MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
KawiBoy1428
KawiBoy1428's picture
Last seen: 4 hours 33 min ago
I’m guessing at 6v…3-4amps out of a 17mm, 4-5amps from a 20mm and 5-6amps from a 22mm driver.
KB1428 “Live Life WOT
BlueSwordM
BlueSwordM's picture
Last seen: 3 hours 57 min ago
The 18650 will have more capacity and lower internal resistance.
You just need to replace the springs or bypass them to get the full potential out of the C8. Boost drivers request can pull even higher currents than a FET driver by upping the voltage.
Lowering the resistance at any point in the flashlight itself is crucial.
Yourrid
Yourrid's picture
Last seen: 2 weeks 1 day ago
My thoughts: a quality 18650 would have so much less resistance than 2 18350’s that a FET wouldn’t be pulling nearly as much as a high boost driver. I guess it all depends on what the amps are set at on the boost driver, right?
BlueSwordM
Yes, but I need to explain myself a bit.
In a single cell light, a boost driver will pull more current as the voltage drops farther and farther from the emitter’s foward voltage to keep it in regulation.
That means using steel springs not bypassed at say 6A current, the voltage drop will be around 0,3V. Which is huge.
Say the output power is 18W for a 6V emitter
Our cell at varying voltages and current draw:
18W= 4,20V x 4,28A
18W = 3,9V x 4,50A
18W = 3,60V x 5,00A
As you can see, current draw increases as voltage decreases.
Now, let’s introduce a steel spring(-0,3V for every voltage)
18W = 3,9V x 4,62A
18W = 3,6V x 5,00A
18W = 3,3V x 5,45A
That means you have to pull even more current out of the cell.
Imagine that but at 50W power! You would be pulling at least 12A at 4,2V, and that could go up to 14A at 3,6V, or even 15A at 3,3V! With only a steel spring and no bypass, that would be go much worse. And that is not even counting the internal resistance of the cell, and other resistance in the circuit.
You’d probably get either a low voltage warning almost instantly due to the huge spring resistance, a burned spring, or a huge power loss.
That problem is still there with a FET driver, but since current pulled goes down with voltage, it isn’t as much trouble.
TLDR: For such a powerful boost driver, going with a single 18650 is crucial for both energy and power density. You also need to get rid of all almost all contact resistance, which includes the springs.
Edit: Remove something I should not have said Facepalm
contactcr
Last seen: 4 hours 1 min ago
We get it we all bought your springs Mr BlueSpringM Smile
will34
will34's picture
Last seen: 1 hour 12 min ago
I have a BLF D80 that has been waiting for a decent driver for a XHP50.2 build. can’t wait!
JasonWW
JasonWW's picture
Last seen: 3 hours 23 min ago
Yourrid wrote:
Question for you guys:
I currently have a C8 with a XHP50.2 and a RMM FET with 2 18350’s in it. What do you suppose one of these new boost drivers would do to the output of a XHP50.2 when changing over from 18350’s to a single, high drain 18650 (30Q/VCT5) and one of these drivers?
(Obviously these aren’t out yet, so no one knows exact specs. It’s all conjecture at this point)
How have you not burned out the 50.2 yet? Those leds don’t like FET drivers. Are you running very low drain 18350’s?
KawiBoy1428
FM
eas
eas's picture
Last seen: 8 months 2 days ago
EasyB wrote:
These boost drivers will be a hit, assuming they work well. These will offer multi-emitter performance without the work of making a spacer and finding suitable reflectors. I plan to put a sliced XHP70.2 or XHP50.2 in an emisar D1S.
They are also useful for running triples and quads in series configs. Particularly if one wants to mix emitters with different forward voltages.
Yourrid
Yourrid's picture
  • 2 Efest 18350’s (Purple 2017?)
  • Let the batteries rest a good while after charging (don’t just pop them in)
  • RMM FET with bypassed driver spring, stock spring on the tailcap
  • 20ga leads
  • Pure luck
I got the clear anodizing C8… its a fun and good looking light!
BlueSword – thanks for the detailed explanation! I may have to get in on your spring group buy! Beer
Yourrid
Yourrid's picture
Well I guess I jinxed myself. I was using the above C8 tonight, since we were talking about it… all of a sudden it decided it only wants to use moonlight mode for all levels of intensity. Low is like 1 lumen, medium 10 lumens, high 50 lumens.
Looking at the led on low, one of the arrays is brighter than the other 3. Did I finally blow the emitter?
vinte77
Last seen: 5 days 14 hours ago
So I just checked mountain’s website and I see an out of stock listing for a 17mm boost driver!
JasonWW
JasonWW's picture
What, no link? Lol
17mm boost driver
This boost driver (input voltage is lower than output voltage) can drive 6V LEDs, such as the XHP50.2/70.2 from a single rechargeable lithium-ion battery at an output current of up to 4.2A.  It can also drive a 12V LED, such as the XHP35, at up to around 1.3A.   The MTN-BST2 uses a highly efficient synchronous boost converter squeezed into a tiny 17mm form factor.
Unlike most of the high power boost drivers out there, this driver can achieve a wide dimming range and utilize popular firmwares.
This driver takes up to 10 business days to be built, tested, and shipped.  Your order will not ship until the driver is completed.
Battery & Host Requirements:
In stock form, this driver will pull just over 10A peak current, therefore a 10A+ continuous rated battery is required (unless you reduce the input current limit).  The more voltage the battery can hold under load, the better the driver will perform.  Your switch, springs, etc. must be able to handle the 10A+ input current; this means that you must have high performance or bypassed springs in your light.
The driver must be soldered into the pill or held firmly in place with a retaining ring.  This is required both for adequate thermal and electrical performance.  If during use the light turns off and on, the driver is overheating and needs to be switched to a lower mode or turned off and allowed to cool.  Continued operation at excessively high temperature will damage the driver (damage from excessive temperature will not be covered under warranty).
Specifications:
Boost Converter (input voltage must be lower than output voltage)
3V – 5.5V input voltage range (suitable for a single lithium-ion battery)
Designed to drive 6V LEDs, such as the XHP50.2 and XHP70.2 at drive currents up to 4.5A
Can also drive 12V LEDs, such as the XHP35 at currents up to around 1.3A
Output voltage range:  ~6V —- ~13.8V
Output current range: 6V LED:  1A —- 4.2A
XHP50 / 50.2
XHP70 / 70.2
MT-G2 6V
12V LED:  ~1.3A
XHP35 HD / HI
Input Current Limit Option:
If you are running any battery that is not capable of 10A+ continuous discharge current, you must change the input current limit to a lower value.
~10.5A | 4.2A w/ 6V LED maximum recommended output current
~8A  | 3.5A w/ 6V LED maximum recommended output currnet
~4A | 2A w/ 6V LED maximum recommended output current
Output Current Option:
The output current is set using one or two sense resistors.  You can choose between any of the following output current limit options:
1A
2A
2.5A
3A
3.5A
4.2A
Firmware Options:
Currently only guppy3drv is available.  We will have Bistro available as soon as we get it 100% dialed in.
1. guppy3drv (click for more information).
2. Bistro
contactcr
I’m hoping the 20-22mm versions will have a bit higher 12v output and support both 1s/2s but either way ill still buy one of the 17mm’s as is I think.
JasonWW
JasonWW's picture
Yes, I’m surprised the 12v is not a bit closer to half the 6v output.
We know that a bigger size driver can do 12v up to about 3A, but I’m not sure if Richards will go that high. He may dial it back a little to get better reliability.
This is just the beginning. More is to come. Wink
Yourrid
Yourrid's picture
Richard is about to be flooded with boost driver orders once he lists them in stock Big Smile
Is there a reference you guys use to determine the proper output for XHP and MT-G2 LED’s. I mean, is there a good output to heat chart for each that shows how many amps it would take to blow an emitter?
I don’t want to be selecting 4.2 amps for a XHP50.2 when it can’t handle it. While I wouldn’t want 1A if it can really handle 4.0A either.
contactcr
Check out these examples and look in each of their signatures. I like each member for different information so you should decide for yourself but they basically all test LEDs till they are almost or completely dead.
djozz
http://budgetlightforum.com/node/53086
koef
http://budgetlightforum.com/node/58094
Texas_Ace
http://budgetlightforum.com/node/52227
JasonWW
JasonWW's picture
It’s best to just Google the emitter name and specs. Switch to images and look for charts. I keep a whole folder full of these charts.
For a 6v 50.2 and MT-G2, 4.2A is fine for both.
DB Custom
DB Custom's picture
Last seen: 2 days 1 hour ago
Just so’s ya know, Richard has tested this boost driver of his to death. That’s the way he does things, he won’t release it until he’s very confident it will work reliably. And he’s at that point now. So while we’re just now seeing these he’s been torture testing for quite some time and tweaking to ensure they hold up. Wink
I’ve talked to him about these quite a lot and of course am as eager as anyone to get an order placed. I’m told “Soon”, and I believe they’ll be worth it.
DavidEF
DavidEF's picture
Last seen: 2 days 4 hours ago
Party
- The YKK Philosophy
moderator007
moderator007's picture
Last seen: 2 hours 1 min ago
I just ordered one. Wink
23 more available.
EasyB
Last seen: 3 hours 59 min ago
The 17mm boost driver looks good, but I’m hoping the larger ones will have more power. I’m at a point in my flashaholism that I’m not satisfied with a reasonable amount of power. I need an impractical amount of power. Big Smile
JasonWW
JasonWW's picture
Here’s some pictures. Hmmm, no Atiny85.
JasonWW
JasonWW's picture
There’s not a big difference between 4.2A and 6A. So if you wanted a 70.2 in an S2+, 4.2A is still great. You’ll get much longer run time compared to using 2 × 18350.
Maybe you mean the 12v output? That I can understand.
Personally, I’m still waiting for the e-switch versions with ramping. Wink
vinte77
I just ordered a boost driver for my S2+ copper edition… I’m planning on using a xhp50 90 cri led that i have on hand for now for the build.
contactcr
Be sure to post your beam shots and stuff with that LED. I ordered a 50.2 80CRI 4K one to try in a miniC8 OP reflector
vinte77
Will do, I’ll report back once I have it put together. My led is 5k and the product code is XHP50A-00-0000-0D0UH250G. TA got his hands on some xhp50.2 4.5k 90cri leds that he is going to test on and I think he plans on putting up some for sale. I’m hoping to get my hands on a couple if TA sells it.
contactcr
They are here:
https://www.mouser.com/ProductDetail/Cree-Inc/XHP50B-00-0000-0D0UH245G?q...
Didn’t realize yours were XHP50 and not 50.2 I guess it might not be so comparable to mine. Still interested in your results
Also, I dont want to burst your bubble about that 4500K LED but expect a tint shift if you put it in an S2+, here’s are some beam shots of the zebralight 50.2 4500k 80cri:
http://www.candlepowerforums.com/vb/showthread.php?438803-Zebralight-SC6...
vinte77
contactcr wrote:
They are here:
Well I’ve used these xhp50 leds to make a triple before so I know I like the tint. The 50.2 leds TA has are 90cri and not 80cri, I’m not sure how much difference that’ll make when it comes to the tint shift. Plus I plan on using TIR optics or a Ledil Boom reflector for the light which should eliminate or reduce the tint shift.
will34
will34's picture
Ordered a 17mm BST and there are now just a handful left… XHP50.2 J4 in a C8 with OP reflector, I hope to get a nice even beam out of it.
