Thanks again freeme
Thanks for the code Freeme, I just tried to use it and GB said the “coupon maximum limit has been reached” and wouldn’t let me proceed. Will there be another buy?
Temporarily out of stock.
I received my lamp today. It only took 7 days after I ordered one. I am very impressed with the lantern. It is a lot brighter than I thought. Also being able to change the tints is amazing. The magnet is as strong as on my more popular name brand lights. These would make a great Christmas gift.
If the deal does pop back up, I would be interested in purchasing 2-3 more. Thank you Freeme.
Wow it took less than 10 days to get mine. So far i liked it
I have the same thoughts I bought two already and two more on the way.
Ordered two. Coupon worked.
FB
Looks a good deal. Thinking to buy one for testing purpose.
Interested, thanks.
Thank you. I got it in 6days
Are we still out of stock? Just noticed the thread title is “Active” now. Is there a new code?
Could I get a new code?
I just recieved my two. They are working fine. Very nice design. They even have a blinking side light for when the battery level is below 30%. I have not heard that before, so I thought I’d mention it.
My only minor issue is the coating on the springs is not fixed. On one spring I see several ares where it’s peeling. The other spring has a couple of barely noticable spots. Maybe the next time I have my soldering iron out I’ll add a little bypass wire.
Got my T1 today as well. Figure I’ll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were…
Got my order today, neat little thing it is. Good thing I ordered 4.
rec’ed my 2, all I can say is WOW. Not that I’d want my kids to lose more lanterns but I’ve been supplying them
with the 3xAA lanterns; they’re not worth the 3xAA Eneloops I put in them. And the Blitzwolfs, yea they’d be good night lights
I just got mine as well, Used it a little bit and now I have it charging. With the risk of sounding dumb :person_facepalming: I have a question, to turn off the light can you do it from the top metal switch or do you have to do it from the bottom (next to the tailcap) switch? I tried to turn it off from the top switch but it just kept changing color or brightness, maybe I just haven’t got the hang of it yet.
So, can someone tell me How do you turn it off using only the top switch? :student:
Thanks!
Unfortunately, it can only be switched off using the bottom button…
If you press and hold the bottom button to turn it off, it should memorize your previous color and brightness level.
