my Bistro HD OTSM drivers are not affected by a bleeder resistor for tail switch lighted
on e-switch lights nothing gets affected by switch or TIR LEDs
but a Tail clicky light with TIR has the problem as no ground is available when the tail is off, so wont work
first Emisar D4 sucessfully modded
as I had no feedback on the solder pads distance the first batch is 0.7mm off but no problem to solder even 0.75mm² wires if carefully filed the holes to one shape
the ones with Gen 3 LVP will be different, holes distance will be right and no filing as I routed wires between the 3 center holes
This is first board made, I had some mishaps like blowing it with hot air from reflow plate as the 0.6mm thick weights like nothing half the components fell of
ripped solder pad removing a resistor but in the end it works
Note that I have not ordered yet 0402 resistors so they are all 0603 too big for pads but it works at least, the 2 capacitors are 0402 and fit nicely
also replaced the original 0.35mm² wired with 0.75mm²
future board will look nicer
I would love to buy one of these with amber LEDs to replace the blue in my D4S. I am looking to make a no-blue nightlight mode. Also would be interested in amber or red for the D4. Lexel, any idea when these will be available for sale?
