[M4Ddeal active] : Lumintop GT Mini - 2 authorized deals
402 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 35 min 44 sec ago
have you all cells included?
maybe the shipping restrictions do not allow airmail and you get yours via boat?
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
shirnask
shirnask's picture
Last seen: 22 min 13 sec ago
No battery in mine
Delta_V
Last seen: 1 month 6 days ago
No, just the light, diffuser, and holster for me. Paid on 07/13, so not exactly front of the line, but not at the back, either.
AgentWhiteBread
Last seen: 6 days 2 hours ago
Oh man, I hope the 18350 cells aren’t why mine is so delayed. If that’s the case I probably won’t receive mine for at least another couple weeks.
teacher
teacher's picture
Mini GT, battery, diffuser, & a few holsters for me.
Mine is either….
  • Still sitting in China
  • Held up in customs at JFK in New York
  • Strapped to the back of a Sea Turtle & headed this way….. Wink
See below…. Big Smile
It seems both occurrences happened the same day, hour, & minute. Facepalm
2018-08-03 22:46
Guangzhou, leave Guangzhou send to Guangzhou courier company
2018-08-03 22:46
Guangzhou, leave Guangzhou and send to JFK Airport in New York
Icarus
Icarus's picture
Last seen: 10 hours 24 min ago
My GT Mini’s arrived today. Excellent packaging! Thumbs Up
What a great little light! I’m very satisfied with my purchase! Thank you so much! Thumbs Up
M4D M4X
M4D M4X's picture
great to get all that positive feedback
JasonWW
JasonWW's picture
Last seen: 13 hours 24 min ago
I got mine today in the USA so maybe the rest of the USA orders will show up soon.
Here are my measurements from a stock CW GT Mini using a Samsung 30Q.
Tail amps @30s using UT210E:
Top of ramp – 2.85A
Turbo – 5.5A
Parasitic drain normal – 0.18mA
Drain with switch led off- 0.02mA
Candela @30s and 10 meters using LX1330B:
GT Mini – 148kcd = 769m
Convoy C8 xm-l2 CW – 39kcd = 395m
Stock GT – 1.05mcd = 2,049m
Lumens using Texas_Ace Lumen Tube calibrated from Maukka’s S2 plus CW:
GT Mini:
Top of ramp:
turn on 720 lm
@30s 705 lm
Turbo:
turn on 1240 lm,
@30s 1200 lm
Convoy C8 xm-l2 CW
turn on 850 lm,
@30s 785 lm
I would take my lumen measurements with a grain of salt. My tube had to be really dialed down to read accurately to Maukka’s calibration light. I’m still working on this. Even so, 1200 lumen is pretty much on spec. I’m sure other lumen tubes and devices will read higher, maybe much higher. No doubt that the 148kcd @30s is quite impressive. Higher than spec. Thumbs Up
This is a very impressive light. It truly blows away my Convoy C8.
Someone asked me if the Mini really does blow away the C8. I went and took some pictures, but the question got deleted.
Anyway, here is a comparison of the hot spots at a reduced level, but the same relative brightness as if both were on turbo. You can clearly see the Mini has a much smaller, tighter and intense hot spot.
In this picture I had both lights on turbo and the camera sensitivity turned way down. The C8 looks like a corona that is missing the hot spot. Big Smile
So yeah, the mini really does blow it away.
klrman wrote:
Do you know if it has enough room to run the protected 18650’s?
Yes, protected seem to fit fine. I have a 69mm Keeppower 8A protected Sanyo GA 3500 and a 69.5mm Evva 7A protected Panny B 3400.
The tail springs can collapse down really far so that shouldn’t be an issue.
The thing you should be aware of is the amp draw on your protected cells. If their protection circuitry is only 3 amp then you may not be able to run the GT mini on Turbo.
I measured my Evva at 4.1v and got 2.2A top of ramp and 4A on turbo.
My KeepPower at 4.1v got 2.2A top of ramp and 4.3A on turbo.
chinooker
chinooker's picture
Last seen: 6 hours 43 min ago
how about your D1S?
JasonWW
JasonWW's picture
JasonWW wrote:
M4D M4X wrote:
Neal clarified :
Martin or Neal, can you clarify if it will have the big letters on the battery tube? This is a last minute change that really bothers me.
I know I gave Lumintop a hard time about adding the big logos on both sides of the battery tube, but after holding the light in my hand and seeing just how small the logos actually are it doesn’t bother me. So I overreacted a bit.
I showed the big and little GT to my cousin and he said cool. Then I showed him both versions with the short battery tubes. He could help but giggle just like me. It’s a cute little sucker. Lol
JasonWW
JasonWW's picture
chinooker wrote:
how about your D1S?
Me? I don’t have a D1S.
JasonWW
JasonWW's picture
I’m sure there wouldn’t be such a huge difference if you had an Astrolux C8 with FET driver and xpl-hi. Mine is a regular Convoy C8 with 8 × 7135 = 2.8A with dome-on xml2 U2-1A and Guppydrv.
klrman
klrman's picture
Last seen: 4 hours 6 min ago
Sorry about that.  I edited it and hit the delete button instead of the save button.  Not the first time I've done that!
Wow, those pics say it all thanks   The difference between the mini and C8 is significant, thanks JasonWW.  I'm just about to order the mini after looking at the comparison shots.
Delta_V
That’s an XM-L based C8, right? The difference is still impressive, but it needs to be pointed out that a modern XP-L HI C8 would outperform the C8 in the photo by a decent margin.
klrman
klrman's picture
Delta_V wrote:
That's an XM-L based C8, right? The difference is still impressive, but it needs to be pointed out that a modern XP-L HI C8 would outperform the C8 in the photo by a decent margin.
Good point as I have both and my XP-L HI C8 is quite a bit brighter than my XM-L C8.
JasonWW
JasonWW's picture
klrman wrote:
Sorry about that.  I edited it and hit the delete button instead of the save button.  Not the first time I’ve done that!
Wow, those pics say it all thanks   The difference between the mini and C8 is significant, thanks JasonWW.  I’m just about to order the mini after looking at the comparison shots.
I just added the distances to the candela ratings. The C8 got 395 meters, the Mini got 769 meters. That’s almost double the distance! It’s like a C8 on steriods. Lol
JasonWW
JasonWW's picture
Yes, I wrote it right in the notes of post 309. Also in the post above.
klrman
klrman's picture
I just added the distances to the candela ratings. The C8 got 395 meters, the Mini got 769 meters. That's almost double the distance! It's like a C8 on steriods. Lol I'm sure there wouldn't be such a huge difference if you had an Astrolux C8 with FET driver and xpl-hi. Mine is a regular Convoy C8 with 8 x 7135 = 2.8A with dome-on xml2 U2-1A and Guppydrv.
Yeah I'm sold, it looks like a real solid light.  I probably asked this before and forgot, but do you know if it has enough room to run the protected 18650's?  I have many of those around.
JasonWW
JasonWW's picture
klrman
klrman's picture
Thanks, I have the protected Keeppower GA's as well so all is good.  Have many protected NC18650B's  but I think they trip at 4.75A or close to that which might be pushing it for this light.
BlueSwordM
BlueSwordM's picture
Last seen: 15 hours 24 min ago
Guys, do you think I would gain more lumens by replacing the double springs with my BeCu springs, or would the forward voltage of the LED be too high for any meaningful gain?
I would like to know.
JasonWW
JasonWW's picture
Couldn’t hurt.
It’s the single driver spring that would most benefit.
It looks like the xpl can survive up to 8 or 9 amps before burning out. I’m getting 5.5A stock. I don’t plan to mess with it, but if you bypassed or replaced the driver spring you might see 6A or more. Peak power for the xpl seems to be at 7A, but the heat is massive.
DB Custom stuck a killer Samsung 30T cell on his and got and extra 250 lumen so I would say there’s a bit more output left.
ZozzV6
ZozzV6's picture
Last seen: 1 day 3 hours ago
Yes it has big difference:
My C8 intensity and throw numbers to compare:
XM-L2 2.8A: 32.5 kcd 360m
XP-L HI 2.8A: 54.5 kcd 464m
XP-L HI 5.9A TA17 fet: 93.1 kcd 610m
Dedomed SST40 8.6A TA17 fet: 136.3 kcd 738m
mortuus
mortuus's picture
Last seen: 1 hour 5 min ago
Great info JasonWW the light is sure worthy gt mini Big Smile it blows any c8 out of the water!
...where Frugal meets with Flashlight!
johnkey68
Last seen: 3 hours 59 min ago
So I did not get the track number A month has passed since payment Very bad, gentlemen merchants
JasonWW
JasonWW's picture
They only started shipping them about 1 week ago. Have you PM’ed Madmax or Neal about a tracking number?
Neal
Neal's picture
Last seen: 4 days 5 hours ago
pls send me your paypal mail
I will check the shipment
JasonWW
JasonWW's picture
Those last two are pretty close. I wonder why the Mini beats your last one? It seems like a beast.
Maybe it’s the reflector? It’s slightly wider, 39mm to 33mm and about 9mm deeper. The mini has an AR lens, my C8 doesn’t. This might give it a definite advantage.
ZozzV6
ZozzV6's picture
It is definitely the reflector diameter that counts. But the last two has AR coated lens. Forgot to mention.
My Emisar D1S with XP-L HI has 124.1 kcd and 704m stock
but with the same dedomed SST40 what was in the C8 I got 160.6 kcd and 801m
JasonWW
JasonWW's picture
johnkey68 wrote:
Hey men!
I’ve already sent my phone number twice
I already received a track number of someone else’s and already received goods
Are you out there, asleep?
Or turn on the fool?
I’m very angry at your incompetence and sluggishness!
There’s no need to talk like that.
So they did send you a tracking number, but it was the wrong one.
Are you saying you already recieved your order? Was it correct?
