Well, this is what happened.
2 or 3 nights ago I was watching TV at nighy. It was a bit hot so I decided to pick a small lighted fan I have (given by a team of a project I participate in) and I turned it on.
When I turned it ON, the TV instantly started acting funny, with interferences in the images (distortions, like a signal failure or slight connection break). But as I live in a house where sometimes signal is lost, I didnât mind in the first time.
However, when I turned it OFF, the interference stopped. So I repeated the process ON-OFF several times. I then decide to film that but till this moment I couldnât understand what is going on. Everytime I turn the fan ON, it provokes those interferences.
Can anyone help me understand why? And if this is normal?
NO, the answer is not âAliens, must be Aliensâ
RFI
Radio Frequency Interference. You can shield your fan or add a ferrite rod to you TV if it is the old type with an external antenna. I would toss the fan.
m
it is a POS.
Thanks Calaveras! Didnât know that could interfere this way
I only have internal antenna, so maybe thatâs the case why it is so vulnerable to these interferences.
After all the interference is not in the TV buy in the antenna :person_facepalming:
I will avoid using the fan! Period! Very fun but weird stuff :zipper_mouth_face:
Those are some small dolls that a national association supporting children, youngsters and adults with intellectual âdeficiencyâ, makes every year to raise some funds to help the association! Every year thereâs a different colour
It is a furry doll with a curved antenna and GITD paint on the tip Like a firefly!
I know these since I was a kid once I have a cousin that was in that association and my uncle sold those to get some money for the its users! Here it is
Guess youâre one of the last holdouts who still watches TV on an old CRT.
Have you ever used an old IR remote next to an AM radio? Even though the intended emissions from the remote is supposed to be just IR, the electronics used to generate the signal made a heck of an RF racket that you could hear on AM. Back in the day, most devices sold in the US had to comply with FCC regulations on signal emissions, but these days the cheap electronics shipped directly from China pretty much bypass any FCC testing. Fortunately most of todayâs digital TVs and devices are fairly resilient to that type of interference, but people still using ye old CRTs are at a âslightâ disadvantage.
Ehehe, the TV was already in the house when I rented it so there was no need to buy one And I donât spend many time at home to watch TV, so I just turn it ON to have some people talking and watch the news! Also, this only has some channels, just the basics ! I spend more time on computer, though, so despite loving TV, I donât care much about the quality of image! BTW, I damaged it a bit due to the proximity of some magnets on the tail of my flashlights :person_facepalming:
Reds are purple now
I never tried what you mention but I will
Ahah, nice, didnât know you had it there too, theyâre quite similar These are nice little creatures. And unless it is âstaring at meâ, I donât bother Eheh
That can likely be fixed or the effect diminished by using the same magnet. Tune to a dead channel so thereâs just snow on the screen. Slowly move the magnet toward the discolored spot, but try not to get all the way to the glass if you can. Then slowly move the magnet to a corner, which should drag the spot with it. Once at the corner very slowly pull the magnet away from the screen. You may have to do this more than once if you donât get close enough. Having a magnet that you can flip over to reverse the polarity can sometimes help with the demagnetization as well. If that doesnât work, then you may need to find or build a degausser.
Wow, didnât know that technique :o I guess I will try it with a less strong magnet (just in case) and see how / if it works! Thatâs a quite nice thing, thanks for the suggestion!
The stain created is quite big so, sometimes, it annoys to have a different colour there. I will try that technique Without the fan around
