Ended
Temporarily out of stock.
I received my lamp today. It only took 7 days after I ordered one. I am very impressed with the lantern. It is a lot brighter than I thought. Also being able to change the tints is amazing. The magnet is as strong as on my more popular name brand lights. These would make a great Christmas gift.
If the deal does pop back up, I would be interested in purchasing 2-3 more. Thank you Freeme.
Wow it took less than 10 days to get mine. So far i liked it
I have the same thoughts I bought two already and two more on the way.
Ordered two. Coupon worked.
FB
Looks a good deal. Thinking to buy one for testing purpose.
Interested, thanks.
Thank you. I got it in 6days
Are we still out of stock? Just noticed the thread title is “Active” now. Is there a new code?
Could I get a new code?
I just recieved my two. They are working fine. Very nice design. They even have a blinking side light for when the battery level is below 30%. I have not heard that before, so I thought I’d mention it.
My only minor issue is the coating on the springs is not fixed. On one spring I see several ares where it’s peeling. The other spring has a couple of barely noticable spots. Maybe the next time I have my soldering iron out I’ll add a little bypass wire.
Got my T1 today as well. Figure I’ll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were… :slight_smile:
Got my order today, neat little thing it is. Good thing I ordered 4. :smiley:
rec’ed my 2, all I can say is WOW. Not that I’d want my kids to lose more lanterns but I’ve been supplying them
with the 3xAA lanterns; they’re not worth the 3xAA Eneloops I put in them. And the Blitzwolfs, yea they’d be good night lights :slight_smile:
Hope he likes it.
I just got mine as well, Used it a little bit and now I have it charging. With the risk of sounding dumb :person_facepalming: I have a question, to turn off the light can you do it from the top metal switch or do you have to do it from the bottom (next to the tailcap) switch? I tried to turn it off from the top switch but it just kept changing color or brightness, maybe I just haven’t got the hang of it yet.
So, can someone tell me How do you turn it off using only the top switch? :student:
Thanks!
Unfortunately, it can only be switched off using the bottom button…
If you press and hold the bottom button to turn it off, it should memorize your previous color and brightness level.
I received my light yesterday and it seems to have some issues…
First is I can’t turn it off without totally removing the battery compartment cap (boy not having anodized threads for a lockout is annoying) but the bottom button doesn’t do anything. Seems like there’s a bad connection at the driver / button or a broken wire inbetween.
I was thinking I could spray paint the threads to try to make it so I could just crack the tail to shut it off. I like the light and definitely want to be able to use it… Does that sound like it’ll fix it make it usable?
Second (and it may be related) is that I can’t ramp brightness in the tint mixing mode. Have I just not figured out the UI yet or does ramping brightness in tint mode require that bottom button again (which wouldn’t be fixed by my proposed solution for shutting it off above)?
I really don’t want to try to open up a glued together plastic bodied light…
The bottom button is used only for red modes and off, everything else is done by the top touch-button
