Mine shipped on the 3rd, still in china…dont worrie…you should probably get next week.
Mine has been there since July 31st. Looks like US lights are all stuck there.
Mine (US order) was updated on 08/03 to “Dispatched from sorting center” at Guangzhou. Not sure if that’s actually different, or just different tracking systems interpreting the status differently.
Yea from china routing via PostNL in europe seems to go very fast so i think u guys in USA will get next week sadly
have you all cells included?
maybe the shipping restrictions do not allow airmail and you get yours via boat?
No battery in mine
No, just the light, diffuser, and holster for me. Paid on 07/13, so not exactly front of the line, but not at the back, either.
Oh man, I hope the 18350 cells aren’t why mine is so delayed. If that’s the case I probably won’t receive mine for at least another couple weeks.
Mini GT, battery, diffuser, & a few holsters for me.
Mine is either….
- Still sitting in China
- Held up in customs at JFK in New York
- Strapped to the back of a Sea Turtle & headed this way……
See below….
It seems both occurrences happened the same day, hour, & minute. :person_facepalming:
2018-08-03 22:46
Guangzhou, leave Guangzhou send to Guangzhou courier company
2018-08-03 22:46
Guangzhou, leave Guangzhou and send to JFK Airport in New York
My GT Mini’s arrived today. Excellent packaging! :+1:
What a great little light! I’m very satisfied with my purchase! Thank you so much! :+1:
great to get all that positive feedback
I got mine today in the USA so maybe the rest of the USA orders will show up soon.
Here are my measurements from a stock CW GT Mini using a Samsung 30Q.
Tail amps @30s using UT210E:
Top of ramp - 2.85A
Turbo - 5.5A
Parasitic drain normal - 0.18mA
Drain with switch led off- 0.02mA
Candela @30s and 10 meters using LX1330B:
GT Mini - 148kcd = 769m
Convoy C8 xm-l2 CW - 39kcd = 395m
Stock GT - 1.05mcd = 2,049m
Lumens using Texas_Ace Lumen Tube calibrated from Maukka’s S2 plus CW:
GT Mini:
Top of ramp:
turn on 720 lm
@30s 705 lm
Turbo:
turn on 1240 lm,
@30s 1200 lm
Convoy C8 xm-l2 CW
turn on 850 lm,
@30s 785 lm
I would take my lumen measurements with a grain of salt. My tube had to be really dialed down to read accurately to Maukka’s calibration light. I’m still working on this. Even so, 1200 lumen is pretty much on spec. I’m sure other lumen tubes and devices will read higher, maybe much higher. No doubt that the 148kcd @30s is quite impressive. Higher than spec. :+1:
This is a very impressive light. It truly blows away my Convoy C8.
Someone asked me if the Mini really does blow away the C8. I went and took some pictures, but the question got deleted.
Anyway, here is a comparison of the hot spots at a reduced level, but the same relative brightness as if both were on turbo. You can clearly see the Mini has a much smaller, tighter and intense hot spot.
In this picture I had both lights on turbo and the camera sensitivity turned way down. The C8 looks like a corona that is missing the hot spot.
So yeah, the mini really does blow it away.
Yes, protected seem to fit fine. I have a 69mm Keeppower 8A protected Sanyo GA 3500 and a 69.5mm Evva 7A protected Panny B 3400.
The tail springs can collapse down really far so that shouldn’t be an issue.
The thing you should be aware of is the amp draw on your protected cells. If their protection circuitry is only 3 amp then you may not be able to run the GT mini on Turbo.
I measured my Evva at 4.1v and got 2.2A top of ramp and 4A on turbo.
My KeepPower at 4.1v got 2.2A top of ramp and 4.3A on turbo.
how about your D1S?
I know I gave Lumintop a hard time about adding the big logos on both sides of the battery tube, but after holding the light in my hand and seeing just how small the logos actually are it doesn’t bother me. So I overreacted a bit.
I showed the big and little GT to my cousin and he said cool. Then I showed him both versions with the short battery tubes. He could help but giggle just like me. It’s a cute little sucker. Lol
how about your D1S?
Me? I don’t have a D1S.
I’m sure there wouldn’t be such a huge difference if you had an Astrolux C8 with FET driver and xpl-hi. Mine is a regular Convoy C8 with 8 x 7135 = 2.8A with dome-on xml2 U2-1A and Guppydrv.
Sorry about that. I edited it and hit the delete button instead of the save button. Not the first time I've done that!
Wow, those pics say it all thanks The difference between the mini and C8 is significant, thanks JasonWW. I'm just about to order the mini after looking at the comparison shots.
That’s an XM-L based C8, right? The difference is still impressive, but it needs to be pointed out that a modern XP-L HI C8 would outperform the C8 in the photo by a decent margin.
Good point as I have both and my XP-L HI C8 is quite a bit brighter than my XM-L C8.
Sorry about that. I edited it and hit the delete button instead of the save button. Not the first time I’ve done that!
Wow, those pics say it all thanks The difference between the mini and C8 is significant, thanks JasonWW. I’m just about to order the mini after looking at the comparison shots.
I just added the distances to the candela ratings. The C8 got 395 meters, the Mini got 769 meters. That’s almost double the distance! It’s like a C8 on steriods. Lol
