Lumens using Texas_Ace Lumen Tube calibrated from Maukkaās S2 plus CW:
GT Mini:
Top of ramp:
turn on 720 lm @30s 705 lm
Turbo:
turn on 1240 lm, @30s 1200 lm
Convoy C8 xm-l2 CW
turn on 850 lm, @30s 785 lm
I would take my lumen measurements with a grain of salt. My tube had to be really dialed down to read accurately to Maukkaās calibration light. Iām still working on this. Even so, 1200 lumen is pretty much on spec. Iām sure other lumen tubes and devices will read higher, maybe much higher. No doubt that the 148kcd @30s is quite impressive. Higher than spec. :+1:
This is a very impressive light. It truly blows away my Convoy C8.
Someone asked me if the Mini really does blow away the C8. I went and took some pictures, but the question got deleted.
Anyway, here is a comparison of the hot spots at a reduced level, but the same relative brightness as if both were on turbo. You can clearly see the Mini has a much smaller, tighter and intense hot spot.
In this picture I had both lights on turbo and the camera sensitivity turned way down. The C8 looks like a corona that is missing the hot spot.
So yeah, the mini really does blow it away.
Yes, protected seem to fit fine. I have a 69mm Keeppower 8A protected Sanyo GA 3500 and a 69.5mm Evva 7A protected Panny B 3400.
The tail springs can collapse down really far so that shouldnāt be an issue.
The thing you should be aware of is the amp draw on your protected cells. If their protection circuitry is only 3 amp then you may not be able to run the GT mini on Turbo.
I measured my Evva at 4.1v and got 2.2A top of ramp and 4A on turbo.
My KeepPower at 4.1v got 2.2A top of ramp and 4.3A on turbo.
I know I gave Lumintop a hard time about adding the big logos on both sides of the battery tube, but after holding the light in my hand and seeing just how small the logos actually are it doesnāt bother me. So I overreacted a bit.
I showed the big and little GT to my cousin and he said cool. Then I showed him both versions with the short battery tubes. He could help but giggle just like me. Itās a cute little sucker. Lol
Iām sure there wouldnāt be such a huge difference if you had an Astrolux C8 with FET driver and xpl-hi. Mine is a regular Convoy C8 with 8 x 7135 = 2.8A with dome-on xml2 U2-1A and Guppydrv.
Sorry about that. I edited it and hit the delete button instead of the save button. Not the first time I've done that!
Wow, those pics say it all thanks The difference between the mini and C8 is significant, thanks JasonWW. I'm just about to order the mini after looking at the comparison shots.
Thatās an XM-L based C8, right? The difference is still impressive, but it needs to be pointed out that a modern XP-L HI C8 would outperform the C8 in the photo by a decent margin.
I just added the distances to the candela ratings. The C8 got 395 meters, the Mini got 769 meters. Thatās almost double the distance! Itās like a C8 on steriods. Lol
Yeah I'm sold, it looks like a real solid light. I probably asked this before and forgot, but do you know if it has enough room to run the protected 18650's? I have many of those around.
Thanks, I have the protected Keeppower GA's as well so all is good. Have many protected NC18650B's but I think they trip at 4.75A or close to that which might be pushing it for this light.
Guys, do you think I would gain more lumens by replacing the double springs with my BeCu springs, or would the forward voltage of the LED be too high for any meaningful gain?
Itās the single driver spring that would most benefit.
It looks like the xpl can survive up to 8 or 9 amps before burning out. Iām getting 5.5A stock. I donāt plan to mess with it, but if you bypassed or replaced the driver spring you might see 6A or more. Peak power for the xpl seems to be at 7A, but the heat is massive.
DB Custom stuck a killer Samsung 30T cell on his and got and extra 250 lumen so I would say thereās a bit more output left.
