looks like he’s sold out and I don’t know where you can get them now.
With the sudden surge in demand, QC issue can arise from smaller manufacturers is inevitable. If you got a DOA, just contact customer service for full refund.
The good:
-Much better build quality than expected
-Decent output and lots of room for modding
-Nothing is glued (except for driver)
-The clip is extremely solid
-Aluminum pill does an good job, but this light is not ready for some FET action. I’ll be keeping the stock driver.
The bad:
-Rear switch doesn’t have a spring but a brass plate that is very thin and rather large in diameter, so if you’re using batteries that are wrapped a bit more towards the center or have double wrapping it won’t work. Maybe this is why many are reporting DOA units. Fortunately that can be fixed with a spring but you’ll have to take the light apart.
-Front oring needs to be thicker
For those who can’t remove the tail cap, it’s most likely the clip that is pressing against the body. Just take off the clip and you’re good.
Overall a very nice flashlight and great value for the money. I’m modding mine soon and post the outcome here.
I wondered what was going on with my light last night. Turned out to be low voltage warning. Last night I checked the battery and it seemed to kick in the warning (on high mode) about 3.6v. Today at work I played with it again and the frequency of the dimming seems to have increased as the voltage gets lower. I don’t know if the light will shut off at some point and am reluctant to run the battery down to find out as it is unprotected and I have no multimeter or charger to check the battery voltage.
Low the voltage higher the frequency
Edit: when I was able to check battery voltage I kept running the light. Voltage got down to 2.7v with no shut down.
HELP!
I just got my Amutorch AT40 Nichia from the mail and its DOA! It is Not working… Can somebody tell me what can possibly be wrong with it? I’ve searched the internet and it seems to have some problems and I just can’t get it to light up… Thanks in advance!!!
It is DOA is always a very difficult question to answer. It helps enormously if you start by checking the obvious yourself first (like does the battery make contact on both sides)
Yes, I’ve checked and both positive and specially the negative on the tail do have contacts. I’ve also checked to see if the battery is working and it is working.
