The dots line up fine. And the switch clicks fine as well, you feel a good click and you hear it too, the response to the click (or hold) is just not there, as if the contact surfaces inside the switch are very dirty or something. But Iâm not going to solve this tonight, tomorrow there is another day!
Even after being removed the driver presses back into a snug fitting position, even after a few removals. So it at least doesnât get all loose and floppy after the glue is broken at the driver shelf. And yes, there is that bit of like Elmerâs glue holding the driver in place, ears/tabs or not, the driver isnât shifting around not even after being removed.
About the only difference I see is that the GT Mini has a bit tighter corona.
DrDevil, do you have a lux meter? Have you done a side by side candela measurement?
Seperate reports have shown they should be about 130kcd to 135kcd. Itâs not like anyone could see that difference, but I was just curious to see both measured with the same meter and under the same conditions.
how would u do bounce test on your ceiling anyways? i have a few apps that shows lux but how actually do it proper? Would that even give an estimate on actual lumens ?
Iâve found it to not be very accurate at all due to lights having different beam shapes, etc⌠Itâs also not comparable to anyone elseâs numbers as you have differences in table heights, ceiling textures, paint colors, etc⌠I never used a phone app, only a $30 Dr Meter LX1330B.
Basically you find a table or something similar and mark you a little spot to always tail stand your light. Then I mark a spot about 6 inches to one side to put the meter. Using the same light and meter orientation will give you repeatability.
Since light is additive, I turn off most of the room light except for a little lamp. I read this ambient level and later subtract it from the total. Then I turn on the flashlight and wait for it to either stabilize or hit the 30 second mark, whichever comes first.
Iâve never tried to equate it to lumens, but it does show me small changes in a particular light. Such as doing an emitter swap, spring bypass or a resistor mod, etcâŚ
Itâs not very good for comparing different styles of lights. Throwy beams and floody beams of the same lumens can give pretty different results due to the way the light reflects from your ceiling back to the meter.
If you have similar lights it can tell you which is brighter/dimmer etcâŚ
Of all the different ways to measure lights, the candela or throw distance is the easiest. If you ever wanted to try it, you just need a $15-$30 lux meter and a tape measure. Here is a video showing the procedure.
In the ceiling bounce test, concerning ambient light, I have to ponderâŚ. if a lamp is on in the room and there is a very slight reading on the meter, does the 1200 lumen light hit the ceiling and add to the 2 lux already on the meter? If youâre running the test and have someone turn off the lamp, does the meter reading change?
If itâs daylight outside but the blinds are closed such that there is a low level of ambient, does that actually influence the meterâs total reading when the light is turned on? Can you add 3 lux of ambient to 135 lux produced by the flashlight and get a measurable gain? What about adding 3 lux of ambient to a flashlights 665,000?
So, at what point does a bit of low level ambient light actually matter? I mean, I know some people that do their lux tests in a blacked out basement, as if it really matters. Just wondering is all.
Iâd test my GT mini compared to one of my D1Sâs but of course, all are modified so it wouldnât be an exact comparison. Wonder if I could swap reflectors in one of em and see a difference? HmmmmmâŚâŚ
Yes. If my room light is showing 88 lux and I do a ceiling bounce test of a light on low which is only 2 lux, the meter goes up to 90 lux.
The point that it starts to matter is subjective. Consider the percentage of difference. Some people might think they should compensate for anything over 1% difference.
In your example of a light measuring 1200 lux and a lamp adding 2 lux, the lamp is only adding 0.16%. So I would say that 2 lux is irrelevant.
Did you actually mean 1200 lumen? Letâs say that 1200 lumen light measured 175 lux on a ceiling bounce. Now the 2 lux would be 1.1% of the reading. This is a big iffy. If you got a steady 175 lux then, sure, why not subtract the 2 extra lux. If the lux was rapidly falling while waiting for the 30 second mark, then itâs probably not a big deal.
BTW, adding 3 lux to 665,000 lux would be 0.00045%. Irrelevant, of course.
Adding 3 lux to 135 lux is 2.2. So yeah, you might want to subtract it. It depends if 2.2 is a big deal to you or not.
I ask because lux is not additive as lumens is. If you put 4 1000 lumen emitters in a single flashlight then you are indeed likely to get 4000 lumens of output, but that doesnât mean the lux will go up the same way, itâs not linear like the additive lumens. So say you measured the Convoy C8 with a given set-up, then MRsDNF builds a light using 4 Convoy C8 reflectors and the emitter/driver set-up is the same to each one as was in the original C8. Youâll see the lumens go up exponentially, but not the lux. So adding 135 lux to a room of 3 lux isnât likely to show the low ambient on the meter, it simply getâs overridden. And the candela reading we usually use is all about the intensity of the hot spot, a ceiling bounce totally diffuses that to the point of irrelevance. Lux is subjective here because itâs not taken in the standard context.
Shine a low output light on the wall, then shine a high power light on top of it. The overall brightness of the spot on the wall doesnât get bumped (that you can see) by the addition of the low level light. The low level light just getâs over ridden.
All this seems obtuse to me and is confusing. Of course, my health for the past 18 years doesnât help with this kind of thinkingâŚ
This is meaningful to me on the basis of the fixture I am building to aid the growth of my pepper plant. I am changing from a single 90 CRI 5000K COB to a mix of 5 high CRI COBâs of 3 levels of temperature in order to introduce some red into the spectrum. How it all mixes and the apparent overall output will mean I get great peppers or I wasted my time and money. So, thus , the relevance to me about how all this works.
I think you are describing a personâs perception of light as opposed to measuring it with a high precision device. Our eyes can not see small differences in brightness like your describing.
As an example of just how bad our eyes are at detecting brightness levels, I was watching the output of my ODF30 light on Turbo. It stayed steady at about 3000 lumen then started to ramp down to 1900 lumen over a 35 second period. I didnât even notice. I wasnât specifically looking for it, so when it happened I didnât notice it. If it had abruptly stepped down it would be noticable.
I typically can not tell a 500 lumen light from a 600 lumen light when held side by side. I can stare at it on a wall and guess which is the brighter, but Iâm not positive.
This is why we need to measure things and not use our eyes.
Sorry, I canât help on the grow light stuff. I donât know anything on that subject.
I guess Iâm just used to taking a lux reading at the center of the hot spot for Kcd reading, which in turn determines throw. Using a diffused light from the ceiling bounce just doesnât compute as Iâve never done that, always had a light box since I got a meter.
From 5 meters, shine the light on the meterâs sensor and multiply the reading x25, then take that reading and multiply times 4 and use the square root of that answer for throw.
Ceiling bounce lux is an obtuse number, it doesnât line up with anything from the manufacturerâs or the normal mind set of what a light is doing, ie: itâs not lumens, itâs not Kcd, itâs not throw. Itâs making do with part of the equipment or simply not using the meter in a term that weâve used for some years now to establish lux as the intensity of the hot spot⌠135Kcd as this light has been measured.
Iâm coming off pretty much a solid workweek of bad days and meds, so itâs probably just me not making sense. Sorry.
