nitecore TM10K
Love it. Get a gb started please
Surprise no love for this new light. It reminds me of the the fenix light ld50 that is a dual emitter. Always wanted it but too expensive. I like the rectangle shape and seems so pocket friendly.
What cells are inside this thing?
I like the rectangle shape as it is more space efficient for multi-cell lights. Would love to see a GB for this.
Looks beautiful. Cross fingers for UI and stock emitters.
Interested.
Yup…one click for on and off. Turbo mode allowed to be memorized so that it can be turned on with a single click from off.
it uses a single non-replaceable [the magic Grey] Samsung 48G 21700 cell with 4,800mAh and rated at 35A continuous power, to feed a reliable 100W to the 6x XHP35HD Cree array. To absolutely minimize contact resistance, the cell’s terminals are welded in place. No question the Samsung 48G specs far above competing 21700 cells with its huge capacity AND current capability, so it seems the entire design is made to optimize the current match between cell and emitters.
They claim 100mOhm was the best spring contact resistance they could achieve allowing replaceable cells, so they opted to build in the cell with welded contacts to lower the resistance by a factor of 5 to 20 mOhm, maximizing current delivery. It also features a USB type-C charging port and rapid charge circuit.
it has an OLED status display and user programmable 4 levels in 100 lumen increments.
At first I balked at the rectangular construction, but the photo next to an iPhone made me feel better about it; it seems realistically palm sized with a very wide belt clip, so EDC without a holster is possible.
Overall, I’m pretty excited about this new TM10K. Certainly “not another tube flashlight”, yet Henry Ford Black HA-III anodized finish is the only color option (sigh).
Looks pricey unfortunately :frowning:
A single cell or two? If it’s a single, what’s using up the rest of the space?
https://m.facebook.com/story.php?story_fbid=720984524900898&id=365299783802709
many information
but I read about 400 usd :(
Just read the fine print... Normal high output defaults at 1000 lumens with a runtime of 2 hours, less than spectacular. With high programmable between 400 and 2000 lumens in 100 lumen increments.
...and the 18W USB-C charges the cell to nearly full in 30 minutes
The ugly part is the 10,000 max turbo is time limited to a fixed 7 seconds ! (Sigh). With a Giggles-like 10,000 LUMENS emblazoned on the side of the light, it seems a bit misleading. Also, the candela measurements are disappointing, with only 2,050 cd at the stock high power (1000 lumen total) setting and 20,000 cd at 10,000 lumens FOR JUST SEVEN SECONDS....
So it seems we have a wall of light flood monster that’s compact, sealed case, and pricey. I’d have to see quality comparative beam shots to seriously consider it. The selling point would be entirely subjective on the uber-flood design with the shallow depth smooth reflectors.
just speculation, it seems there’s no NW option, so CW IS the only game in town. I have a Nitecore MH23 which appears to be the same XHP35HD Cree and the tint quality is (speculation about 5700K) quite nice to my eyes, if they are the same.
One really cool cool feature is a monster interwoven 550 Paracord wrist strap with a big “tactical ball” gripping knot.
soooo, a radical departure from the norm, not just another tube light, it’s s rectangle housing a fixed cylinder cell, probably a midrange huge wall of light (that, IMHO, would be its strongest feature).... with tactical balls :-)
I hope the production units doesn’t come with the 10,000 LUMENS!!! Label, makes it look like a cheap Chinese cree ultra bright 400W 1000X zoom tactical flashlight.
Seems like nitecore are also riding the lumen wave but are doing it wrong, if the 7 seconds thing is true.
Also, single cell and 6x XPL HD in tiny reflectors?? If they made it two cell with just dual XHP35 HI for ~4,500 lumens I would buy it in a heartbeat
Yes, A SINGLE CELL, the Samsung 48G 21700 size ... a round peg in a square hole. Same length as a 18650, 3mm wider diameter, yet double the typical capacity (equlivalent to 2x 2400 mAh) of a 18650....
$400 USD MSRP is a deal breaker for me. What happens after a few hundred charge cycles? With its welded contacts, as the cell gradually loses capacity, it’s an eventual certainty that you bought a $400 Bic lighter. Caveat Emptor.
I have had quite a few Nitecore products and very happy with them. But this
10000 LUMENS
nonsense just reeks of lumen wars marketing, period. Quite a disappointment.
Non replaceable cells are a deal-breaker.
Although only 7seconds, being able to produce 10k lumens with 1-cell is quite a technical achievement! I wish the high mode can be set a bit higher at like 3k lumens. I might still buy this if we can get a GB. If it can sustain 2k lumens for 3+ minutes, then it makes this more practical than almost all other single cell lights out there.
10,000 lumens? Sure it will impress the unwashed masses, but as a useful tool this light leaves a lot to be desired. I’ll admit that getting 10K lumens out of a small single cell flashlight is a stunning engineering achievement, but as a useful, practical portable light source, this light leaves a lot to be desired. Exit turbo mode and my TC20 can hold it’s own against this monster light. TC20 is small, powerful, and affordable.
I suspect that there will be many instances of buyer’s remorse.
Hm…… 10,000 lumen turbo for 7-seconds. However, if this has an interface similar to my Nitecore Concept 1 it may be possible to override the rampdown by continuously holding down the button.
This light has an intriguing design and layout, but $400 is way out of my pricerange for a flashlight. I’ll have to pass.
I use my TC20 frequently for work purposes because it is the only single cell light that can maintain 1800 lumens for a couple minutes. If the TM10K can maintain 2k lumens for a couple minutes, that would make it the most practical single cell light out there. I don’t see why everyone is bashing the 10k lumens. I would love to have a turbo mode as powerful as possible so I know I have it if I ever want to blast it on. But normally, I use the 2nd or 3rd highest modes for practical use and only blast on turbo for a few seconds to surprise people or to get a good view of the surrounding.
The host cleary has space for 2 21700 cell, so 5000 lumen per cell is not actually impresses
